  3. Garbage attitude control
27 Posts 9 Posters 8.6k Views 4 Watching
  • Patrick HincheyP Offline
    Patrick Hinchey
    Thanks for the quick reply, Chad!
    We're using a standard 4-in-1 racing ESC on PWM. We have a 6S battery so we couldn't use the ModalAI ESC but I've just ordered some of your new T-motor F55As.
      Then it sounds like you're using the M0065 VOXL 2 I/O board with it to generate PWM? If so, have you tried calibrating those ESC? https://docs.modalai.com/voxl2-io-user-guide/#pwm-esc-calibration
      Otherwise, it still sounds like platform tuning... Can you copy the working parameters from your Pixhawk over?
      Patrick HincheyP 1 Reply Last reply
      • Chad SweetC Chad Sweet
        Patrick Hinchey
        @Chad-Sweet yep, we're using the I/O expander. We calibrated the ESC and and tried with the pixhawk's gains too, and it was still unflyable. Again, I have plenty of experience tuning PIDs, and nothing I could do could make this stable. Would it help if I uploaded some logs?
          Yes, of course. logs.px4.io is a good way
            Another thought... Did you configure the mixer using these docs: https://docs.modalai.com/voxl2-io-user-guide/#supported-mixers-and-airframe-setup
            And then did you disable the modal_esc driver?
            Tamas Pal 0T 1 Reply Last reply
              Tamas Pal 0T Offline
              Tamas Pal 0
              @Chad-Sweet I am also having same issue. Can you please tell what is modal_esc driver? How to disable it ?
              • Tamas Pal 0T Tamas Pal 0
                Patrick Hinchey
                Hmm, that's really interesting. Looking back at the parameters from those tests, the UART_ESC_CONFIG was set to 1. I'll set it to 0 and see what happens.
                @Tamas-Pal-0 go into qgroudcontrol parameters and set UART_ESC_CONFIG to 0. please post your results!
                • modaltbM Offline
                  modaltbM Offline
                  modaltb
                  Guys, I'm actively looking at this and will report what I find, it's my top priority.
                    Patrick Hinchey
                    Thank you @modaltb , much appreciated. I look forward to your findings. I disabled the modal_esc driver and it didn't help. Here is a log of the VOXL as flight controller, and one with a Pixhawk 4 as flight controller, with identical parameters. Both were mounted to the aircraft the whole time, all we did was swap wires around between flights.
                    Obviously there's still room for improvement with the Pixhawk 4 but for the most part it flew really well with default PID gains, whereas we couldn't even get the VOXL2 stable.
                    VOXL2:
                    https://logs.px4.io/plot_app?log=25afc87c-37cd-4693-9318-df62be99e4bd
                    Pixhawk 4:
                    https://logs.px4.io/plot_app?log=4b8a4762-8f59-49ca-a7fc-af41d38c466b
                    • Patrick HincheyP Patrick Hinchey
                      VOXL2:
                      Pixhawk 4:
                      Tamas Pal 0
                      @Patrick-Hinchey I also have same experience like you. After disabling modalai_esc driver. I set UART_ESC_CONFIG to 0 also. It didn't help.
                      • modaltbM Offline
                        modaltbM Offline
                        modaltb
                        #13
                        @Patrick-Hinchey ,
                        I'm still actively looking into this! One area that caught my eye is here:
                        https://github.com/modalai/px4-firmware/blob/voxl-dev/boards/modalai/rb5-flight/voxl-px4.config#L187
                        Out testing has been on a Sentinel setup and am wondering if there's some settings not propagating correctly.
                        This file can be edited on target to adjust, I'm going through some testing now.
                        • M Offline
                          M Offline
                          m1baldwin
                          wrote on last edited by m1baldwin
                          #14
                          I saw something similar with PX4 version 1.13.1; I don't have a VOXL2, but I had an issue where with VOXL 1 Flight Deck with PX4 1.13.1 did not work well for me on a standard airframe.
                          I downgraded to 1.11.3 sub-version 0.2.3 - I think this is a Modal AI sub-version? - and had better luck, maybe try an earlier version of px4
                          • modaltbM Offline
                            modaltbM Offline
                            modaltb
                            No smoking gun, but here's a commit I have going that uses params instead of hard coded values that we could give a try.
                            https://github.com/modalai/px4-firmware/commit/a0317b59e72eeb90126788e71093726dafe70708
                            File changed is here: https://github.com/modalai/px4-firmware/blob/pr-m0065-mr1/boards/modalai/rb5-flight/voxl-px4.config
                            On monday, I did fly the default Sentinel params with this VOXL2 IO board, it oscillated like crazy and we did a quick dirty tune and got it reasonable.
                            I'm going to request that we do a full tune on our Sentinel here to ensure we can get same perf as expected with this setup so we have a ground truth. Will report back when I have info.
                            • modaltbM Offline
                              modaltbM Offline
                              modaltb
                              Also, any chance you could post a link to a video of a flight to help us understand the failure mode even more?
                                Patrick Hinchey
                                Thank you for looking into this.
                                Here is a video
                                https://drive.google.com/file/d/1qPXFrxluE-MyOOpnfHQJ5eT4XOLYvGNu/view?usp=share_link
                                I'll try with the new config file tonight. However the Pixhawk4 parameters are very similar - min=1075, maz=1950 so I would be surprised if that mad all that much difference.
                                Also, regarding tuning the VOXL2, I'm curious to hear your opinion on why the same gains on the same machine would work great on the Pixhawk4 but not on the VOXL2. The Pixhawk4 is running the latest stable release
                                • modaltbM Offline
                                  modaltbM Offline
                                  modaltb
                                  Hey @Patrick-Hinchey ,
                                  Thanks for the video, I'm gonna get some teammates to help early this week who are much more versed in this area.
                                  Here's my setup, it's VOXL2 with VOXL2 IO, as you can see it's flyable but a little rough, I too initially had a wobble that prevented me from flying and changed params a bit from our default Sentinel settings to get it airborne:
                                  https://www.youtube.com/watch?v=1INto92k-v0
                                  I'll get some members of the team early this week to better answer your second question and we'll keep cranking away.
                                  • Daniel MellingerD Offline
                                    Daniel Mellinger
                                    Hi @Patrick-Hinchey, we are actively working on figuring out the answer your question about "why the same gains on the same machine would work great on the Pixhawk4 but not on the VOXL2." There are several differences between the PX4 code running on VOXL2 compared to Pixhawk4. Specifically, the path of the PWM commands to the motors including the px4io setup is different on VOXL2 compared to Pixhawk4. Additionally, VOXL2 uses a different IMU than Pixhawk4 and that IMU is configured differently. We will keep you posted on what we are able to figure out.
                                    • ? Offline
                                      #20
                                      @Patrick-Hinchey
                                      I hope all is well!
                                      I'm sorry you're dealing with this - I know it can be frustrating.
                                      I'm jumping here a little late and may have missed something. I was wondering, can you confirm that you have the correct motor mapping:
                                      Also, were you able to successfully run through a PWM ESC calibration using these Instructions? Which specific ESCs are you using? Did you hear the expected chimes (maybe firmware not accepting)?
                                        Patrick Hinchey
                                        Thank you for your insight everyone,
                                        We have an important milestone coming up in 2 weeks so we're going to use the external flight controller until then and then resume troubleshooting this issue after that - trying all the suggestions above.
                                        Thanks, see you in 2 weeks!
                                        • X Offline
                                          X Offline
                                          xav04
                                          Hi, I have the same problem. I have VOXL 2 I/O and every time I try to take it off it wobbles and crashes. I have a quad x, I have done the ESC calibration and I have followed all the instructions. Is there any solution to this problem?
