    HDMI-CSI bridge driver on VOXL2
    • D
      DanielHviid
      I'm looking at using the VOXL2 as a flight controller for a fixed wing UAS using a gimbal camera with an HDMI output. I see that the HDMI input accessory for the VOXL was discontinued, is there any HDMI-CSI bridge drivers available for the VOXL2, or are there any plans for developing any such drivers?
      • Chad SweetC
        Chad Sweet ModalAI Team
        We have had much better success using HDMI to USB 3 adapters and voxl-uvc-server, so we are focused on that for HDMI support for the time being. It is smaller, cheaper and more robust.
        황인호황 1 Reply Last reply Reply Quote 0
        • 황인호황
          황인호 @Chad Sweet
          @Chad-Sweet
          Where can I connect 'HDMI to USB 3 adapter' to VOXL2 board?
          • Chad SweetC
            This exposes a USB 3 host which is a good way to connect https://docs.modalai.com/voxl2-usb3-uart-add-on/
            황인호황 2 Replies Last reply Reply Quote 0
            • 황인호황
              황인호 @Chad Sweet
              @Chad-Sweet
              Thank you for reply.
              But, If I use this USB 3 adapter, 5G modem board is not useable. Right?
              • 황인호황
                황인호 @Chad Sweet
                @Chad-Sweet
                I found this. The 5G modem board also has a USB 3 port.
                Then, all I need is this cable.
                https://www.modalai.com/collections/cables-1/products/mcbl-00022
