  3. Starvis IMX412 doesn't work with VOXL
voxl-flight
2 Posts 2 Posters 673 Views 1 Watching
  • JP DroneJ Offline
    JP DroneJ Offline
    JP Drone
    I tested these sensors with VOXL Flight.
    hires: Starvis IMX412
    tracking: OV7251 167° Tracking Sensor Module
    ToF
    The error occured after I typed voxl-configure-cameras 6 and check hires view in voxl-portal.
    -- Logs begin at Thu 1970-01-01 00:00:04 UTC, end at Thu 1970-01-01 00:01:06 UTC. --
    Jan 01 00:00:07 apq8096 systemd[1]: Started voxl-camera-server.
    Jan 01 00:00:10 apq8096 bash[2030]: ------ voxl-camera-server INFO: Camera server is now stopping
    Jan 01 00:00:10 apq8096 bash[2030]: There is a chance that it may segfault here, this is a mmqcamera bug, ignore it
    Jan 01 00:00:10 apq8096 bash[2030]: ------ voxl-camera-server INFO: Stopping tracking camera
    Jan 01 00:00:10 apq8096 bash[2030]: ------ voxl-camera-server INFO: tracking camera stopped successfully
    Jan 01 00:00:10 apq8096 bash[2030]: ------ voxl-camera-server INFO: Stopping hires camera
    Jan 01 00:00:10 apq8096 bash[2030]: ------ voxl-camera-server INFO: hires camera stopped successfully
    Jan 01 00:00:10 apq8096 bash[2030]: ------ voxl-camera-server INFO: Stopping stereo camera
    Jan 01 00:00:10 apq8096 bash[2030]: Segmentation fault:
    Jan 01 00:00:10 apq8096 bash[2030]: Fault thread: voxl-camera-ser(tid: 2030)
    Jan 01 00:00:10 apq8096 bash[2030]: Fault address: 0x68
    Jan 01 00:00:10 apq8096 bash[2030]: Address not mapped.
    Jan 01 00:00:10 apq8096 systemd[1]: [[1;39mvoxl-camera-server.service: Main process exited, code=killed, status=11/SEGV[[0m
    Jan 01 00:00:10 apq8096 systemd[1]: [[1;39mvoxl-camera-server.service: Unit entered failed state.[[0m
    Jan 01 00:00:10 apq8096 systemd[1]: [[1;39mvoxl-camera-server.service: Failed with result 'signal'.[[0m
    system image: 3.8.0 / voxl-suite: 0.7
    And I also tested it with System Image 4.0, but the error also occured.
    -- Logs begin at Thu 1970-01-01 00:10:17 UTC, end at Thu 1970-01-01 00:13:17 UTC. --
    Jan 01 00:12:42 apq8096 systemd[1]: Stopped voxl-camera-server.
    Jan 01 00:12:42 apq8096 systemd[1]: Started voxl-camera-server.
    Jan 01 00:12:43 apq8096 bash[3645]: ERROR:   Camera 1 failed to find supported preview config: 640x480
    Jan 01 00:12:43 apq8096 bash[3645]: ERROR:   Failed to start camera: tracking, exiting
    Jan 01 00:12:43 apq8096 systemd[1]: [[1;39mvoxl-camera-server.service: Main process exited, code=exited, status=255/n/a[[0m
    Jan 01 00:12:43 apq8096 systemd[1]: [[1;39mvoxl-camera-server.service: Unit entered failed state.[[0m
    Jan 01 00:12:43 apq8096 systemd[1]: [[1;39mvoxl-camera-server.service: Failed with result 'exit-code'.[[0m
    Jan 01 00:12:53 apq8096 systemd[1]: Stopped voxl-camera-server.
    Jan 01 00:12:53 apq8096 systemd[1]: Started voxl-camera-server.
    Jan 01 00:12:53 apq8096 bash[3976]: WARNING: Recieved RAW10 frame, will be converting to RAW8 on cpu
    Jan 01 00:12:59 apq8096 bash[3976]: ERROR:   Recieved Fatal error from camera:hires
    Jan 01 00:12:59 apq8096 bash[3976]: ERROR:   Sending request 3, ErrorCode: -ENODEV
    Jan 01 00:12:59 apq8096 bash[3976]: WARNING: Thread: hires request thread recieved ESTOP
    Jan 01 00:12:59 apq8096 bash[3976]: WARNING: Thread: tracking result thread recieved ESTOP
    Jan 01 00:12:59 apq8096 bash[3976]: WARNING: Thread: hires result thread recieved ESTOP
    Jan 01 00:12:59 apq8096 bash[3976]: WARNING: Thread: tof result thread recieved ESTOP
    Jan 01 00:12:59 apq8096 bash[3976]: WARNING: Thread: tracking request thread recieved ESTOP
    Jan 01 00:12:59 apq8096 bash[3976]: WARNING: Thread: tof request thread recieved ESTOP
    Jan 01 00:12:59 apq8096 bash[3976]: ------ voxl-camera-server INFO: Camera server is now stopping
    Jan 01 00:12:59 apq8096 bash[3976]: WARNING: Deleting buffers: 3 of 16 still in use
    Jan 01 00:13:00 apq8096 bash[3976]: ------ voxl-camera-server INFO: Camera server exited gracefully
    I found "ERROR: Recieved Fatal error from camera:hires" from the message.
    so I disabled hires with voxl-camera-server.conf.
    And ToF and Tracking work.
    Would this require replacing the Starvis camera?
    Or do I need to set up something else?
      this usually means one of the following:
      • camera configuration does not match what is installed. the configuration needs to match what is installed, not what you want to use
      • a connector is not properly seated
      • a connector is backwards
