    Vision failure everytime during takeoff
    4043
    • Tamas Pal 0T
      Tamas Pal 0
      I am trying to fly a quad using voxl2 flight deck + voxl2 IO board with F-450 frame. Everytime during takeoff its showing vision failure and starts wobbling uncontrollably. How to fix it ?
      The terminal ouput during takeoff for qvio.
      voxl2:~$ voxl-inspect-qvio
      waiting for server
       dt(ms) |    T_imu_wrt_vio (m)   |Roll Pitch Yaw (deg)|features|quality| state| error_codes |
         33.2 |    0.00    0.00    0.00|   0.0   -0.0    0.0|    14  |   -1% | FAIL | NOT_STATIONARY
      Tamas Pal 0T 1 Reply Last reply Reply Quote 0
      • Tamas Pal 0T
        Tamas Pal 0 @Tamas Pal 0
        @modaltb please help me to fix this
        wilkinsafW 1 Reply Last reply Reply Quote 0
        • wilkinsafW
          wilkinsaf ModalAI Team @Tamas Pal 0
          @Tamas-Pal-0 This seems like this might be a pid issue. PID issues causes unstable flight making the camera useless since it is all over the place
          Would you be able to upload a ulog file to https://review.px4.io/ and post the link here so we can review?
          Tamas Pal 0T 1 Reply Last reply Reply Quote 1
          • Tamas Pal 0T
            Tamas Pal 0 @wilkinsaf
            @wilkinsaf Here are the link for the log files
            https://review.px4.io/plot_app?log=8d5ce1ba-a330-4f0e-9026-a70a7c7c5236
            https://review.px4.io/plot_app?log=42ad2744-11e3-42d3-9fb3-8ae4abc40974
            https://review.px4.io/plot_app?log=37c1881e-e9ed-4068-8943-b1b42c860afa
            https://review.px4.io/plot_app?log=1e214868-0fae-41f9-8c8d-9620bd245002
            • wilkinsafW
              @Tamas-Pal-0 Yeah, it looks like this UAV is not tuned.
              Notice how the red and green lines are not matching up. Those should be in sync and much less noisy. Your vibration metrics are also very high
              Are you familiar with PID tuning in PX4? https://docs.px4.io/main/en/config_mc/pid_tuning_guide_multicopter.html
              • Tamas Pal 0T
                @wilkinsaf Why the autotune is not working for it?
                • Dobry KolaczD
                  Dobry Kolacz ModalAI Team
                  @Tamas-Pal-0 What is the "quality" readout before takeoff when you run voxl-inspect-qvio ?
                  • Tamas Pal 0T
                    Tamas Pal 0 @Dobry Kolacz
                    @Dobry-Kolacz The quality reduces to -1% before even taking off everytime
                    • Steve TurnerS
                      Steve Turner
                      Is this a unit direct from ModalAI? If it is, it should be tuned or you could load default parameters from https://gitlab.com/voxl-public/flight-core-px4/px4-parameters/-/tree/master/platforms for your version of PX4 and platform.
                      Then from there you load a helper through QGroundControl parameters page: https://gitlab.com/voxl-public/flight-core-px4/px4-parameters/-/tree/master/helpers
                      That should get you close to a decent tune.
                      If this is a custom drone, you need to configure your extrinsics, calibrate your camera, and validate QVIO first before attempting to fly which it looks like you are attempting to do. The VOXL portal qVIO overlay will show you points selected as well as distance traveled which you can validate against manually moving the drone around prior to any attempts to fly. The camera needs to have areas of contrasting features in view -- so reflective floors or some repetitive patterns can be a challenge for qVIO.
                      https://docs.modalai.com/configure-extrinsics/
                      https://docs.modalai.com/calibrate-cameras/
                      1 Reply Last reply Reply Quote 2
                      • modaltbM
                        modaltb ModalAI Team
                        @Tamas-Pal-0 ,
                        I think the 'auto tune' you are talking about is a PX4 feature that came out in PX4 1.13? We at Modal haven't that yet and it's not a feature in the 1.12 based voxl-px4 release at this time, and we don't have documentation calling this out to use anywhere that I'm aware of?
                        I personally am not great at tuning, it's a skill for sure, but when I have done it I start with very low PID values and guess and check till I get it useable and make small tweaks.
                        For sure, make sure you can manual flight smoothly before ever attempting throwing it into a computer vision assisted flight!
                        Without introducing vibrations into the system (e.g. carry vehicle by hand) do you still see this issue?
                        Can you paste a picture of how you are mounting the hardware?
                        • Tamas Pal 0T
                          Tamas Pal 0 @modaltb
                          @modaltb The autotune I am talking about is shown here.
                          By deafult it is enabled, even if I disable it, automatically it gets enabled after restart.
                          It is not at usable even in manual mode.
                          The hardware setup is here. I am using modal ai voxl2 case only.
                          • Tamas Pal 0T
                            @modaltb any suggestion ?
                            • modaltbM
                              The way I'd tackle this, and I'd be painfully slow to be honest, is reducing the PID values for roll/pitch/yaw manually, and slowly tweaking, likely taking me a day or two, until I get things usable.
                              You are using an S500 frame with the VOXL IO board. We have successfully flown this setup ourselves, for reference here's PID values that could be used to start off with, which is where I'd start: https://gitlab.com/voxl-public/flight-core-px4/px4-parameters/-/blob/master/platforms/v1.12/Sentinel/Sentinel_v1_param_rev_C.params#L110
                              Before any time of autonomous flight, I always do manual flights.
                              • Have you flown in manual mode yet successfully?
                              • If not, can you try the PID gain settings from above?
                              • If not, have you confirmed that the ESC ordering is OK?
                              • If not, have you tried calibrating your PWM ESCs? https://docs.modalai.com/voxl2-io-user-guide/#pwm-esc-calibration
                              • modaltbM
                                Also, any mechanical looseness will translate into undesired artifacts that may affect flight performance. If the wrong frequencies get into the system, you will see flight issues for sure... Our ME team spends considerable effort in the coupling of the systems.
                                In the image, I'm not totally familiar with the plastics being used for the mounting, are those custom or maybe painted?
                                • Tamas Pal 0T
                                  @modaltb I am not able to fly it manually. I do not think it is because of PID gains. It is the ESC that is causing the problem. How to be sure that PWM ESCs are getting calibrated with the backdoor calibration method?
                                  The casing is printed with PLA. It is pretty strong and there is no significant vibration because of it. However, any recommendation which material should we use?
                                  In another post https://forum.modalai.com/topic/1490/garbage-attitude-control?_=1667191852345 @Chad-Sweet asked to disable model_esc driver. What is it and how to disable it ?
                                  • modaltbM
                                    I'm actively looking at this and will report what I find, it's my top priority. I don't believe the UART esc to be causing this but regardless for this use case, we will disable it (some users had both UART esc and VOXL2IO, but we haven't fully validated that use case)
                                    • modaltbM
                                      As far as disabling the driver in the build you have:
                                      /etc/modalai/voxl-px4.confg
                                      You can comment out the last two lines to prevent the UART driver starting.
                                      # ESC driver
                                      # We start this even if there is a PX4IO module. If there is
                                      # a PX4IO (M0065) module it will be plugged into the RC port
                                      # and so this driver will output commands on an empty port.
                                      #qshell modalai_esc start
                                      #qshell mixer load /dev/uart_esc quad_x.main.mix
                                      I just did a test and this made no difference in flight perf, but in the next release I will be checking for a param and only starting if the param is set:
                                      My first flight I though I was reproducing your error, my Sentinel was flying awful and I had to put it down. I got our flight test team to make some tuning changes around the PID values for roll/pitch/yaw and we were able to fly after that.
                                      So one data point out of this is, the default Sentinel tune is optimized for our UART ESC and doesn't work well with the VOXL IO / PWM escs out of the box likely.....
                                      I will get these off the vehicle when I do some updates here in a bit and can share with you to see if that helps any.
                                      • Tamas Pal 0T
                                        @modaltb After diabling it, the quad is able to hover in stabilized mode. but it is going here and there uncontrollably and dangerously without any stick input and a bit of wobbling is still there. Any update?
                                        • modaltbM
                                          My next step is to share some PX4 params (pid settings, cutoff filters) that got my sentinel stable, but I need my team to validate before sending. I’m not clear if this will solve everything but will at least be a good data point. I’m hoping to get this tested tomorrow and will share
                                          • modaltbM
                                            @Tamas-Pal-0 ...
                                            I still have nothing to report as far as finding root cause of something, after our tune tweaks I was up and going. I am still testing though for this use case to see if there's some edge case I'm not seeing, I'm just a bit slow with this debugging.
                                            As far as sharing my params that got me flying, I don't even know if my approach here is valid, you have different motor/prop setup, and frames aren't identical, battery type?...
                                            My lawyer told me to tell you "not to use these since we don't have the same setup and the author/developer in the post here isn't really a pilot so...." You've been warned by the lawyer! 😉
                                            # Pitch PID
                                            1	1	MC_PITCH_P	5.5	9
                                            1	1	MC_PITCHRATE_P	0.065	9
                                            1	1	MC_PITCHRATE_I	0.150	9
                                            1	1	MC_PITCHRATE_D	0.002	9
                                            1	1	MC_PITCHRATE_K	1.0	9
                                            # Roll PID
                                            1	1	MC_ROLL_P	5.5	9
                                            1	1	MC_ROLLRATE_P	0.065	9
                                            1	1	MC_ROLLRATE_I	0.150	9
                                            1	1	MC_ROLLRATE_D	0.002	9
                                            1	1	MC_ROLLRATE_K	1.0	9
                                            # Yaw PID
                                            1	1	MC_YAW_P	2.0	9
                                            1	1	MC_YAWRATE_P	0.15	9
                                            1	1	MC_YAWRATE_I	0.10	9
                                            1	1	MC_YAWRATE_D	0.0	9
                                            1	1	MC_YAWRATE_K	1.0	9
                                            # Noise management
                                            1	1	MOT_SLEW_MAX	0.0	9
                                            1	1	IMU_DGYRO_CUTOFF	30.0	9
                                            1	1	IMU_ACCEL_CUTOFF	30.0	9
                                            1	1	IMU_GYRO_CUTOFF	30.0	9
                                            Checkout out noise management here... I've had some nasty flights due to cutoff frequencies.
