  3. LTE Modem "Feather is Disabled"
cellular
19 Posts 2 Posters 4.4k Views 2 Watching
  • S Offline
    S Offline
    scottesicdrone
    I disabled the service and ran voxl-modem --feather_configure and got this:
    Configuring GPIO pins
        Setting defaults:
            GPIO_PIN_WWAN_WAKEUP_IN  = 1
            GPIO_PIN_WWAN_POWER_ON_N = 1
            GPIO_PIN_WWAN_RESET_N    = 1
        feather is DISABLED
    ENABLE WNC feather module
        feather is DISABLED
        feather is DISABLED
        feather is DISABLED
        feather is DISABLED
        feather is DISABLED
        feather is DISABLED
        feather is DISABLED
        feather is DISABLED
        feather is DISABLED
        feather is DISABLED
        feather is DISABLED
        feather is DISABLED
        feather is DISABLED
        feather is DISABLED
        feather is DISABLED
        feather is DISABLED
        feather is DISABLED
        feather is DISABLED
        feather is DISABLED
        feather is DISABLED
    WARNING: feather state transtion failed.
       enable failed, try again 0 retries remaining
        feather is DISABLED
        feather is DISABLED
        feather is DISABLED
        feather is DISABLED
        feather is DISABLED
        feather is DISABLED
        feather is DISABLED
        feather is DISABLED
        feather is DISABLED
        feather is DISABLED
        feather is DISABLED
        feather is DISABLED
        feather is DISABLED
        feather is DISABLED
        feather is DISABLED
        feather is DISABLED
        feather is DISABLED
        feather is DISABLED
        feather is DISABLED
        feather is DISABLED
       enable failed, try again 1 retries remaining
        feather is DISABLED
        feather is DISABLED
    And this will keep going if I let it, I'm pretty sure. In the /dev folder, /dev/qcqmi0 exists but /dev/ttyUSB0 doesn't exist.
      @scottesicdrone Thanks for the info, I will look into this behavior in order to get a solution for you
      • S Offline
        S Offline
        scottesicdrone
        Thanks, Tom, for the help! I really appreciate it! Is it possible that the serial port and the ports got renamed from /dev/ttyACM0 and /dev/ttyUSB0? I'm not too familiar with how these devices are generated or normal behavior for these devices. We have also noticed that this happened on two different VOXLs with the same v1 modem, so this problem seems to be with the modem and not the VOXL (though this is not something I am 100% certain about).
          @scottesicdrone I'm leaning toward it being a hardware issue with your modem. Did anything hardware related change from when it was working and wasn't working? Do you have any other v1 modems you can test with?
          • S Offline
            S Offline
            scottesicdrone
            Nothing physically changed that I can recall, and unfortunately, we don't have extra modems though we ordered more modems. Last potential useful bit of info: when I ran dmesg, I saw errors relating to qmi pop up but I don't know what to make of them:
            yocto:/# dmesg | grep "qmi"
            [    1.186410] usbcore: registered new interface driver qmi_wwan
            [    1.187419] msm_sharedmem: sharedmem_register_qmi: qmi init successful
            [    5.741357] sysmon_send_event_no_qmi: Message sending failed -19
            [    5.890086] type=1130 audit(7.556:61): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0-s15:c0.c1023 msg='unit=qmi_shutdown_modemd comm="systemd" exe="/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
            [    5.903844] sysmon_send_event_no_qmi: Message sending failed -19
            [    5.903850] sysmon_send_event_no_qmi: Message sending failed -19
            [    5.908564] sysmon-qmi: sysmon_clnt_svc_arrive: Connection established between QMI handle and slpi's SSCTL service
            [    5.914578] sysmon_send_event_no_qmi: Message sending failed -19
            [    6.039513] sysmon-qmi: sysmon_clnt_svc_arrive: Connection established between QMI handle and adsp's SSCTL service
            [    6.523379] sysmon-qmi: sysmon_clnt_svc_arrive: Connection established between QMI handle and modem's SSCTL service
            [    6.543970] msm_slim_qmi_send_power_request: QMI request failed 0x1 (Unknown error)
            [    7.045169] msm_slim_qmi_send_power_request: QMI request failed 0x1 (Unknown error)
            [    7.546548] msm_slim_qmi_send_power_request: QMI request failed 0x1 (Unknown error)
            [    8.049225] msm_slim_qmi_send_power_request: QMI request failed 0x1 (Unknown error)
              Can you also run voxl-version so I can see what system image / package version you're using.
              • S Offline
                S Offline
                scottesicdrone
                Here is what I get when I run voxl-version:
                yocto:/# voxl-version
                system-image:    ModalAI 3.1.0 BUILDER: ekatzfey BUILD_TIME: 2020-12-23_19:41
                kernel:          #1 SMP PREEMPT Wed Dec 23 19:50:23 UTC 2020 3.18.71-perf
                factory-bundle:  1.0.1 (Yocto installation)
                architecture:    aarch64
                processor:       apq8096
                os:              GNU/Linux
                voxl-suite:
                Package: voxl-suite
                Version: 0.3.4
                Depends: voxl-utils (>= 0.6.0), libmodal_json (>= 0.3.4), libmodal_pipe (>= 1.7.8), librc_math (>= 1.1.4), libvoxl_io (>= 0.5.4), mavlink-camera-manager (>= 0.0.1), opencv (>= 4.5.1), openmp (>= 10.0.1), voxl-camera-server (>= 0.5.6), voxl-dfs-server (>= 0.0.7), voxl-docker-support (>= 1.1.1), voxl-gphoto2 (>= 0.0.5), voxl-hal3-tof-cam-ros (>= 0.0.5), voxl-imu-server (>= 0.7.8), voxl-modem (>= 0.11.0), voxl-mpa-tflite-server (>= 0.0.2), voxl-mpa-tools (>= 0.1.6), voxl-nodes (>= 0.1.3), voxl-qvio-server (>= 0.2.1), voxl-rtsp (>= 1.0.3), voxl-streamer (>= 0.2.1), voxl-vision-px4 (>= 0.8.1), voxl-vpn (>= 0.0.3)
                Section: base
                Architecture: all
                Maintainer: james@modalai.com
                MD5Sum: e1e5bf1a125affe5036099f6ce895bed
                Filename: voxl-suite_0.3.4.ipk
                Description: meta-package for voxl-suite stable release
                Package: voxl-suite
                Version: 0.2.0
                Depends: docker, imu_app (= 0.0.6), libvoxl_io (= 0.5.2), voxl-cam-manager (= 0.2.2), voxl-docker-support (= 1.1.1), voxl-hal3-tof-cam-ros (= 0.0.2), voxl-modem (= 0.10.0), voxl-nodes (= 0.0.8), voxl-rtsp (= 1.0.2), voxl-utils (= 0.5.2), voxl-vision-px4 (= 0.6.8), voxl_imu (= 0.0.4), voxl-time-sync (= 0.0.1), voxl-vpn (= 0.0.2), librc_math (= 1.1.2), libmodal_pipe (= 1.2.2), modalai-vl (= 0.1.3)
                Section: base
                Architecture: armv7a
                MD5Sum: af706cd3c1ea59f274f2ed9b93141f1d
                Filename: voxl-suite_0.2.0.ipk
                Description: meta-package to install all of the voxl-suite
                Installed-Time: 689
                  Just to show you what a working modem would look like:
                  / # voxl-modem --feather_configure
                      Setting defaults:
                      feather is DISABLED
                      feather is DISABLED
                      feather is DISABLED
                      feather is DISABLED
                      feather is ENABLED, device detected: /dev/ttyUSB0
                  It comes up within a few seconds. Good thought about qmi / dmesg, those errors will go away once the modem is powered up correctly by voxl-modem
                  • S Offline
                    S Offline
                    scottesicdrone
                    This makes a lot of sense. I have seen this working before but now it just says feather is DISABLED until it power cycles and repeats. So if I understand correctly, after a few seconds, /dev/ttyUSB0 will be created and then the feather is enabled? Also random question: what is a feather exactly? I haven't heard of this before and I tried to look into it but I'm still confused!
                      @scottesicdrone Haha okay so "feather" is a remnant from the days that the VOXL predecessor was a Qualcomm product. The nickname for the project at the time was "Eagle", therefore a "feather" was the nickname for an add-on board for the Eagle. So any reference to "feather" in voxl-modem is just talking about the modem add-on board. An example of one of the VOXL's predecessors is currently powering NASA's "Ingenuity" Drone on Mars (https://mars.nasa.gov/technology/helicopter/).
                      A little ModalAI lore for you that you won't find on Google 😉
                      • S Offline
                        S Offline
                        scottesicdrone
                        Love the Lore and good thing to note! Last last thing, here is the link to an instance of me running dmesg if that's of any use.
                        output here
                        I'm going to keep trying to figure this out because this is a time-sensitive situation but if we will know for sure if it's a hardware issue once we get another modem to test it on. Thanks for the help thus far! Anything else I should try on here?
                          @scottesicdrone Thanks! I am going to have another resource take a look at the issue and I will update you with our conclusion. I will message you if anything else is needed.
                          • S Offline
                            S Offline
                            scottesicdrone
                            Sounds good, thanks!
