<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Starvis IMX412 doesn&#x27;t work with VOXL]]></title><description><![CDATA[<p dir="auto">I tested these sensors with VOXL Flight.</p>
<p dir="auto">hires: Starvis IMX412<br />
tracking: OV7251 167° Tracking Sensor Module<br />
ToF</p>
<p dir="auto">The error occured after I typed <code>voxl-configure-cameras 6</code> and check hires view in voxl-portal.</p>
<pre><code>-- Logs begin at Thu 1970-01-01 00:00:04 UTC, end at Thu 1970-01-01 00:01:06 UTC. --
Jan 01 00:00:07 apq8096 systemd[1]: Started voxl-camera-server.
Jan 01 00:00:10 apq8096 bash[2030]: ------ voxl-camera-server INFO: Camera server is now stopping
Jan 01 00:00:10 apq8096 bash[2030]: There is a chance that it may segfault here, this is a mmqcamera bug, ignore it
Jan 01 00:00:10 apq8096 bash[2030]: ------ voxl-camera-server INFO: Stopping tracking camera
Jan 01 00:00:10 apq8096 bash[2030]: ------ voxl-camera-server INFO: tracking camera stopped successfully
Jan 01 00:00:10 apq8096 bash[2030]: ------ voxl-camera-server INFO: Stopping hires camera
Jan 01 00:00:10 apq8096 bash[2030]: ------ voxl-camera-server INFO: hires camera stopped successfully
Jan 01 00:00:10 apq8096 bash[2030]: ------ voxl-camera-server INFO: Stopping stereo camera
Jan 01 00:00:10 apq8096 bash[2030]: Segmentation fault:
Jan 01 00:00:10 apq8096 bash[2030]: Fault thread: voxl-camera-ser(tid: 2030)
Jan 01 00:00:10 apq8096 bash[2030]: Fault address: 0x68
Jan 01 00:00:10 apq8096 bash[2030]: Address not mapped.
Jan 01 00:00:10 apq8096 systemd[1]: &lsqb;&lsqb;1;39mvoxl-camera-server.service: Main process exited, code=killed, status=11/SEGV&lsqb;&lsqb;0m
Jan 01 00:00:10 apq8096 systemd[1]: &lsqb;&lsqb;1;39mvoxl-camera-server.service: Unit entered failed state.&lsqb;&lsqb;0m
Jan 01 00:00:10 apq8096 systemd[1]: &lsqb;&lsqb;1;39mvoxl-camera-server.service: Failed with result 'signal'.&lsqb;&lsqb;0m
<p dir="auto">system image: 3.8.0 / voxl-suite: 0.7</p>
<p dir="auto">And I also tested it with System Image 4.0, but the error also occured.</p>
<pre><code>-- Logs begin at Thu 1970-01-01 00:10:17 UTC, end at Thu 1970-01-01 00:13:17 UTC. --
Jan 01 00:12:42 apq8096 systemd[1]: Stopped voxl-camera-server.
Jan 01 00:12:42 apq8096 systemd[1]: Started voxl-camera-server.
Jan 01 00:12:43 apq8096 bash[3645]: ERROR:   Camera 1 failed to find supported preview config: 640x480
Jan 01 00:12:43 apq8096 bash[3645]: ERROR:   Failed to start camera: tracking, exiting
Jan 01 00:12:43 apq8096 systemd[1]: &lsqb;&lsqb;1;39mvoxl-camera-server.service: Main process exited, code=exited, status=255/n/a&lsqb;&lsqb;0m
Jan 01 00:12:43 apq8096 systemd[1]: &lsqb;&lsqb;1;39mvoxl-camera-server.service: Unit entered failed state.&lsqb;&lsqb;0m
Jan 01 00:12:43 apq8096 systemd[1]: &lsqb;&lsqb;1;39mvoxl-camera-server.service: Failed with result 'exit-code'.&lsqb;&lsqb;0m
Jan 01 00:12:53 apq8096 systemd[1]: Stopped voxl-camera-server.
Jan 01 00:12:53 apq8096 systemd[1]: Started voxl-camera-server.
Jan 01 00:12:53 apq8096 bash[3976]: WARNING: Recieved RAW10 frame, will be converting to RAW8 on cpu
Jan 01 00:12:59 apq8096 bash[3976]: ERROR:   Recieved Fatal error from camera:hires
Jan 01 00:12:59 apq8096 bash[3976]: ERROR:   Sending request 3, ErrorCode: -ENODEV
Jan 01 00:12:59 apq8096 bash[3976]: WARNING: Thread: hires request thread recieved ESTOP
Jan 01 00:12:59 apq8096 bash[3976]: WARNING: Thread: tracking result thread recieved ESTOP
Jan 01 00:12:59 apq8096 bash[3976]: WARNING: Thread: hires result thread recieved ESTOP
Jan 01 00:12:59 apq8096 bash[3976]: WARNING: Thread: tof result thread recieved ESTOP
Jan 01 00:12:59 apq8096 bash[3976]: WARNING: Thread: tracking request thread recieved ESTOP
Jan 01 00:12:59 apq8096 bash[3976]: WARNING: Thread: tof request thread recieved ESTOP
Jan 01 00:12:59 apq8096 bash[3976]: ------ voxl-camera-server INFO: Camera server is now stopping
Jan 01 00:12:59 apq8096 bash[3976]: WARNING: Deleting buffers: 3 of 16 still in use
Jan 01 00:13:00 apq8096 bash[3976]: ------ voxl-camera-server INFO: Camera server exited gracefully
<p dir="auto">I found "ERROR:   Recieved Fatal error from camera:hires" from the message.<br />
so I disabled hires with voxl-camera-server.conf.<br />
And ToF and Tracking work.<br />
Would this require replacing the Starvis camera?<br />
Or do I need to set up something else?</p>
]]></description><link>https://forum.modalai.com/topic/1727/starvis-imx412-doesn-t-work-with-voxl</link><generator>RSS for Node</generator><lastBuildDate>Sat, 08 Aug 2026 00:28:47 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/1727.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 21 Jan 2023 02:05:13 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Starvis IMX412 doesn&#x27;t work with VOXL on Mon, 23 Jan 2023 16:32:59 GMT]]></title><description><![CDATA[<p dir="auto">this usually means one of the following:</p>
<ul>
<li>camera configuration does not match what is installed. the configuration needs to match what is installed, not what you want to use</li>
<li>a connector is not properly seated</li>
<li>a connector is backwards</li>
</ul>
]]></description><link>https://forum.modalai.com/post/8017</link><guid isPermaLink="true">https://forum.modalai.com/post/8017</guid><dc:creator><![CDATA[Chad Sweet]]></dc:creator><pubDate>Mon, 23 Jan 2023 16:32:59 GMT</pubDate></item></channel></rss>
