  3. HDMI-CSI bridge driver on VOXL2
6 Posts 3 Posters 1.0k Views 1 Watching
  • D Offline
    D Offline
    DanielHviid
    I'm looking at using the VOXL2 as a flight controller for a fixed wing UAS using a gimbal camera with an HDMI output. I see that the HDMI input accessory for the VOXL was discontinued, is there any HDMI-CSI bridge drivers available for the VOXL2, or are there any plans for developing any such drivers?
      We have had much better success using HDMI to USB 3 adapters and voxl-uvc-server, so we are focused on that for HDMI support for the time being. It is smaller, cheaper and more robust.
      황인호황 1 Reply Last reply
      • Chad SweetC Chad Sweet
        황인호황 Offline
        황인호황 Offline
        황인호
        @Chad-Sweet
        Where can I connect 'HDMI to USB 3 adapter' to VOXL2 board?
          This exposes a USB 3 host which is a good way to connect https://docs.modalai.com/voxl2-usb3-uart-add-on/
          황인호황 2 Replies Last reply
            황인호황 Offline
            황인호황 Offline
            황인호
            @Chad-Sweet
            Thank you for reply.
            But, If I use this USB 3 adapter, 5G modem board is not useable. Right?
              황인호황 Offline
              황인호황 Offline
              황인호
              @Chad-Sweet
              I found this. The 5G modem board also has a USB 3 port.
              Then, all I need is this cable.
              https://www.modalai.com/collections/cables-1/products/mcbl-00022
