  2. VOXL Accessories
  3. Cellular Modems
  4. LTE Modem "Feather is Disabled"
Scheduled Pinned Locked Moved Cellular Modems
19 Posts 2 Posters 3.8k Views 2 Watching
  • S Offline
    S Offline
    scottesicdrone
    Hi Guys,
    I was working on setting up the LTE modem add-on with the VOXL. I configured the modem properly and even connected to our VPN, and used QGC on the VPN server. However, when I rebooted the VOXL and went through the process of connecting the modem using voxl-modem --connect_to_network, I wasn't able to connect and got this as output:
    Configuring GPIO pins
        Setting defaults:
            GPIO_PIN_WWAN_WAKEUP_IN  = 1
            GPIO_PIN_WWAN_POWER_ON_N = 1
            GPIO_PIN_WWAN_RESET_N    = 1
        feather is DISABLED
    ENABLE WNC feather module
        feather is DISABLED
        feather is DISABLED
        feather is DISABLED
        feather is DISABLED
        feather is DISABLED
        feather is DISABLED
        feather is DISABLED
        feather is DISABLED
        feather is DISABLED
        feather is DISABLED
        feather is DISABLED
        feather is DISABLED
        feather is DISABLED
        feather is DISABLED
        feather is DISABLED
        feather is DISABLED
        feather is DISABLED
        feather is DISABLED
        feather is DISABLED
        feather is DISABLED
    WARNING: feather state transtion failed.
       enable failed, try again 0 retries remaining
        feather is DISABLED
        feather is DISABLED
        feather is DISABLED
        feather is DISABLED
        feather is DISABLED
        feather is DISABLED
        feather is DISABLED
        feather is DISABLED
        feather is DISABLED
        feather is DISABLED
        feather is DISABLED
        feather is DISABLED
        feather is DISABLED
        feather is DISABLED
        feather is DISABLED
        feather is DISABLED
        feather is DISABLED
        feather is DISABLED
        feather is DISABLED
        feather is DISABLED
       enable failed, try again 1 retries remaining
        feather is DISABLED
        feather is DISABLED
        feather is DISABLED
        feather is DISABLED
        feather is DISABLED
        feather is DISABLED
    I know people previously have had this issue and the solution was that they improperly answered the voxl-configure-modem prompts. But I'm almost certain that this isn't the case because I was able to connect with no problems previously with no issues. What seems to be the problem from my view is that the devices /dev/ttyUSB0 and /dev/ttyACM0, which are supposedly the serial port and AT command port respectively, do not exist! I'm not sure if this is normal or if they are suppose to generate, but they do not show up when ls -la /dev is run:
    total 4
    drwxr-xr-x. 16 root   root          5660 Jan  1  1970 .
    drwxr-xr-x. 29 root   root          4096 Jan  1  1970 ..
    crw-rw-rw-.  1 root   root      224,   0 Jan  1  1970 adsprpc-smd
    crw-------.  1 root   root       10,  37 Jan  1  1970 android_mbim
    crw-------.  1 root   root       10,  28 Jan  1  1970 android_rndis_qc
    crw-------.  1 root   root      244,   3 Jan  1  1970 apr_apps2
    crw-------.  1 root   root       10,  53 Jan  1  1970 ashmem
    crw-------.  1 root   root      248,   0 Jan  1  1970 at_mdm0
    crw-------.  1 root   root      234,   0 Jan  1  1970 at_usb0
    crw-------.  1 root   root      234,   1 Jan  1  1970 at_usb1
    crw-------.  1 root   root      228,   0 Jan  1  1970 avtimer
    crw-------.  1 root   root       10,  56 Jan  1  1970 binder
    drwxr-xr-x.  3 root   root          1680 Jan  1  1970 block
    drwxr-xr-x.  2 root   root           220 Jan  1  1970 bsg
    drwxr-xr-x.  3 root   root            60 Jan  1  1970 bus
    crw-------.  1 root   root       10,  30 Jan  1  1970 ccid_bulk
    crw-------.  1 root   root       10,  31 Jan  1  1970 ccid_ctrl
    drwxr-xr-x.  2 root   root          4020 Jan  1  1970 char
    crw-------.  1 root   root        5,   1 Jan  1  1970 console
    crw-------.  1 root   root       10,  49 Jan  1  1970 coresight-stm
    crw-------.  1 root   root       10,  50 Jan  1  1970 coresight-tmc-etf
    crw-------.  1 root   root       10,  51 Jan  1  1970 coresight-tmc-etr
    crw-------.  1 root   root      227,   0 Jan  1  1970 coresight-tmc-etr-stream
    crw-------.  1 root   root       10,  43 Jan  1  1970 cpu_dma_latency
    crw-rw----.  1 root   diag      243,   0 Jan  1  1970 diag
    drwxr-xr-x.  8 root   root           160 Jan  1  1970 disk
    crw-------.  1 root   root       10,  32 Jan  1  1970 dpl_ctrl
    lrwxrwxrwx.  1 root   root            13 Jan  1  1970 fd -> /proc/self/fd
    crw-rw-rw-.  1 root   root        1,   7 Jan  1  1970 full
    crw-rw-rw-.  1 root   root       10, 229 Jan  1  1970 fuse
    crw-------.  1 root   root      248,   2 Jan  1  1970 glink_pkt_loopback
    crw-------.  1 root   root      248,   1 Jan  1  1970 glink_pkt_loopback_ctrl
    crw-------.  1 root   root       10,  59 Jan  1  1970 hbtp_input
    crw-------.  1 root   root       10,  58 Jan  1  1970 hbtp_vm
    crw-------.  1 root   root       10,  55 Jan  1  1970 hwbinder
    crw-------.  1 root   root       10, 183 Jan  1  1970 hwrng
    crw-------.  1 root   root      239,   0 Jan  1  1970 icesdcc
    crw-------.  1 root   root      240,   0 Jan  1  1970 iceufs
    lrwxrwxrwx.  1 root   root            25 Jan  1  1970 initctl -> /run/systemd/initctl/fifo
    drwxr-xr-x.  2 root   root           160 Jan  1  1970 input
    crw-rw-r--.  1 root   root       10,  94 Jan  1  1970 ion
    crw-------.  1 root   root      233,   0 Jan  1  1970 jpeg0
    crw-------.  1 root   root      232,   0 Jan  1  1970 jpeg2
    crw-------.  1 root   root      231,   0 Jan  1  1970 jpeg3
    crw-------.  1 root   root       10,  57 Jan  1  1970 keychord
    crw-------.  1 root   root      242,   0 Jan  1  1970 kgsl-3d0
    crw-r--r--.  1 root   root        1,  11 Jan  1  1970 kmsg
    lrwxrwxrwx.  1 root   root            28 Jan  1  1970 log -> /run/systemd/journal/dev-log
    crw-rw----.  1 root   disk       10, 237 Jan  1  1970 loop-control
    brw-rw----.  1 root   disk        7,   0 Jan  1  1970 loop0
    brw-rw----.  1 root   disk        7,   1 Jan  1  1970 loop1
    brw-rw----.  1 root   disk        7,   2 Jan  1  1970 loop2
    brw-rw----.  1 root   disk        7,   3 Jan  1  1970 loop3
    brw-rw----.  1 root   disk        7,   4 Jan  1  1970 loop4
    brw-rw----.  1 root   disk        7,   5 Jan  1  1970 loop5
    brw-rw----.  1 root   disk        7,   6 Jan  1  1970 loop6
    brw-rw----.  1 root   disk        7,   7 Jan  1  1970 loop7
    drwxr-xr-x.  2 root   root            60 Jan  1  1970 mapper
    crw-------.  1 root   root      224,   2 Jan  1  1970 mdsprpc-smd
    crw-------.  1 root   root      251,   0 Jan  1  1970 media0
    crw-------.  1 root   root      251,   1 Jan  1  1970 media1
    crw-------.  1 root   root      251,   2 Jan  1  1970 media2
    crw-------.  1 root   root      251,   3 Jan  1  1970 media3
    crw-------.  1 root   root       10,  40 Jan  1  1970 memory_bandwidth
    drwxrwxrwt.  2 root   root            40 Jan  1  1970 mqueue
    crw-------.  1 root   root      256,   0 Jan  1  1970 msm-rng
    crw-------.  1 root   root       10,  75 Jan  1  1970 msm_aac
    crw-------.  1 root   root       10,  83 Jan  1  1970 msm_aac_in
    crw-------.  1 root   root       10,  73 Jan  1  1970 msm_alac
    crw-------.  1 root   root       10,  68 Jan  1  1970 msm_amrnb
    crw-------.  1 root   root       10,  80 Jan  1  1970 msm_amrnb_in
    crw-------.  1 root   root       10,  67 Jan  1  1970 msm_amrwb
    crw-------.  1 root   root       10,  63 Jan  1  1970 msm_amrwb_in
    crw-------.  1 root   root       10,  66 Jan  1  1970 msm_amrwbplus
    crw-------.  1 root   root       10,  72 Jan  1  1970 msm_ape
    crw-------.  1 root   root       10,  93 Jan  1  1970 msm_audio_cal
    crw-------.  1 root   root       10,  65 Jan  1  1970 msm_evrc
    crw-------.  1 root   root       10,  81 Jan  1  1970 msm_evrc_in
    crw-------.  1 root   root       10,  70 Jan  1  1970 msm_g711alaw
    crw-------.  1 root   root       10,  78 Jan  1  1970 msm_g711alaw_in
    crw-------.  1 root   root       10,  71 Jan  1  1970 msm_g711mlaw
    crw-------.  1 root   root       10,  79 Jan  1  1970 msm_g711mlaw_in
    crw-------.  1 root   root       10,  62 Jan  1  1970 msm_hweffects
    crw-------.  1 root   root       10,  69 Jan  1  1970 msm_mp3
    crw-------.  1 root   root       10,  74 Jan  1  1970 msm_multi_aac
    crw-------.  1 root   root       10,  64 Jan  1  1970 msm_qcelp
    crw-------.  1 root   root       10,  82 Jan  1  1970 msm_qcelp_in
    crw-------.  1 root   root       10,  48 Jan  1  1970 msm_rtac
    crw-------.  1 root   root      254,   0 Jan  1  1970 msm_sps
    crw-------.  1 root   root      253,   0 Jan  1  1970 msm_thermal_query
    crw-------.  1 root   root       10,  77 Jan  1  1970 msm_wma
    crw-------.  1 root   root       10,  76 Jan  1  1970 msm_wmapro
    crw-------.  1 root   root       10,  29 Jan  1  1970 mtp_usb
    drwxr-xr-x.  2 root   root            60 Jan  1  1970 net
    crw-------.  1 root   root       10,  42 Jan  1  1970 network_latency
    crw-------.  1 root   root       10,  41 Jan  1  1970 network_throughput
    crw-rw-rw-.  1 root   root        1,   3 Jan  1  1970 null
    crw-------.  1 root   root      108,   0 Jan  1  1970 ppp
    crw-------.  1 root   root       10,   1 Jan  1  1970 psaux
    crw-------.  1 root   root       10,  26 Jan  1  1970 pta
    crw-rw-rw-.  1 root   tty         5,   2 Apr  2 16:31 ptmx
    drwxr-xr-x.  2 root   root             0 Jan  1  1970 pts
    crw-------.  1 root   root      247,   0 Jan  1  1970 qbt1000
    crw-------.  1 root   root       10,  60 Jan  1  1970 qce
    crw-------.  1 root   root      238,   0 Jan  1  1970 qcqmi0
    crw-------.  1 root   root      238,   1 Jan  1  1970 qcqmi1
    crw-------.  1 root   root      238,   2 Jan  1  1970 qcqmi2
    crw-------.  1 root   root      238,   3 Jan  1  1970 qcqmi3
    crw-rw-rw-.  1 root   root      241,   0 Jan  1  1970 qseecom
    brw-rw----.  1 root   disk        1,   0 Jan  1  1970 ram0
    brw-rw----.  1 root   disk        1,   1 Jan  1  1970 ram1
    brw-rw----.  1 root   disk        1,  10 Jan  1  1970 ram10
    brw-rw----.  1 root   disk        1,  11 Jan  1  1970 ram11
    brw-rw----.  1 root   disk        1,  12 Jan  1  1970 ram12
    brw-rw----.  1 root   disk        1,  13 Jan  1  1970 ram13
    brw-rw----.  1 root   disk        1,  14 Jan  1  1970 ram14
    brw-rw----.  1 root   disk        1,  15 Jan  1  1970 ram15
    brw-rw----.  1 root   disk        1,   2 Jan  1  1970 ram2
    brw-rw----.  1 root   disk        1,   3 Jan  1  1970 ram3
    brw-rw----.  1 root   disk        1,   4 Jan  1  1970 ram4
    brw-rw----.  1 root   disk        1,   5 Jan  1  1970 ram5
    brw-rw----.  1 root   disk        1,   6 Jan  1  1970 ram6
    brw-rw----.  1 root   disk        1,   7 Jan  1  1970 ram7
    brw-rw----.  1 root   disk        1,   8 Jan  1  1970 ram8
    brw-rw----.  1 root   disk        1,   9 Jan  1  1970 ram9
    crw-------.  1 root   root       10,  91 Jan  1  1970 ramdump_AR6320
    crw-------.  1 root   root       10,  85 Jan  1  1970 ramdump_a530_zap
    crw-------.  1 root   root       10,  46 Jan  1  1970 ramdump_adsp
    crw-------.  1 root   root       10,  38 Jan  1  1970 ramdump_adsp_rh
    crw-------.  1 root   root       10,  87 Jan  1  1970 ramdump_memshare_DIAG
    crw-------.  1 root   root       10,  88 Jan  1  1970 ramdump_memshare_FTM
    crw-------.  1 root   root       10,  89 Jan  1  1970 ramdump_memshare_GPS
    crw-------.  1 root   root       10,  44 Jan  1  1970 ramdump_modem
    crw-------.  1 root   root       10,  45 Jan  1  1970 ramdump_slpi
    crw-------.  1 root   root       10,  39 Jan  1  1970 ramdump_smem
    crw-------.  1 root   root       10,  86 Jan  1  1970 ramdump_venus
    crw-rw-rw-.  1 root   root        1,   8 Jan  1  1970 random
    prw--w----.  1 root   rebooters        0 Jan  1  1970 rebooterdev
    crw-rw-r--.  1 root   root       10,  92 Jan  1  1970 rfkill
    crw-------.  1 root   root       10,  36 Jan  1  1970 rmnet_ctrl
    crw-------.  1 root   root       10,  35 Jan  1  1970 rmnet_ctrl1
    crw-------.  1 root   root       10,  34 Jan  1  1970 rmnet_ctrl2
    crw-------.  1 root   root       10,  33 Jan  1  1970 rmnet_ctrl3
    lrwxrwxrwx.  1 root   root             4 Jan  1  1970 rtc -> rtc0
    crw-------.  1 root   root      252,   0 Jan  1  1970 rtc0
    brw-rw----.  1 root   disk        8,   0 Jan  1  1970 sda
    brw-rw----.  1 root   disk        8,   1 Jan  1  1970 sda1
    brw-rw----.  1 root   disk        8,   2 Jan  1  1970 sda2
    brw-rw----.  1 root   disk        8,   3 Jan  1  1970 sda3
    brw-rw----.  1 root   disk        8,   4 Jan  1  1970 sda4
    brw-rw----.  1 root   disk        8,   5 Jan  1  1970 sda5
    brw-rw----.  1 root   disk        8,   6 Jan  1  1970 sda6
    brw-rw----.  1 root   disk        8,   7 Jan  1  1970 sda7
    brw-rw----.  1 root   disk        8,   8 Jan  1  1970 sda8
    brw-rw----.  1 root   disk        8,   9 Jan  1  1970 sda9
    brw-rw----.  1 root   disk        8,  16 Jan  1  1970 sdb
    brw-rw----.  1 root   disk        8,  17 Jan  1  1970 sdb1
    brw-rw----.  1 root   disk        8,  32 Jan  1  1970 sdc
    brw-rw----.  1 root   disk        8,  33 Jan  1  1970 sdc1
    brw-rw----.  1 root   disk        8,  48 Jan  1  1970 sdd
    brw-rw----.  1 root   disk        8,  49 Jan  1  1970 sdd1
    brw-rw----.  1 root   disk        8,  50 Jan  1  1970 sdd2
    brw-rw----.  1 root   disk        8,  51 Jan  1  1970 sdd3
    brw-rw----.  1 root   disk        8,  64 Jan  1  1970 sde
    brw-rw----.  1 root   disk        8,  65 Jan  1  1970 sde1
    brw-rw----.  1 root   disk        8,  74 Jan  1  1970 sde10
    brw-rw----.  1 root   disk        8,  75 Jan  1  1970 sde11
    brw-rw----.  1 root   disk        8,  76 Jan  1  1970 sde12
    brw-rw----.  1 root   disk        8,  77 Jan  1  1970 sde13
    brw-rw----.  1 root   disk        8,  78 Jan  1  1970 sde14
    brw-rw----.  1 root   disk        8,  79 Jan  1  1970 sde15
    brw-rw----.  1 root   disk      259,   0 Jan  1  1970 sde16
    brw-rw----.  1 root   disk      259,   1 Jan  1  1970 sde17
    brw-rw----.  1 root   disk      259,   2 Jan  1  1970 sde18
    brw-rw----.  1 root   disk      259,   3 Jan  1  1970 sde19
    brw-rw----.  1 root   disk        8,  66 Jan  1  1970 sde2
    brw-rw-r--.  1 root   disk      259,   4 Jan  1  1970 sde20
    brw-rw----.  1 root   disk      259,   5 Jan  1  1970 sde21
    brw-rw----.  1 root   disk      259,   6 Jan  1  1970 sde22
    brw-rw----.  1 root   disk      259,   7 Jan  1  1970 sde23
    brw-rw----.  1 root   disk      259,   8 Jan  1  1970 sde24
    brw-rw----.  1 root   disk      259,   9 Jan  1  1970 sde25
    brw-rw----.  1 root   disk      259,  10 Jan  1  1970 sde26
    brw-rw----.  1 root   disk      259,  11 Jan  1  1970 sde27
    brw-rw----.  1 root   disk      259,  12 Jan  1  1970 sde28
    brw-rw----.  1 root   disk      259,  13 Jan  1  1970 sde29
    brw-rw----.  1 root   disk        8,  67 Jan  1  1970 sde3
    brw-rw----.  1 root   disk      259,  14 Jan  1  1970 sde30
    brw-rw----.  1 root   disk      259,  15 Jan  1  1970 sde31
    brw-rw----.  1 root   disk      259,  16 Jan  1  1970 sde32
    brw-rw----.  1 root   disk      259,  17 Jan  1  1970 sde33
    brw-rw----.  1 root   disk        8,  68 Jan  1  1970 sde4
    brw-rw----.  1 root   disk        8,  69 Jan  1  1970 sde5
    brw-rw----.  1 root   disk        8,  70 Jan  1  1970 sde6
    brw-rw----.  1 root   disk        8,  71 Jan  1  1970 sde7
    brw-rw----.  1 root   disk        8,  72 Jan  1  1970 sde8
    brw-rw----.  1 root   disk        8,  73 Jan  1  1970 sde9
    brw-rw----.  1 root   disk        8,  80 Jan  1  1970 sdf
    brw-rw----.  1 root   disk        8,  81 Jan  1  1970 sdf1
    brw-rw----.  1 root   disk        8,  82 Jan  1  1970 sdf2
    brw-rw----.  1 root   disk        8,  83 Jan  1  1970 sdf3
    crw-------.  1 root   root      224,   1 Jan  1  1970 sdsprpc-smd
    crw-------.  1 root   root      229,   0 Jan  1  1970 seemplog
    crw-------.  1 root   root      225,   0 Jan  1  1970 sensors
    crw-------.  1 root   root       21,   0 Jan  1  1970 sg0
    crw-------.  1 root   root       21,   1 Jan  1  1970 sg1
    crw-------.  1 system system     21,   2 Jan  1  1970 sg2
    crw-rw----.  1 root   disk       21,   3 Jan  1  1970 sg3
    crw-rw----.  1 root   disk       21,   4 Jan  1  1970 sg4
    crw-rw----.  1 root   disk       21,   5 Jan  1  1970 sg5
    crw-rw----.  1 root   disk       21,   6 Jan  1  1970 sg6
    crw-rw----.  1 root   disk       21,   7 Jan  1  1970 sg7
    crw-rw----.  1 root   disk       21,   8 Jan  1  1970 sg8
    drwxrwxrwt.  2 root   root            40 Jan  1  1970 shm
    crw-------.  1 root   root       10,  84 Jan  1  1970 smcinvoke
    crw-------.  1 root   root      245,  11 Jan  1  1970 smd11
    crw-------.  1 root   root      245,  21 Jan  1  1970 smd21
    crw-------.  1 root   root      244,   1 Jan  1  1970 smd22
    crw-------.  1 root   root      245,  36 Jan  1  1970 smd36
    crw-------.  1 root   root      245,   7 Jan  1  1970 smd7
    crw-------.  1 root   root      245,   8 Jan  1  1970 smd8
    crw-------.  1 root   root      244,   4 Jan  1  1970 smd_pkt_loopback
    crw-------.  1 root   root      244,   0 Jan  1  1970 smdcntl0
    crw-------.  1 root   root      244,   2 Jan  1  1970 smdcntl8
    crw-------.  1 root   root       10,  90 Jan  1  1970 smem_log
    drwxr-xr-x.  2 root   root            60 Jan  1  1970 snd
    drwxrwxrwx.  2 root   root           200 Jan  1  1970 socket
    lrwxrwxrwx.  1 root   root            15 Jan  1  1970 stderr -> /proc/self/fd/2
    lrwxrwxrwx.  1 root   root            15 Jan  1  1970 stdin -> /proc/self/fd/0
    lrwxrwxrwx.  1 root   root            15 Jan  1  1970 stdout -> /proc/self/fd/1
    crw-------.  1 root   root      250,   0 Jan  1  1970 subsys_AR6320
    crw-------.  1 root   root      250,   2 Jan  1  1970 subsys_a530_zap
    crw-------.  1 root   root      250,   3 Jan  1  1970 subsys_adsp
    crw-------.  1 root   root      250,   5 Jan  1  1970 subsys_modem
    crw-------.  1 root   root      250,   4 Jan  1  1970 subsys_slpi
    crw-------.  1 root   root      250,   1 Jan  1  1970 subsys_venus
    crw-------.  1 root   root       10,  52 Jan  1  1970 sw_sync
    crw-rw-rw-.  1 root   tty         5,   0 Jan  1  1970 tty
    crw-rw----.  1 root   dialout   246,   0 Jan  1  1970 ttyHS0
    crw-------.  1 root   root       10, 239 Jan  1  1970 uhid
    crw-------.  1 root   root       10, 223 Jan  1  1970 uinput
    crw-------.  1 root   root      237,   0 Jan  1  1970 uio0
    crw-------.  1 root   root      237,   1 Jan  1  1970 uio1
    crw-------.  1 root   root      237,   2 Jan  1  1970 uio2
    crw-rw-rw-.  1 root   root        1,   9 Jan  1  1970 urandom
    drwxr-xr-x.  3 root   root            60 Jan  1  1970 usb-ffs
    crw-------.  1 root   root       10,  27 Jan  1  1970 usb_accessory
    crw-------.  1 root   root      236,   0 Jan  1  1970 usbmon0
    crw-------.  1 root   root      236,   1 Jan  1  1970 usbmon1
    crw-------.  1 root   root      236,   2 Jan  1  1970 usbmon2
    crw-------.  1 root   root       10,  61 Jan  1  1970 usf1
    crw-rw----.  1 root   video      81,   3 Jan  1  1970 v4l-subdev0
    crw-rw----.  1 root   video      81,   4 Jan  1  1970 v4l-subdev1
    crw-rw----.  1 root   video      81,  13 Jan  1  1970 v4l-subdev10
    crw-rw----.  1 root   video      81,  14 Jan  1  1970 v4l-subdev11
    crw-rw----.  1 root   video      81,  15 Jan  1  1970 v4l-subdev12
    crw-rw----.  1 root   video      81,  16 Jan  1  1970 v4l-subdev13
    crw-rw----.  1 root   video      81,  17 Jan  1  1970 v4l-subdev14
    crw-rw----.  1 root   video      81,  18 Jan  1  1970 v4l-subdev15
    crw-rw----.  1 root   video      81,  21 Jan  1  1970 v4l-subdev16
    crw-rw----.  1 root   video      81,  23 Jan  1  1970 v4l-subdev17
    crw-rw----.  1 root   video      81,  24 Jan  1  1970 v4l-subdev18
    crw-rw----.  1 root   video      81,  26 Jan  1  1970 v4l-subdev19
    crw-rw----.  1 root   video      81,   5 Jan  1  1970 v4l-subdev2
    crw-rw----.  1 root   video      81,   6 Jan  1  1970 v4l-subdev3
    crw-rw----.  1 root   video      81,   7 Jan  1  1970 v4l-subdev4
    crw-rw----.  1 root   video      81,   8 Jan  1  1970 v4l-subdev5
    crw-rw----.  1 root   video      81,   9 Jan  1  1970 v4l-subdev6
    crw-rw----.  1 root   video      81,  10 Jan  1  1970 v4l-subdev7
    crw-rw----.  1 root   video      81,  11 Jan  1  1970 v4l-subdev8
    crw-rw----.  1 root   video      81,  12 Jan  1  1970 v4l-subdev9
    crw-------.  1 root   root       10,  95 Jan  1  1970 vga_arbiter
    crw-rw----.  1 root   video      81,   2 Jan  1  1970 video0
    crw-rw----.  1 root   video      81,  19 Jan  1  1970 video1
    crw-rw----.  1 root   video      81,  20 Jan  1  1970 video2
    crw-rw----.  1 root   video      81,  22 Jan  1  1970 video3
    crw-rw----.  1 root   video      81,   0 Jan  1  1970 video32
    crw-rw----.  1 root   video      81,   1 Jan  1  1970 video33
    crw-rw----.  1 root   video      81,  25 Jan  1  1970 video4
    crw-------.  1 root   root       10,  54 Jan  1  1970 vndbinder
    crw-------.  1 root   root       10,  47 Jan  1  1970 xt_qtaguid
    crw-rw-rw-.  1 root   root        1,   5 Jan  1  1970 zero
    brw-rw----.  1 root   disk      253,   0 Jan  1  1970 zram0
    Some more useful info for debugging this (I ran this with the modem in):
    yocto:/# lsusb -v
    Device Descriptor:
      bLength                18
      bDescriptorType         1
      bcdUSB               3.00
      bDeviceClass            9 Hub
      bDeviceSubClass         0
      bDeviceProtocol         3
      bMaxPacketSize0         9
      idVendor           0x1d6b Linux Foundation
      idProduct          0x0003 3.0 root hub
      bcdDevice            3.18
      iManufacturer           3 Linux 3.18.71-perf xhci-hcd
      iProduct                2 xHCI Host Controller
      iSerial                 1 xhci-hcd.0.auto
      bNumConfigurations      1
      Configuration Descriptor:
        bLength                 9
        bDescriptorType         2
        wTotalLength           31
        bNumInterfaces          1
        bConfigurationValue     1
        iConfiguration          0
        bmAttributes         0xe0
          Self Powered
          Remote Wakeup
        MaxPower                0mA
        Interface Descriptor:
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        0
          bAlternateSetting       0
          bNumEndpoints           1
          bInterfaceClass         9 Hub
          bInterfaceSubClass      0
          bInterfaceProtocol      0 Full speed (or root) hub
          iInterface              0
          Endpoint Descriptor:
            bLength                 7
            bDescriptorType         5
            bEndpointAddress     0x81  EP 1 IN
            bmAttributes            3
              Transfer Type            Interrupt
              Synch Type               None
              Usage Type               Data
            wMaxPacketSize     0x0004  1x 4 bytes
            bInterval              12
            bMaxBurst               0
    Hub Descriptor:
      bLength              12
      bDescriptorType      42
      nNbrPorts             0
      wHubCharacteristic 0x000a
        No power switching (usb 1.0)
        Per-port overcurrent protection
      bPwrOn2PwrGood       10 * 2 milli seconds
      bHubContrCurrent      0 milli Ampere
      bHubDecLat          0.0 micro seconds
      wHubDelay             0 nano seconds
      DeviceRemovable    0x00
     Hub Port Status:
    Binary Object Store Descriptor:
      bLength                 5
      bDescriptorType        15
      wTotalLength           15
      bNumDeviceCaps          1
      SuperSpeed USB Device Capability:
        bLength                10
        bDescriptorType        16
        bDevCapabilityType      3
        bmAttributes         0x02
          Latency Tolerance Messages (LTM) Supported
        wSpeedsSupported   0x0008
          Device can operate at SuperSpeed (5Gbps)
        bFunctionalitySupport   3
          Lowest fully-functional device speed is SuperSpeed (5Gbps)
        bU1DevExitLat           0 micro seconds
        bU2DevExitLat           0 micro seconds
    can't get debug descriptor: Resource temporarily unavailable
    Device Status:     0x0001
      Self Powered
    Bus 001 Device 002: ID 0424:2514 Standard Microsystems Corp. USB 2.0 Hub
    Device Descriptor:
      bLength                18
      bDescriptorType         1
      bcdUSB               2.00
      bDeviceClass            9 Hub
      bDeviceSubClass         0
      bDeviceProtocol         2 TT per port
      bMaxPacketSize0        64
      idVendor           0x0424 Standard Microsystems Corp.
      idProduct          0x2514 USB 2.0 Hub
      bcdDevice            b.b3
      iManufacturer           0
      iProduct                0
      iSerial                 0
        bLength                 9
        bDescriptorType         2
        wTotalLength           41
        bNumInterfaces          1
        iConfiguration          0
        bmAttributes         0xe0
          Self Powered
          Remote Wakeup
        MaxPower                2mA
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        0
          bAlternateSetting       0
          bNumEndpoints           1
          bInterfaceProtocol      1 Single TT
          iInterface              0
            bLength                 7
            bDescriptorType         5
            bmAttributes            3
              Synch Type               None
              Usage Type               Data
            wMaxPacketSize     0x0001  1x 1 bytes
            bInterval              12
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        0
          bAlternateSetting       1
          bNumEndpoints           1
          bInterfaceProtocol      2 TT per port
          iInterface              0
            bLength                 7
            bDescriptorType         5
            bmAttributes            3
              Synch Type               None
              Usage Type               Data
            bInterval              12
    Hub Descriptor:
      bLength               9
      bDescriptorType      41
      nNbrPorts             3
      wHubCharacteristic 0x0009
        Per-port power switching
        TT think time 8 FS bits
      bPwrOn2PwrGood       50 * 2 milli seconds
      bHubContrCurrent      1 milli Ampere
      PortPwrCtrlMask    0xff
     Hub Port Status:
       Port 1: 0000.0100 power
       Port 2: 0000.0100 power
       Port 3: 0000.0100 power
    Device Qualifier (for other device speed):
      bLength                10
      bDescriptorType         6
      bcdUSB               2.00
      bDeviceClass            9 Hub
      bDeviceSubClass         0
      bDeviceProtocol         0 Full speed (or root) hub
      bMaxPacketSize0        64
      Self Powered
    Device Descriptor:
      bLength                18
      bDescriptorType         1
      bcdUSB               2.00
      bDeviceClass            9 Hub
      bDeviceSubClass         0
      bDeviceProtocol         1 Single TT
      bMaxPacketSize0        64
      idProduct          0x0002 2.0 root hub
      bcdDevice            3.18
        bLength                 9
        bDescriptorType         2
        wTotalLength           25
        bNumInterfaces          1
        iConfiguration          0
        bmAttributes         0xe0
          Self Powered
          Remote Wakeup
        MaxPower                0mA
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        0
          bAlternateSetting       0
          bNumEndpoints           1
          iInterface              0
            bLength                 7
            bDescriptorType         5
            bmAttributes            3
              Synch Type               None
              Usage Type               Data
            bInterval              12
    Hub Descriptor:
      bLength               9
      bDescriptorType      41
      nNbrPorts             1
     Hub Port Status:
       Port 1: 0000.0507 highspeed power suspend enable connect
    can't get device qualifier: Resource temporarily unavailable
      Self Powered
    The last thing to note is that all the lights on the modem seem to be on, even the WWAN light when trying to run voxl-modem. Any help on this as soon as possible would be greatly appreciated!
      Hi @scottesicdrone ,
      Just to make sure I understand your setup, are you using a v1 modem or v2 modem?
      Another question, did you previously run voxl-configure-modem? If so there will be a service running in the background on boot attempting to connect to the LTE network.
      You can check the status of this service by running systemctl status -l voxl-modem
      • S Offline
        S Offline
        scottesicdrone
        Thanks for the quick response! We are using a v1 modem.
        We ran voxl-configure-modem previously so that definitely could be the case. Here is the output for systemctl status -l voxl-modem:
        yocto:/# systemctl status -l voxl-modem
        ● voxl-modem.service - Modem Initialization
           Loaded: loaded (/etc/systemd/system/voxl-modem.service; enabled; vendor preset: enabled)
           Active: active (running) since Thu 1970-01-01 00:00:08 UTC; 51 years 3 months ago
          Process: 2041 ExecStartPre=/bin/sleep 2 (code=exited, status=0/SUCCESS)
         Main PID: 2824 (voxl-modem-star)
           CGroup: /system.slice/voxl-modem.service
                   ├─2824 /bin/bash /usr/bin/voxl-modem-start.sh
                   └─2907 /usr/bin/python /usr/bin/voxl-modem --feather_configure
        Jan 01 00:00:06 apq8096 systemd[1]: Starting Modem Initialization...
        Jan 01 00:00:08 apq8096 systemd[1]: Started Modem Initialization.
        Jan 01 00:00:09 apq8096 voxl-modem-start.sh[2824]: Initializing v1 modem...
        Should I disable this service and try configuring and connecting?
          wrote on last edited by tom
          @scottesicdrone Okay great, if you went through the setup using voxl-configure-modem then you shouldn't need to run anything manually. Can I also see what your voxl-modem config file looks like: /etc/modalai/voxl-modem.conf? As a next step I would try rebooting and monitoring the status of the voxl-modem service with watch systemctl status -l voxl-modem.
          • S Offline
            S Offline
            scottesicdrone
            Here is my voxl-modem.conf file:
            	"modem_type":	"v1",
            	"apn":	"broadband",
            	"world":	"false",
            	"microhard_ip": "192.168.168.100",
            	"modallink":	"false",
            	"placeholder": "hello world"
            I'm watching the service right now and here is where it is at currently
               Active: active (running) since Thu 1970-01-01 00:01:23 UTC; 51 years 3 months ago
              Process: 2129 ExecStartPre=/bin/sleep 2 (code=exited, status=0/SUCCESS)
             Main PID: 2853 (voxl-modem-star)
                       ├─2853 /bin/bash /usr/bin/voxl-modem-start.sh
                       └─3364 /usr/bin/python /usr/bin/voxl-modem --connect_to_network
            Apr 02 17:13:49 apq8096 voxl-modem-start.sh[2853]: Setting network preference to LTE
            Apr 02 17:13:59 apq8096 voxl-modem-start.sh[2853]: Failed to open device
            Apr 02 17:13:59 apq8096 voxl-modem-start.sh[2853]: Finished setting network preference
            Apr 02 17:13:59 apq8096 voxl-modem-start.sh[2853]: Disabling band 5...
            Apr 02 17:13:59 apq8096 voxl-modem-start.sh[2853]: configband starting
            Apr 02 17:13:59 apq8096 voxl-modem-start.sh[2853]: Band mask 1 to 32: 0x0000080a 0x0a 0x08 0x00 0x00
            Apr 02 17:13:59 apq8096 voxl-modem-start.sh[2853]: Band mask 33 to 64: 0x00000000 0x00 0x00 0x00 0x00
            Apr 02 17:13:59 apq8096 voxl-modem-start.sh[2853]: Band mask 65 to 96: 0x00000000 0x00 0x00 0x00 0x00
            Apr 02 17:13:59 apq8096 voxl-modem-start.sh[2853]: Error opening /dev/ttyUSB0: No such file or directory
            Apr 02 17:13:59 apq8096 voxl-modem-start.sh[2853]: Initalizing cellular connection...
              @scottesicdrone Okay let's have you go through the steps manually to see if it's a timing issue.
              First, disable the voxl-modem service -> systemctl disable voxl-modem and reboot.
              Now, run the following:
              voxl-modem --feather_configure -> this should bring up /dev/qcqmi0 and /dev/ttyUSB0, make sure these exist before proceeding
              Next, run:
              uqmi -P -d /dev/qcqmi0 --set-network-preference lte
              then
              configband write /dev/ttyUSB0 0x80a
              Lastly, run
              voxl-modem --conect_to_network
              • S Offline
                S Offline
                scottesicdrone
                I disabled the service and ran voxl-modem --feather_configure and got this:
                    Setting defaults:
                    feather is DISABLED
                    feather is DISABLED
                    feather is DISABLED
                    feather is DISABLED
                    feather is DISABLED
                    feather is DISABLED
                    feather is DISABLED
                    feather is DISABLED
                    feather is DISABLED
                    feather is DISABLED
                    feather is DISABLED
                    feather is DISABLED
                    feather is DISABLED
                    feather is DISABLED
                    feather is DISABLED
                    feather is DISABLED
                    feather is DISABLED
                    feather is DISABLED
                    feather is DISABLED
                    feather is DISABLED
                    feather is DISABLED
                    feather is DISABLED
                    feather is DISABLED
                    feather is DISABLED
                    feather is DISABLED
                    feather is DISABLED
                    feather is DISABLED
                    feather is DISABLED
                    feather is DISABLED
                    feather is DISABLED
                    feather is DISABLED
                    feather is DISABLED
                    feather is DISABLED
                    feather is DISABLED
                    feather is DISABLED
                    feather is DISABLED
                    feather is DISABLED
                    feather is DISABLED
                    feather is DISABLED
                    feather is DISABLED
                    feather is DISABLED
                    feather is DISABLED
                    feather is DISABLED
                And this will keep going if I let it, I'm pretty sure. In the /dev folder, /dev/qcqmi0 exists but /dev/ttyUSB0 doesn't exist.
                  @scottesicdrone Thanks for the info, I will look into this behavior in order to get a solution for you
                  • S Offline
                    S Offline
                    scottesicdrone
                    Thanks, Tom, for the help! I really appreciate it! Is it possible that the serial port and the ports got renamed from /dev/ttyACM0 and /dev/ttyUSB0? I'm not too familiar with how these devices are generated or normal behavior for these devices. We have also noticed that this happened on two different VOXLs with the same v1 modem, so this problem seems to be with the modem and not the VOXL (though this is not something I am 100% certain about).
                      @scottesicdrone I'm leaning toward it being a hardware issue with your modem. Did anything hardware related change from when it was working and wasn't working? Do you have any other v1 modems you can test with?
                      • S Offline
                        S Offline
                        scottesicdrone
                        Nothing physically changed that I can recall, and unfortunately, we don't have extra modems though we ordered more modems. Last potential useful bit of info: when I ran dmesg, I saw errors relating to qmi pop up but I don't know what to make of them:
                        yocto:/# dmesg | grep "qmi"
                        [    1.186410] usbcore: registered new interface driver qmi_wwan
                        [    1.187419] msm_sharedmem: sharedmem_register_qmi: qmi init successful
                        [    5.741357] sysmon_send_event_no_qmi: Message sending failed -19
                        [    5.890086] type=1130 audit(7.556:61): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0-s15:c0.c1023 msg='unit=qmi_shutdown_modemd comm="systemd" exe="/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
                        [    5.903844] sysmon_send_event_no_qmi: Message sending failed -19
                        [    5.903850] sysmon_send_event_no_qmi: Message sending failed -19
                        [    5.908564] sysmon-qmi: sysmon_clnt_svc_arrive: Connection established between QMI handle and slpi's SSCTL service
                        [    5.914578] sysmon_send_event_no_qmi: Message sending failed -19
                        [    6.039513] sysmon-qmi: sysmon_clnt_svc_arrive: Connection established between QMI handle and adsp's SSCTL service
                        [    6.523379] sysmon-qmi: sysmon_clnt_svc_arrive: Connection established between QMI handle and modem's SSCTL service
                        [    6.543970] msm_slim_qmi_send_power_request: QMI request failed 0x1 (Unknown error)
                        [    7.045169] msm_slim_qmi_send_power_request: QMI request failed 0x1 (Unknown error)
                        [    7.546548] msm_slim_qmi_send_power_request: QMI request failed 0x1 (Unknown error)
                        [    8.049225] msm_slim_qmi_send_power_request: QMI request failed 0x1 (Unknown error)
                          Can you also run voxl-version so I can see what system image / package version you're using.
                          • S Offline
                            S Offline
                            scottesicdrone
                            Here is what I get when I run voxl-version:
                            yocto:/# voxl-version
                            system-image:    ModalAI 3.1.0 BUILDER: ekatzfey BUILD_TIME: 2020-12-23_19:41
                            kernel:          #1 SMP PREEMPT Wed Dec 23 19:50:23 UTC 2020 3.18.71-perf
                            factory-bundle:  1.0.1 (Yocto installation)
                            architecture:    aarch64
                            processor:       apq8096
                            os:              GNU/Linux
                            voxl-suite:
                            Package: voxl-suite
                            Version: 0.3.4
                            Depends: voxl-utils (>= 0.6.0), libmodal_json (>= 0.3.4), libmodal_pipe (>= 1.7.8), librc_math (>= 1.1.4), libvoxl_io (>= 0.5.4), mavlink-camera-manager (>= 0.0.1), opencv (>= 4.5.1), openmp (>= 10.0.1), voxl-camera-server (>= 0.5.6), voxl-dfs-server (>= 0.0.7), voxl-docker-support (>= 1.1.1), voxl-gphoto2 (>= 0.0.5), voxl-hal3-tof-cam-ros (>= 0.0.5), voxl-imu-server (>= 0.7.8), voxl-modem (>= 0.11.0), voxl-mpa-tflite-server (>= 0.0.2), voxl-mpa-tools (>= 0.1.6), voxl-nodes (>= 0.1.3), voxl-qvio-server (>= 0.2.1), voxl-rtsp (>= 1.0.3), voxl-streamer (>= 0.2.1), voxl-vision-px4 (>= 0.8.1), voxl-vpn (>= 0.0.3)
                            Section: base
                            Architecture: all
                            Maintainer: james@modalai.com
                            MD5Sum: e1e5bf1a125affe5036099f6ce895bed
                            Filename: voxl-suite_0.3.4.ipk
                            Description: meta-package for voxl-suite stable release
                            Package: voxl-suite
                            Version: 0.2.0
                            Depends: docker, imu_app (= 0.0.6), libvoxl_io (= 0.5.2), voxl-cam-manager (= 0.2.2), voxl-docker-support (= 1.1.1), voxl-hal3-tof-cam-ros (= 0.0.2), voxl-modem (= 0.10.0), voxl-nodes (= 0.0.8), voxl-rtsp (= 1.0.2), voxl-utils (= 0.5.2), voxl-vision-px4 (= 0.6.8), voxl_imu (= 0.0.4), voxl-time-sync (= 0.0.1), voxl-vpn (= 0.0.2), librc_math (= 1.1.2), libmodal_pipe (= 1.2.2), modalai-vl (= 0.1.3)
                            Section: base
                            Architecture: armv7a
                            MD5Sum: af706cd3c1ea59f274f2ed9b93141f1d
                            Filename: voxl-suite_0.2.0.ipk
                            Description: meta-package to install all of the voxl-suite
                            Installed-Time: 689
                              Just to show you what a working modem would look like:
                              / # voxl-modem --feather_configure
                                  Setting defaults:
                                  feather is DISABLED
                                  feather is DISABLED
                                  feather is DISABLED
                                  feather is DISABLED
                                  feather is ENABLED, device detected: /dev/ttyUSB0
                              It comes up within a few seconds. Good thought about qmi / dmesg, those errors will go away once the modem is powered up correctly by voxl-modem
                              • S Offline
                                S Offline
                                scottesicdrone
                                This makes a lot of sense. I have seen this working before but now it just says feather is DISABLED until it power cycles and repeats. So if I understand correctly, after a few seconds, /dev/ttyUSB0 will be created and then the feather is enabled? Also random question: what is a feather exactly? I haven't heard of this before and I tried to look into it but I'm still confused!
                                  @scottesicdrone Haha okay so "feather" is a remnant from the days that the VOXL predecessor was a Qualcomm product. The nickname for the project at the time was "Eagle", therefore a "feather" was the nickname for an add-on board for the Eagle. So any reference to "feather" in voxl-modem is just talking about the modem add-on board. An example of one of the VOXL's predecessors is currently powering NASA's "Ingenuity" Drone on Mars (https://mars.nasa.gov/technology/helicopter/).
                                  A little ModalAI lore for you that you won't find on Google 😉
                                  • S Offline
                                    S Offline
                                    scottesicdrone
                                    Love the Lore and good thing to note! Last last thing, here is the link to an instance of me running dmesg if that's of any use.
                                    output here
                                    I'm going to keep trying to figure this out because this is a time-sensitive situation but if we will know for sure if it's a hardware issue once we get another modem to test it on. Thanks for the help thus far! Anything else I should try on here?
                                      @scottesicdrone Thanks! I am going to have another resource take a look at the issue and I will update you with our conclusion. I will message you if anything else is needed.
                                      • S Offline
                                        S Offline
                                        scottesicdrone
                                        Sounds good, thanks!
