    First Flight Help On VOXL Flight Deck.
    VOXL Flight Deck
    • M
      mirasul
      Can someone please help me with my first flight? I setup a roskinetic docker and used the mavros_test example that was provided online. However I am unable to fly the drone in figure eight motion. I am able to see the rostopic list from host pc but nothing is being published on the topics.
      My goal is to run a custom Python script that uses motion capture system to provide pose data over vrpn_client_ros for hover and land. I started with the tutorial first but because I could not get the drone to take off I am now stuck. Any help would be highly appreciated.
      Thank You.
      P.S My drone is able to arm via QGroundControl over UDP connection.
      • Chad SweetC
        Chad Sweet ModalAI Team
        If it is VOXL Flight based, the M500 Getting Started should be useful
        https://docs.modalai.com/voxl-m500-quickstart/
        Definitely first test the drone out very carefully using manual mode. It's a big jump to get start programming it with a script. A lot could go wrong!
        See https://modalai.com/safety
        • M
          mirasul
          I have done a first flight using a controller and the drone is responding fine. I wanted to use Motion capture to provide the Pose data, is there a way to do this on the VOXL?
