    LTE Modem "Feather is Disabled"
    Cellular Modems
    1895
    • S
      scottesicdrone
      Hi Guys,
      I was working on setting up the LTE modem add-on with the VOXL. I configured the modem properly and even connected to our VPN, and used QGC on the VPN server. However, when I rebooted the VOXL and went through the process of connecting the modem using voxl-modem --connect_to_network, I wasn't able to connect and got this as output:
      Configuring GPIO pins
          Setting defaults:
              GPIO_PIN_WWAN_WAKEUP_IN  = 1
              GPIO_PIN_WWAN_POWER_ON_N = 1
              GPIO_PIN_WWAN_RESET_N    = 1
          feather is DISABLED
      ENABLE WNC feather module
          feather is DISABLED
          feather is DISABLED
          feather is DISABLED
          feather is DISABLED
          feather is DISABLED
          feather is DISABLED
          feather is DISABLED
          feather is DISABLED
          feather is DISABLED
          feather is DISABLED
          feather is DISABLED
          feather is DISABLED
          feather is DISABLED
          feather is DISABLED
          feather is DISABLED
          feather is DISABLED
          feather is DISABLED
          feather is DISABLED
          feather is DISABLED
          feather is DISABLED
      WARNING: feather state transtion failed.
         enable failed, try again 0 retries remaining
          feather is DISABLED
          feather is DISABLED
          feather is DISABLED
          feather is DISABLED
          feather is DISABLED
          feather is DISABLED
          feather is DISABLED
          feather is DISABLED
          feather is DISABLED
          feather is DISABLED
          feather is DISABLED
          feather is DISABLED
          feather is DISABLED
          feather is DISABLED
          feather is DISABLED
          feather is DISABLED
          feather is DISABLED
          feather is DISABLED
          feather is DISABLED
          feather is DISABLED
         enable failed, try again 1 retries remaining
          feather is DISABLED
          feather is DISABLED
          feather is DISABLED
          feather is DISABLED
          feather is DISABLED
          feather is DISABLED
      I know people previously have had this issue and the solution was that they improperly answered the voxl-configure-modem prompts. But I'm almost certain that this isn't the case because I was able to connect with no problems previously with no issues. What seems to be the problem from my view is that the devices /dev/ttyUSB0 and /dev/ttyACM0, which are supposedly the serial port and AT command port respectively, do not exist! I'm not sure if this is normal or if they are suppose to generate, but they do not show up when ls -la /dev is run:
      total 4
      drwxr-xr-x. 16 root   root          5660 Jan  1  1970 .
      drwxr-xr-x. 29 root   root          4096 Jan  1  1970 ..
      crw-rw-rw-.  1 root   root      224,   0 Jan  1  1970 adsprpc-smd
      crw-------.  1 root   root       10,  37 Jan  1  1970 android_mbim
      crw-------.  1 root   root       10,  28 Jan  1  1970 android_rndis_qc
      crw-------.  1 root   root      244,   3 Jan  1  1970 apr_apps2
      crw-------.  1 root   root       10,  53 Jan  1  1970 ashmem
      crw-------.  1 root   root      248,   0 Jan  1  1970 at_mdm0
      crw-------.  1 root   root      234,   0 Jan  1  1970 at_usb0
      crw-------.  1 root   root      234,   1 Jan  1  1970 at_usb1
      crw-------.  1 root   root      228,   0 Jan  1  1970 avtimer
      crw-------.  1 root   root       10,  56 Jan  1  1970 binder
      drwxr-xr-x.  3 root   root          1680 Jan  1  1970 block
      drwxr-xr-x.  2 root   root           220 Jan  1  1970 bsg
      drwxr-xr-x.  3 root   root            60 Jan  1  1970 bus
      crw-------.  1 root   root       10,  30 Jan  1  1970 ccid_bulk
      crw-------.  1 root   root       10,  31 Jan  1  1970 ccid_ctrl
      drwxr-xr-x.  2 root   root          4020 Jan  1  1970 char
      crw-------.  1 root   root        5,   1 Jan  1  1970 console
      crw-------.  1 root   root       10,  49 Jan  1  1970 coresight-stm
      crw-------.  1 root   root       10,  50 Jan  1  1970 coresight-tmc-etf
      crw-------.  1 root   root       10,  51 Jan  1  1970 coresight-tmc-etr
      crw-------.  1 root   root      227,   0 Jan  1  1970 coresight-tmc-etr-stream
      crw-------.  1 root   root       10,  43 Jan  1  1970 cpu_dma_latency
      crw-rw----.  1 root   diag      243,   0 Jan  1  1970 diag
      drwxr-xr-x.  8 root   root           160 Jan  1  1970 disk
      crw-------.  1 root   root       10,  32 Jan  1  1970 dpl_ctrl
      lrwxrwxrwx.  1 root   root            13 Jan  1  1970 fd -> /proc/self/fd
      crw-rw-rw-.  1 root   root        1,   7 Jan  1  1970 full
      crw-rw-rw-.  1 root   root       10, 229 Jan  1  1970 fuse
      crw-------.  1 root   root      248,   2 Jan  1  1970 glink_pkt_loopback
      crw-------.  1 root   root      248,   1 Jan  1  1970 glink_pkt_loopback_ctrl
      crw-------.  1 root   root       10,  59 Jan  1  1970 hbtp_input
      crw-------.  1 root   root       10,  58 Jan  1  1970 hbtp_vm
      crw-------.  1 root   root       10,  55 Jan  1  1970 hwbinder
      crw-------.  1 root   root       10, 183 Jan  1  1970 hwrng
      crw-------.  1 root   root      239,   0 Jan  1  1970 icesdcc
      crw-------.  1 root   root      240,   0 Jan  1  1970 iceufs
      lrwxrwxrwx.  1 root   root            25 Jan  1  1970 initctl -> /run/systemd/initctl/fifo
      drwxr-xr-x.  2 root   root           160 Jan  1  1970 input
      crw-rw-r--.  1 root   root       10,  94 Jan  1  1970 ion
      crw-------.  1 root   root      233,   0 Jan  1  1970 jpeg0
      crw-------.  1 root   root      232,   0 Jan  1  1970 jpeg2
      crw-------.  1 root   root      231,   0 Jan  1  1970 jpeg3
      crw-------.  1 root   root       10,  57 Jan  1  1970 keychord
      crw-------.  1 root   root      242,   0 Jan  1  1970 kgsl-3d0
      crw-r--r--.  1 root   root        1,  11 Jan  1  1970 kmsg
      lrwxrwxrwx.  1 root   root            28 Jan  1  1970 log -> /run/systemd/journal/dev-log
      crw-rw----.  1 root   disk       10, 237 Jan  1  1970 loop-control
      brw-rw----.  1 root   disk        7,   0 Jan  1  1970 loop0
      brw-rw----.  1 root   disk        7,   1 Jan  1  1970 loop1
      brw-rw----.  1 root   disk        7,   2 Jan  1  1970 loop2
      brw-rw----.  1 root   disk        7,   3 Jan  1  1970 loop3
      brw-rw----.  1 root   disk        7,   4 Jan  1  1970 loop4
      brw-rw----.  1 root   disk        7,   5 Jan  1  1970 loop5
      brw-rw----.  1 root   disk        7,   6 Jan  1  1970 loop6
      brw-rw----.  1 root   disk        7,   7 Jan  1  1970 loop7
      drwxr-xr-x.  2 root   root            60 Jan  1  1970 mapper
      crw-------.  1 root   root      224,   2 Jan  1  1970 mdsprpc-smd
      crw-------.  1 root   root      251,   0 Jan  1  1970 media0
      crw-------.  1 root   root      251,   1 Jan  1  1970 media1
      crw-------.  1 root   root      251,   2 Jan  1  1970 media2
      crw-------.  1 root   root      251,   3 Jan  1  1970 media3
      crw-------.  1 root   root       10,  40 Jan  1  1970 memory_bandwidth
      drwxrwxrwt.  2 root   root            40 Jan  1  1970 mqueue
      crw-------.  1 root   root      256,   0 Jan  1  1970 msm-rng
      crw-------.  1 root   root       10,  75 Jan  1  1970 msm_aac
      crw-------.  1 root   root       10,  83 Jan  1  1970 msm_aac_in
      crw-------.  1 root   root       10,  73 Jan  1  1970 msm_alac
      crw-------.  1 root   root       10,  68 Jan  1  1970 msm_amrnb
      crw-------.  1 root   root       10,  80 Jan  1  1970 msm_amrnb_in
      crw-------.  1 root   root       10,  67 Jan  1  1970 msm_amrwb
      crw-------.  1 root   root       10,  63 Jan  1  1970 msm_amrwb_in
      crw-------.  1 root   root       10,  66 Jan  1  1970 msm_amrwbplus
      crw-------.  1 root   root       10,  72 Jan  1  1970 msm_ape
      crw-------.  1 root   root       10,  93 Jan  1  1970 msm_audio_cal
      crw-------.  1 root   root       10,  65 Jan  1  1970 msm_evrc
      crw-------.  1 root   root       10,  81 Jan  1  1970 msm_evrc_in
      crw-------.  1 root   root       10,  70 Jan  1  1970 msm_g711alaw
      crw-------.  1 root   root       10,  78 Jan  1  1970 msm_g711alaw_in
      crw-------.  1 root   root       10,  71 Jan  1  1970 msm_g711mlaw
      crw-------.  1 root   root       10,  79 Jan  1  1970 msm_g711mlaw_in
      crw-------.  1 root   root       10,  62 Jan  1  1970 msm_hweffects
      crw-------.  1 root   root       10,  69 Jan  1  1970 msm_mp3
      crw-------.  1 root   root       10,  74 Jan  1  1970 msm_multi_aac
      crw-------.  1 root   root       10,  64 Jan  1  1970 msm_qcelp
      crw-------.  1 root   root       10,  82 Jan  1  1970 msm_qcelp_in
      crw-------.  1 root   root       10,  48 Jan  1  1970 msm_rtac
      crw-------.  1 root   root      254,   0 Jan  1  1970 msm_sps
      crw-------.  1 root   root      253,   0 Jan  1  1970 msm_thermal_query
      crw-------.  1 root   root       10,  77 Jan  1  1970 msm_wma
      crw-------.  1 root   root       10,  76 Jan  1  1970 msm_wmapro
      crw-------.  1 root   root       10,  29 Jan  1  1970 mtp_usb
      drwxr-xr-x.  2 root   root            60 Jan  1  1970 net
      crw-------.  1 root   root       10,  42 Jan  1  1970 network_latency
      crw-------.  1 root   root       10,  41 Jan  1  1970 network_throughput
      crw-rw-rw-.  1 root   root        1,   3 Jan  1  1970 null
      crw-------.  1 root   root      108,   0 Jan  1  1970 ppp
      crw-------.  1 root   root       10,   1 Jan  1  1970 psaux
      crw-------.  1 root   root       10,  26 Jan  1  1970 pta
      crw-rw-rw-.  1 root   tty         5,   2 Apr  2 16:31 ptmx
      drwxr-xr-x.  2 root   root             0 Jan  1  1970 pts
      crw-------.  1 root   root      247,   0 Jan  1  1970 qbt1000
      crw-------.  1 root   root       10,  60 Jan  1  1970 qce
      crw-------.  1 root   root      238,   0 Jan  1  1970 qcqmi0
      crw-------.  1 root   root      238,   1 Jan  1  1970 qcqmi1
      crw-------.  1 root   root      238,   2 Jan  1  1970 qcqmi2
      crw-------.  1 root   root      238,   3 Jan  1  1970 qcqmi3
      crw-rw-rw-.  1 root   root      241,   0 Jan  1  1970 qseecom
      brw-rw----.  1 root   disk        1,   0 Jan  1  1970 ram0
      brw-rw----.  1 root   disk        1,   1 Jan  1  1970 ram1
      brw-rw----.  1 root   disk        1,  10 Jan  1  1970 ram10
      brw-rw----.  1 root   disk        1,  11 Jan  1  1970 ram11
      brw-rw----.  1 root   disk        1,  12 Jan  1  1970 ram12
      brw-rw----.  1 root   disk        1,  13 Jan  1  1970 ram13
      brw-rw----.  1 root   disk        1,  14 Jan  1  1970 ram14
      brw-rw----.  1 root   disk        1,  15 Jan  1  1970 ram15
      brw-rw----.  1 root   disk        1,   2 Jan  1  1970 ram2
      brw-rw----.  1 root   disk        1,   3 Jan  1  1970 ram3
      brw-rw----.  1 root   disk        1,   4 Jan  1  1970 ram4
      brw-rw----.  1 root   disk        1,   5 Jan  1  1970 ram5
      brw-rw----.  1 root   disk        1,   6 Jan  1  1970 ram6
      brw-rw----.  1 root   disk        1,   7 Jan  1  1970 ram7
      brw-rw----.  1 root   disk        1,   8 Jan  1  1970 ram8
      brw-rw----.  1 root   disk        1,   9 Jan  1  1970 ram9
      crw-------.  1 root   root       10,  91 Jan  1  1970 ramdump_AR6320
      crw-------.  1 root   root       10,  85 Jan  1  1970 ramdump_a530_zap
      crw-------.  1 root   root       10,  46 Jan  1  1970 ramdump_adsp
      crw-------.  1 root   root       10,  38 Jan  1  1970 ramdump_adsp_rh
      crw-------.  1 root   root       10,  87 Jan  1  1970 ramdump_memshare_DIAG
      crw-------.  1 root   root       10,  88 Jan  1  1970 ramdump_memshare_FTM
      crw-------.  1 root   root       10,  89 Jan  1  1970 ramdump_memshare_GPS
      crw-------.  1 root   root       10,  44 Jan  1  1970 ramdump_modem
      crw-------.  1 root   root       10,  45 Jan  1  1970 ramdump_slpi
      crw-------.  1 root   root       10,  39 Jan  1  1970 ramdump_smem
      crw-------.  1 root   root       10,  86 Jan  1  1970 ramdump_venus
      crw-rw-rw-.  1 root   root        1,   8 Jan  1  1970 random
      prw--w----.  1 root   rebooters        0 Jan  1  1970 rebooterdev
      crw-rw-r--.  1 root   root       10,  92 Jan  1  1970 rfkill
      crw-------.  1 root   root       10,  36 Jan  1  1970 rmnet_ctrl
      crw-------.  1 root   root       10,  35 Jan  1  1970 rmnet_ctrl1
      crw-------.  1 root   root       10,  34 Jan  1  1970 rmnet_ctrl2
      crw-------.  1 root   root       10,  33 Jan  1  1970 rmnet_ctrl3
      lrwxrwxrwx.  1 root   root             4 Jan  1  1970 rtc -> rtc0
      crw-------.  1 root   root      252,   0 Jan  1  1970 rtc0
      brw-rw----.  1 root   disk        8,   0 Jan  1  1970 sda
      brw-rw----.  1 root   disk        8,   1 Jan  1  1970 sda1
      brw-rw----.  1 root   disk        8,   2 Jan  1  1970 sda2
      brw-rw----.  1 root   disk        8,   3 Jan  1  1970 sda3
      brw-rw----.  1 root   disk        8,   4 Jan  1  1970 sda4
      brw-rw----.  1 root   disk        8,   5 Jan  1  1970 sda5
      brw-rw----.  1 root   disk        8,   6 Jan  1  1970 sda6
      brw-rw----.  1 root   disk        8,   7 Jan  1  1970 sda7
      brw-rw----.  1 root   disk        8,   8 Jan  1  1970 sda8
      brw-rw----.  1 root   disk        8,   9 Jan  1  1970 sda9
      brw-rw----.  1 root   disk        8,  16 Jan  1  1970 sdb
      brw-rw----.  1 root   disk        8,  17 Jan  1  1970 sdb1
      brw-rw----.  1 root   disk        8,  32 Jan  1  1970 sdc
      brw-rw----.  1 root   disk        8,  33 Jan  1  1970 sdc1
      brw-rw----.  1 root   disk        8,  48 Jan  1  1970 sdd
      brw-rw----.  1 root   disk        8,  49 Jan  1  1970 sdd1
      brw-rw----.  1 root   disk        8,  50 Jan  1  1970 sdd2
      brw-rw----.  1 root   disk        8,  51 Jan  1  1970 sdd3
      brw-rw----.  1 root   disk        8,  64 Jan  1  1970 sde
      brw-rw----.  1 root   disk        8,  65 Jan  1  1970 sde1
      brw-rw----.  1 root   disk        8,  74 Jan  1  1970 sde10
      brw-rw----.  1 root   disk        8,  75 Jan  1  1970 sde11
      brw-rw----.  1 root   disk        8,  76 Jan  1  1970 sde12
      brw-rw----.  1 root   disk        8,  77 Jan  1  1970 sde13
      brw-rw----.  1 root   disk        8,  78 Jan  1  1970 sde14
      brw-rw----.  1 root   disk        8,  79 Jan  1  1970 sde15
      brw-rw----.  1 root   disk      259,   0 Jan  1  1970 sde16
      brw-rw----.  1 root   disk      259,   1 Jan  1  1970 sde17
      brw-rw----.  1 root   disk      259,   2 Jan  1  1970 sde18
      brw-rw----.  1 root   disk      259,   3 Jan  1  1970 sde19
      brw-rw----.  1 root   disk        8,  66 Jan  1  1970 sde2
      brw-rw-r--.  1 root   disk      259,   4 Jan  1  1970 sde20
      brw-rw----.  1 root   disk      259,   5 Jan  1  1970 sde21
      brw-rw----.  1 root   disk      259,   6 Jan  1  1970 sde22
      brw-rw----.  1 root   disk      259,   7 Jan  1  1970 sde23
      brw-rw----.  1 root   disk      259,   8 Jan  1  1970 sde24
      brw-rw----.  1 root   disk      259,   9 Jan  1  1970 sde25
      brw-rw----.  1 root   disk      259,  10 Jan  1  1970 sde26
      brw-rw----.  1 root   disk      259,  11 Jan  1  1970 sde27
      brw-rw----.  1 root   disk      259,  12 Jan  1  1970 sde28
      brw-rw----.  1 root   disk      259,  13 Jan  1  1970 sde29
      brw-rw----.  1 root   disk        8,  67 Jan  1  1970 sde3
      brw-rw----.  1 root   disk      259,  14 Jan  1  1970 sde30
      brw-rw----.  1 root   disk      259,  15 Jan  1  1970 sde31
      brw-rw----.  1 root   disk      259,  16 Jan  1  1970 sde32
      brw-rw----.  1 root   disk      259,  17 Jan  1  1970 sde33
      brw-rw----.  1 root   disk        8,  68 Jan  1  1970 sde4
      brw-rw----.  1 root   disk        8,  69 Jan  1  1970 sde5
      brw-rw----.  1 root   disk        8,  70 Jan  1  1970 sde6
      brw-rw----.  1 root   disk        8,  71 Jan  1  1970 sde7
      brw-rw----.  1 root   disk        8,  72 Jan  1  1970 sde8
      brw-rw----.  1 root   disk        8,  73 Jan  1  1970 sde9
      brw-rw----.  1 root   disk        8,  80 Jan  1  1970 sdf
      brw-rw----.  1 root   disk        8,  81 Jan  1  1970 sdf1
      brw-rw----.  1 root   disk        8,  82 Jan  1  1970 sdf2
      brw-rw----.  1 root   disk        8,  83 Jan  1  1970 sdf3
      crw-------.  1 root   root      224,   1 Jan  1  1970 sdsprpc-smd
      crw-------.  1 root   root      229,   0 Jan  1  1970 seemplog
      crw-------.  1 root   root      225,   0 Jan  1  1970 sensors
      crw-------.  1 root   root       21,   0 Jan  1  1970 sg0
      crw-------.  1 root   root       21,   1 Jan  1  1970 sg1
      crw-------.  1 system system     21,   2 Jan  1  1970 sg2
      crw-rw----.  1 root   disk       21,   3 Jan  1  1970 sg3
      crw-rw----.  1 root   disk       21,   4 Jan  1  1970 sg4
      crw-rw----.  1 root   disk       21,   5 Jan  1  1970 sg5
      crw-rw----.  1 root   disk       21,   6 Jan  1  1970 sg6
      crw-rw----.  1 root   disk       21,   7 Jan  1  1970 sg7
      crw-rw----.  1 root   disk       21,   8 Jan  1  1970 sg8
      drwxrwxrwt.  2 root   root            40 Jan  1  1970 shm
      crw-------.  1 root   root       10,  84 Jan  1  1970 smcinvoke
      crw-------.  1 root   root      245,  11 Jan  1  1970 smd11
      crw-------.  1 root   root      245,  21 Jan  1  1970 smd21
      crw-------.  1 root   root      244,   1 Jan  1  1970 smd22
      crw-------.  1 root   root      245,  36 Jan  1  1970 smd36
      crw-------.  1 root   root      245,   7 Jan  1  1970 smd7
      crw-------.  1 root   root      245,   8 Jan  1  1970 smd8
      crw-------.  1 root   root      244,   4 Jan  1  1970 smd_pkt_loopback
      crw-------.  1 root   root      244,   0 Jan  1  1970 smdcntl0
      crw-------.  1 root   root      244,   2 Jan  1  1970 smdcntl8
      crw-------.  1 root   root       10,  90 Jan  1  1970 smem_log
      drwxr-xr-x.  2 root   root            60 Jan  1  1970 snd
      drwxrwxrwx.  2 root   root           200 Jan  1  1970 socket
      lrwxrwxrwx.  1 root   root            15 Jan  1  1970 stderr -> /proc/self/fd/2
      lrwxrwxrwx.  1 root   root            15 Jan  1  1970 stdin -> /proc/self/fd/0
      lrwxrwxrwx.  1 root   root            15 Jan  1  1970 stdout -> /proc/self/fd/1
      crw-------.  1 root   root      250,   0 Jan  1  1970 subsys_AR6320
      crw-------.  1 root   root      250,   2 Jan  1  1970 subsys_a530_zap
      crw-------.  1 root   root      250,   3 Jan  1  1970 subsys_adsp
      crw-------.  1 root   root      250,   5 Jan  1  1970 subsys_modem
      crw-------.  1 root   root      250,   4 Jan  1  1970 subsys_slpi
      crw-------.  1 root   root      250,   1 Jan  1  1970 subsys_venus
      crw-------.  1 root   root       10,  52 Jan  1  1970 sw_sync
      crw-rw-rw-.  1 root   tty         5,   0 Jan  1  1970 tty
      crw-rw----.  1 root   dialout   246,   0 Jan  1  1970 ttyHS0
      crw-------.  1 root   root       10, 239 Jan  1  1970 uhid
      crw-------.  1 root   root       10, 223 Jan  1  1970 uinput
      crw-------.  1 root   root      237,   0 Jan  1  1970 uio0
      crw-------.  1 root   root      237,   1 Jan  1  1970 uio1
      crw-------.  1 root   root      237,   2 Jan  1  1970 uio2
      crw-rw-rw-.  1 root   root        1,   9 Jan  1  1970 urandom
      drwxr-xr-x.  3 root   root            60 Jan  1  1970 usb-ffs
      crw-------.  1 root   root       10,  27 Jan  1  1970 usb_accessory
      crw-------.  1 root   root      236,   0 Jan  1  1970 usbmon0
      crw-------.  1 root   root      236,   1 Jan  1  1970 usbmon1
      crw-------.  1 root   root      236,   2 Jan  1  1970 usbmon2
      crw-------.  1 root   root       10,  61 Jan  1  1970 usf1
      crw-rw----.  1 root   video      81,   3 Jan  1  1970 v4l-subdev0
      crw-rw----.  1 root   video      81,   4 Jan  1  1970 v4l-subdev1
      crw-rw----.  1 root   video      81,  13 Jan  1  1970 v4l-subdev10
      crw-rw----.  1 root   video      81,  14 Jan  1  1970 v4l-subdev11
      crw-rw----.  1 root   video      81,  15 Jan  1  1970 v4l-subdev12
      crw-rw----.  1 root   video      81,  16 Jan  1  1970 v4l-subdev13
      crw-rw----.  1 root   video      81,  17 Jan  1  1970 v4l-subdev14
      crw-rw----.  1 root   video      81,  18 Jan  1  1970 v4l-subdev15
      crw-rw----.  1 root   video      81,  21 Jan  1  1970 v4l-subdev16
      crw-rw----.  1 root   video      81,  23 Jan  1  1970 v4l-subdev17
      crw-rw----.  1 root   video      81,  24 Jan  1  1970 v4l-subdev18
      crw-rw----.  1 root   video      81,  26 Jan  1  1970 v4l-subdev19
      crw-rw----.  1 root   video      81,   5 Jan  1  1970 v4l-subdev2
      crw-rw----.  1 root   video      81,   6 Jan  1  1970 v4l-subdev3
      crw-rw----.  1 root   video      81,   7 Jan  1  1970 v4l-subdev4
      crw-rw----.  1 root   video      81,   8 Jan  1  1970 v4l-subdev5
      crw-rw----.  1 root   video      81,   9 Jan  1  1970 v4l-subdev6
      crw-rw----.  1 root   video      81,  10 Jan  1  1970 v4l-subdev7
      crw-rw----.  1 root   video      81,  11 Jan  1  1970 v4l-subdev8
      crw-rw----.  1 root   video      81,  12 Jan  1  1970 v4l-subdev9
      crw-------.  1 root   root       10,  95 Jan  1  1970 vga_arbiter
      crw-rw----.  1 root   video      81,   2 Jan  1  1970 video0
      crw-rw----.  1 root   video      81,  19 Jan  1  1970 video1
      crw-rw----.  1 root   video      81,  20 Jan  1  1970 video2
      crw-rw----.  1 root   video      81,  22 Jan  1  1970 video3
      crw-rw----.  1 root   video      81,   0 Jan  1  1970 video32
      crw-rw----.  1 root   video      81,   1 Jan  1  1970 video33
      crw-rw----.  1 root   video      81,  25 Jan  1  1970 video4
      crw-------.  1 root   root       10,  54 Jan  1  1970 vndbinder
      crw-------.  1 root   root       10,  47 Jan  1  1970 xt_qtaguid
      crw-rw-rw-.  1 root   root        1,   5 Jan  1  1970 zero
      brw-rw----.  1 root   disk      253,   0 Jan  1  1970 zram0
      Some more useful info for debugging this (I ran this with the modem in):
      yocto:/# lsusb -v
      Device Descriptor:
        bLength                18
        bDescriptorType         1
        bcdUSB               3.00
        bDeviceClass            9 Hub
        bDeviceSubClass         0
        bDeviceProtocol         3
        bMaxPacketSize0         9
        idVendor           0x1d6b Linux Foundation
        idProduct          0x0003 3.0 root hub
        bcdDevice            3.18
        iManufacturer           3 Linux 3.18.71-perf xhci-hcd
        iProduct                2 xHCI Host Controller
        iSerial                 1 xhci-hcd.0.auto
        bNumConfigurations      1
        Configuration Descriptor:
          bLength                 9
          bDescriptorType         2
          wTotalLength           31
          bNumInterfaces          1
          bConfigurationValue     1
          iConfiguration          0
          bmAttributes         0xe0
            Self Powered
            Remote Wakeup
          MaxPower                0mA
          Interface Descriptor:
            bLength                 9
            bDescriptorType         4
            bInterfaceNumber        0
            bAlternateSetting       0
            bNumEndpoints           1
            bInterfaceClass         9 Hub
            bInterfaceSubClass      0
            bInterfaceProtocol      0 Full speed (or root) hub
            iInterface              0
            Endpoint Descriptor:
              bLength                 7
              bDescriptorType         5
              bEndpointAddress     0x81  EP 1 IN
              bmAttributes            3
                Transfer Type            Interrupt
                Synch Type               None
                Usage Type               Data
              wMaxPacketSize     0x0004  1x 4 bytes
              bInterval              12
              bMaxBurst               0
      Hub Descriptor:
        bLength              12
        bDescriptorType      42
        nNbrPorts             0
        wHubCharacteristic 0x000a
          No power switching (usb 1.0)
          Per-port overcurrent protection
        bPwrOn2PwrGood       10 * 2 milli seconds
        bHubContrCurrent      0 milli Ampere
        bHubDecLat          0.0 micro seconds
        wHubDelay             0 nano seconds
        DeviceRemovable    0x00
       Hub Port Status:
      Binary Object Store Descriptor:
        bLength                 5
        bDescriptorType        15
        wTotalLength           15
        bNumDeviceCaps          1
        SuperSpeed USB Device Capability:
          bLength                10
          bDescriptorType        16
          bDevCapabilityType      3
          bmAttributes         0x02
            Latency Tolerance Messages (LTM) Supported
          wSpeedsSupported   0x0008
            Device can operate at SuperSpeed (5Gbps)
          bFunctionalitySupport   3
            Lowest fully-functional device speed is SuperSpeed (5Gbps)
          bU1DevExitLat           0 micro seconds
          bU2DevExitLat           0 micro seconds
      can't get debug descriptor: Resource temporarily unavailable
      Device Status:     0x0001
        Self Powered
      Bus 001 Device 002: ID 0424:2514 Standard Microsystems Corp. USB 2.0 Hub
      Device Descriptor:
        bLength                18
        bDescriptorType         1
        bcdUSB               2.00
        bDeviceClass            9 Hub
        bDeviceSubClass         0
        bDeviceProtocol         2 TT per port
        bMaxPacketSize0        64
        idVendor           0x0424 Standard Microsystems Corp.
        idProduct          0x2514 USB 2.0 Hub
        bcdDevice            b.b3
        iManufacturer           0
        iProduct                0
        iSerial                 0
          bLength                 9
          bDescriptorType         2
          wTotalLength           41
          bNumInterfaces          1
          iConfiguration          0
          bmAttributes         0xe0
            Self Powered
            Remote Wakeup
          MaxPower                2mA
            bLength                 9
            bDescriptorType         4
            bInterfaceNumber        0
            bAlternateSetting       0
            bNumEndpoints           1
            bInterfaceProtocol      1 Single TT
            iInterface              0
              bLength                 7
              bDescriptorType         5
              bmAttributes            3
                Synch Type               None
                Usage Type               Data
              wMaxPacketSize     0x0001  1x 1 bytes
              bInterval              12
            bLength                 9
            bDescriptorType         4
            bInterfaceNumber        0
            bAlternateSetting       1
            bNumEndpoints           1
            bInterfaceProtocol      2 TT per port
            iInterface              0
              bLength                 7
              bDescriptorType         5
              bmAttributes            3
                Synch Type               None
                Usage Type               Data
              bInterval              12
      Hub Descriptor:
        bLength               9
        bDescriptorType      41
        nNbrPorts             3
        wHubCharacteristic 0x0009
          Per-port power switching
          TT think time 8 FS bits
        bPwrOn2PwrGood       50 * 2 milli seconds
        bHubContrCurrent      1 milli Ampere
        PortPwrCtrlMask    0xff
       Hub Port Status:
         Port 1: 0000.0100 power
         Port 2: 0000.0100 power
         Port 3: 0000.0100 power
      Device Qualifier (for other device speed):
        bLength                10
        bDescriptorType         6
        bcdUSB               2.00
        bDeviceClass            9 Hub
        bDeviceSubClass         0
        bDeviceProtocol         0 Full speed (or root) hub
        bMaxPacketSize0        64
        Self Powered
      Device Descriptor:
        bLength                18
        bDescriptorType         1
        bcdUSB               2.00
        bDeviceClass            9 Hub
        bDeviceSubClass         0
        bDeviceProtocol         1 Single TT
        bMaxPacketSize0        64
        idProduct          0x0002 2.0 root hub
        bcdDevice            3.18
          bLength                 9
          bDescriptorType         2
          wTotalLength           25
          bNumInterfaces          1
          iConfiguration          0
          bmAttributes         0xe0
            Self Powered
            Remote Wakeup
          MaxPower                0mA
            bLength                 9
            bDescriptorType         4
            bInterfaceNumber        0
            bAlternateSetting       0
            bNumEndpoints           1
            iInterface              0
              bLength                 7
              bDescriptorType         5
              bmAttributes            3
                Synch Type               None
                Usage Type               Data
              bInterval              12
      Hub Descriptor:
        bLength               9
        bDescriptorType      41
        nNbrPorts             1
       Hub Port Status:
         Port 1: 0000.0507 highspeed power suspend enable connect
      can't get device qualifier: Resource temporarily unavailable
        Self Powered
      The last thing to note is that all the lights on the modem seem to be on, even the WWAN light when trying to run voxl-modem. Any help on this as soon as possible would be greatly appreciated!
        tom admin
        Hi @scottesicdrone ,
        Just to make sure I understand your setup, are you using a v1 modem or v2 modem?
        Another question, did you previously run voxl-configure-modem? If so there will be a service running in the background on boot attempting to connect to the LTE network.
        You can check the status of this service by running systemctl status -l voxl-modem
        • S
          scottesicdrone
          Thanks for the quick response! We are using a v1 modem.
          We ran voxl-configure-modem previously so that definitely could be the case. Here is the output for systemctl status -l voxl-modem:
          yocto:/# systemctl status -l voxl-modem
          ● voxl-modem.service - Modem Initialization
             Loaded: loaded (/etc/systemd/system/voxl-modem.service; enabled; vendor preset: enabled)
             Active: active (running) since Thu 1970-01-01 00:00:08 UTC; 51 years 3 months ago
            Process: 2041 ExecStartPre=/bin/sleep 2 (code=exited, status=0/SUCCESS)
           Main PID: 2824 (voxl-modem-star)
             CGroup: /system.slice/voxl-modem.service
                     ├─2824 /bin/bash /usr/bin/voxl-modem-start.sh
                     └─2907 /usr/bin/python /usr/bin/voxl-modem --feather_configure
          Jan 01 00:00:06 apq8096 systemd[1]: Starting Modem Initialization...
          Jan 01 00:00:08 apq8096 systemd[1]: Started Modem Initialization.
          Jan 01 00:00:09 apq8096 voxl-modem-start.sh[2824]: Initializing v1 modem...
          Should I disable this service and try configuring and connecting?
            tom admin
            @scottesicdrone Okay great, if you went through the setup using voxl-configure-modem then you shouldn't need to run anything manually. Can I also see what your voxl-modem config file looks like: /etc/modalai/voxl-modem.conf? As a next step I would try rebooting and monitoring the status of the voxl-modem service with watch systemctl status -l voxl-modem.
            • S
              scottesicdrone
              Here is my voxl-modem.conf file:
              	"modem_type":	"v1",
              	"apn":	"broadband",
              	"world":	"false",
              	"microhard_ip": "192.168.168.100",
              	"modallink":	"false",
              	"placeholder": "hello world"
              I'm watching the service right now and here is where it is at currently
                 Active: active (running) since Thu 1970-01-01 00:01:23 UTC; 51 years 3 months ago
                Process: 2129 ExecStartPre=/bin/sleep 2 (code=exited, status=0/SUCCESS)
               Main PID: 2853 (voxl-modem-star)
                         ├─2853 /bin/bash /usr/bin/voxl-modem-start.sh
                         └─3364 /usr/bin/python /usr/bin/voxl-modem --connect_to_network
              Apr 02 17:13:49 apq8096 voxl-modem-start.sh[2853]: Setting network preference to LTE
              Apr 02 17:13:59 apq8096 voxl-modem-start.sh[2853]: Failed to open device
              Apr 02 17:13:59 apq8096 voxl-modem-start.sh[2853]: Finished setting network preference
              Apr 02 17:13:59 apq8096 voxl-modem-start.sh[2853]: Disabling band 5...
              Apr 02 17:13:59 apq8096 voxl-modem-start.sh[2853]: configband starting
              Apr 02 17:13:59 apq8096 voxl-modem-start.sh[2853]: Band mask 1 to 32: 0x0000080a 0x0a 0x08 0x00 0x00
              Apr 02 17:13:59 apq8096 voxl-modem-start.sh[2853]: Band mask 33 to 64: 0x00000000 0x00 0x00 0x00 0x00
              Apr 02 17:13:59 apq8096 voxl-modem-start.sh[2853]: Band mask 65 to 96: 0x00000000 0x00 0x00 0x00 0x00
              Apr 02 17:13:59 apq8096 voxl-modem-start.sh[2853]: Error opening /dev/ttyUSB0: No such file or directory
              Apr 02 17:13:59 apq8096 voxl-modem-start.sh[2853]: Initalizing cellular connection...
                tom admin
                @scottesicdrone Okay let's have you go through the steps manually to see if it's a timing issue.
                First, disable the voxl-modem service -> systemctl disable voxl-modem and reboot.
                Now, run the following:
                voxl-modem --feather_configure -> this should bring up /dev/qcqmi0 and /dev/ttyUSB0, make sure these exist before proceeding
                Next, run:
                uqmi -P -d /dev/qcqmi0 --set-network-preference lte
                then
                configband write /dev/ttyUSB0 0x80a
                Lastly, run
                voxl-modem --conect_to_network
                • S
                  scottesicdrone
                  I disabled the service and ran voxl-modem --feather_configure and got this:
                      Setting defaults:
                      feather is DISABLED
                      feather is DISABLED
                      feather is DISABLED
                      feather is DISABLED
                      feather is DISABLED
                      feather is DISABLED
                      feather is DISABLED
                      feather is DISABLED
                      feather is DISABLED
                      feather is DISABLED
                      feather is DISABLED
                      feather is DISABLED
                      feather is DISABLED
                      feather is DISABLED
                      feather is DISABLED
                      feather is DISABLED
                      feather is DISABLED
                      feather is DISABLED
                      feather is DISABLED
                      feather is DISABLED
                      feather is DISABLED
                      feather is DISABLED
                      feather is DISABLED
                      feather is DISABLED
                      feather is DISABLED
                      feather is DISABLED
                      feather is DISABLED
                      feather is DISABLED
                      feather is DISABLED
                      feather is DISABLED
                      feather is DISABLED
                      feather is DISABLED
                      feather is DISABLED
                      feather is DISABLED
                      feather is DISABLED
                      feather is DISABLED
                      feather is DISABLED
                      feather is DISABLED
                      feather is DISABLED
                      feather is DISABLED
                      feather is DISABLED
                      feather is DISABLED
                      feather is DISABLED
                  And this will keep going if I let it, I'm pretty sure. In the /dev folder, /dev/qcqmi0 exists but /dev/ttyUSB0 doesn't exist.
                    tom admin
                    @scottesicdrone Thanks for the info, I will look into this behavior in order to get a solution for you
                    • S
                      scottesicdrone
                      Thanks, Tom, for the help! I really appreciate it! Is it possible that the serial port and the ports got renamed from /dev/ttyACM0 and /dev/ttyUSB0? I'm not too familiar with how these devices are generated or normal behavior for these devices. We have also noticed that this happened on two different VOXLs with the same v1 modem, so this problem seems to be with the modem and not the VOXL (though this is not something I am 100% certain about).
                        tom admin
                        @scottesicdrone I'm leaning toward it being a hardware issue with your modem. Did anything hardware related change from when it was working and wasn't working? Do you have any other v1 modems you can test with?
                        • S
                          scottesicdrone
                          Nothing physically changed that I can recall, and unfortunately, we don't have extra modems though we ordered more modems. Last potential useful bit of info: when I ran dmesg, I saw errors relating to qmi pop up but I don't know what to make of them:
                          yocto:/# dmesg | grep "qmi"
                          [    1.186410] usbcore: registered new interface driver qmi_wwan
                          [    1.187419] msm_sharedmem: sharedmem_register_qmi: qmi init successful
                          [    5.741357] sysmon_send_event_no_qmi: Message sending failed -19
                          [    5.890086] type=1130 audit(7.556:61): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0-s15:c0.c1023 msg='unit=qmi_shutdown_modemd comm="systemd" exe="/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
                          [    5.903844] sysmon_send_event_no_qmi: Message sending failed -19
                          [    5.903850] sysmon_send_event_no_qmi: Message sending failed -19
                          [    5.908564] sysmon-qmi: sysmon_clnt_svc_arrive: Connection established between QMI handle and slpi's SSCTL service
                          [    5.914578] sysmon_send_event_no_qmi: Message sending failed -19
                          [    6.039513] sysmon-qmi: sysmon_clnt_svc_arrive: Connection established between QMI handle and adsp's SSCTL service
                          [    6.523379] sysmon-qmi: sysmon_clnt_svc_arrive: Connection established between QMI handle and modem's SSCTL service
                          [    6.543970] msm_slim_qmi_send_power_request: QMI request failed 0x1 (Unknown error)
                          [    7.045169] msm_slim_qmi_send_power_request: QMI request failed 0x1 (Unknown error)
                          [    7.546548] msm_slim_qmi_send_power_request: QMI request failed 0x1 (Unknown error)
                          [    8.049225] msm_slim_qmi_send_power_request: QMI request failed 0x1 (Unknown error)
                            tom admin
                            Can you also run voxl-version so I can see what system image / package version you're using.
                            • S
                              scottesicdrone
                              Here is what I get when I run voxl-version:
                              yocto:/# voxl-version
                              system-image:    ModalAI 3.1.0 BUILDER: ekatzfey BUILD_TIME: 2020-12-23_19:41
                              kernel:          #1 SMP PREEMPT Wed Dec 23 19:50:23 UTC 2020 3.18.71-perf
                              factory-bundle:  1.0.1 (Yocto installation)
                              architecture:    aarch64
                              processor:       apq8096
                              os:              GNU/Linux
                              voxl-suite:
                              Package: voxl-suite
                              Version: 0.3.4
                              Depends: voxl-utils (>= 0.6.0), libmodal_json (>= 0.3.4), libmodal_pipe (>= 1.7.8), librc_math (>= 1.1.4), libvoxl_io (>= 0.5.4), mavlink-camera-manager (>= 0.0.1), opencv (>= 4.5.1), openmp (>= 10.0.1), voxl-camera-server (>= 0.5.6), voxl-dfs-server (>= 0.0.7), voxl-docker-support (>= 1.1.1), voxl-gphoto2 (>= 0.0.5), voxl-hal3-tof-cam-ros (>= 0.0.5), voxl-imu-server (>= 0.7.8), voxl-modem (>= 0.11.0), voxl-mpa-tflite-server (>= 0.0.2), voxl-mpa-tools (>= 0.1.6), voxl-nodes (>= 0.1.3), voxl-qvio-server (>= 0.2.1), voxl-rtsp (>= 1.0.3), voxl-streamer (>= 0.2.1), voxl-vision-px4 (>= 0.8.1), voxl-vpn (>= 0.0.3)
                              Section: base
                              Architecture: all
                              Maintainer: james@modalai.com
                              MD5Sum: e1e5bf1a125affe5036099f6ce895bed
                              Filename: voxl-suite_0.3.4.ipk
                              Description: meta-package for voxl-suite stable release
                              Package: voxl-suite
                              Version: 0.2.0
                              Depends: docker, imu_app (= 0.0.6), libvoxl_io (= 0.5.2), voxl-cam-manager (= 0.2.2), voxl-docker-support (= 1.1.1), voxl-hal3-tof-cam-ros (= 0.0.2), voxl-modem (= 0.10.0), voxl-nodes (= 0.0.8), voxl-rtsp (= 1.0.2), voxl-utils (= 0.5.2), voxl-vision-px4 (= 0.6.8), voxl_imu (= 0.0.4), voxl-time-sync (= 0.0.1), voxl-vpn (= 0.0.2), librc_math (= 1.1.2), libmodal_pipe (= 1.2.2), modalai-vl (= 0.1.3)
                              Section: base
                              Architecture: armv7a
                              MD5Sum: af706cd3c1ea59f274f2ed9b93141f1d
                              Filename: voxl-suite_0.2.0.ipk
                              Description: meta-package to install all of the voxl-suite
                              Installed-Time: 689
                                tom admin
                                Just to show you what a working modem would look like:
                                / # voxl-modem --feather_configure
                                    Setting defaults:
                                    feather is DISABLED
                                    feather is DISABLED
                                    feather is DISABLED
                                    feather is DISABLED
                                    feather is ENABLED, device detected: /dev/ttyUSB0
                                It comes up within a few seconds. Good thought about qmi / dmesg, those errors will go away once the modem is powered up correctly by voxl-modem
                                • S
                                  scottesicdrone
                                  This makes a lot of sense. I have seen this working before but now it just says feather is DISABLED until it power cycles and repeats. So if I understand correctly, after a few seconds, /dev/ttyUSB0 will be created and then the feather is enabled? Also random question: what is a feather exactly? I haven't heard of this before and I tried to look into it but I'm still confused!
                                    tom admin
                                    @scottesicdrone Haha okay so "feather" is a remnant from the days that the VOXL predecessor was a Qualcomm product. The nickname for the project at the time was "Eagle", therefore a "feather" was the nickname for an add-on board for the Eagle. So any reference to "feather" in voxl-modem is just talking about the modem add-on board. An example of one of the VOXL's predecessors is currently powering NASA's "Ingenuity" Drone on Mars (https://mars.nasa.gov/technology/helicopter/).
                                    A little ModalAI lore for you that you won't find on Google 😉
                                    • S
                                      scottesicdrone
                                      Love the Lore and good thing to note! Last last thing, here is the link to an instance of me running dmesg if that's of any use.
                                      output here
                                      I'm going to keep trying to figure this out because this is a time-sensitive situation but if we will know for sure if it's a hardware issue once we get another modem to test it on. Thanks for the help thus far! Anything else I should try on here?
                                        tom admin
                                        @scottesicdrone Thanks! I am going to have another resource take a look at the issue and I will update you with our conclusion. I will message you if anything else is needed.
                                        • S
                                          scottesicdrone
                                          Sounds good, thanks!
