Voxl 2 DFS Server
How do you tell the DFS server that you only have one pair of stereo cameras. At no point when you run vox-dfs-configure does it ask you about your setup, and when I go to /etc/modalai/voxl-dfs-server.conf and manually get rid of one pair and change the extrinsics and intrinsics paths and save, running the server just reverts that file to have a "front" and "rear" pair. I've also tried editing this file, running the configurator, and selecting "no" when asking if I want to reset to factory defaults, and it still overwrites my changes in that file... What factors/scripts affect the generation of that conf file?
If the software thinks the file is corrupted, it will reset to defaults.
- What are the exact steps you are trying? Are you calling any other configure after you edit the file?
- What symptom are you trying to fix if two stereo pair are configured?
- Do you have two stereo pair plugged in?
@Chad-Sweet first if I try to run voxl-dfs-server as is, I get the following,
================================================================= min_disparity: 4 max_disparity: 64 min_threshold: 10 cost_threshold: 10 width: 640 height: 480 pc_skip_n_lines: 4 dfs pair #0 enable: 1 input_pipe: stereo_front skip_n_frames: 1 blur_size: 0 post_median_size: 0 intrinsics_file: /data/modalai/opencv_stereo_front_intrinsics.yml extrinsics_file: /data/modalai/opencv_stereo_front_extrinsics.yml dfs pair #1 enable: 1 input_pipe: stereo_rear skip_n_frames: 1 blur_size: 0 post_median_size: 0 intrinsics_file: /data/modalai/opencv_stereo_rear_intrinsics.yml extrinsics_file: /data/modalai/opencv_stereo_rear_extrinsics.yml ================================================================= loading calibration files ERROR: Failed to open calibration file: /data/modalai/opencv_stereo_front_intrinsics.ymlAnd it fails because its looking for "stereo_front" and "stereo_rear" but I only have one pair that in the pipe is just "stereo". So I then go to etc/modalai/voxl-dfs-server.conf which currently looks like this (I'll exclude the comments in this file)
{ "skip_n_frames": 5, "n_disparity_levels": 48, "sobel_cutoff": 5, "first_median_filter_size": 17, "en_second_median_filter": true, "second_median_filter_size": 7, "min_disparity": 4, "max_disparity": 64, "min_threshold": 10, "cost_threshold": 10, "width": 640, "height": 480, "pc_skip_n_lines": 4, "dfs_pair_0": { "enable": true, "input_pipe": "stereo_front", "skip_n_frames": 1, "blur_size": 0, "post_median_size": 0, "intrinsics_file": "/data/modalai/opencv_stereo_front_intrinsics.yml", "extrinsics_file": "/data/modalai/opencv_stereo_front_extrinsics.yml" }, "dfs_pair_1": { "enable": true, "input_pipe": "stereo_rear", "skip_n_frames": 1, "blur_size": 0, "post_median_size": 0, "intrinsics_file": "/data/modalai/opencv_stereo_rear_intrinsics.yml", "extrinsics_file": "/data/modalai/opencv_stereo_rear_extrinsics.yml" } }and remove the "rear" stereo and then edit the front stereo to just be "stereo", and save it to looks like the following
{ "skip_n_frames": 5, "n_disparity_levels": 48, "sobel_cutoff": 5, "first_median_filter_size": 17, "en_second_median_filter": true, "second_median_filter_size": 7, "min_disparity": 4, "max_disparity": 64, "min_threshold": 10, "cost_threshold": 10, "width": 640, "height": 480, "pc_skip_n_lines": 4, "dfs_pair_0": { "enable": true, "input_pipe": "stereo", "skip_n_frames": 1, "blur_size": 0, "post_median_size": 0, "intrinsics_file": "/data/modalai/opencv_stereo_intrinsics.yml", "extrinsics_file": "/data/modalai/opencv_stereo_extrinsics.yml" } }THEN I run voxl-configure-dfs and say NO to reset to defaults, YES to enable the server. If i try to run voxl-dfs-server again, I get the same
ERROR: Failed to open calibration file: /data/modalai/opencv_stereo_rear_intrinsics.ymlAnd I get this because somehow the voxl-dfs-server.conf file was reset to its factory state
@bendraper said in Voxl 2 DFS Server:
voxl-configure-dfs
OK, thanks. It sounds like a bug.
Instead of running
voxl-configure-dfsthe second time, just runsystemctl enable voxl-dfs-server -
voxl-configure-dfs
Instead of running
voxl-configure-dfsthe second time, just runsystemctl enable voxl-dfs-server@Chad-Sweet said in Voxl 2 DFS Server:
That doesn't seem to fix the issue. I can issue that command after editing the file, but the inspect-services just says its enabled but not running. Then when I run voxl-dfs-server, it repopulates that conf file to have a "stereo_rear" and fails because the path its looking for the extrinsics obviously does not exist. Is the naming convention I'm using when I edit that file correct? if I only have one stereo pair, should it still be "dfs_pair_0" or should it be something else. The naming convention for this file also differs to that of what is shown on the DFS-Server wiki page.
Looking at the code here, maybe you just need to set dfs_pair_1 enable to false instead of deleting it?
