  3. voxl_qvio_server version problem
9 Posts 3 Posters 1.6k Views 1 Watching
  • Dong LiuD Offline
    Dong LiuD Offline
    Dong Liu
    I built the latest libmodal_json and libmodal_pipe from gitlab and the latest voxl_mpa_to_ros in a ROS medolic container. But when I tried to subscribe /qvio topic, I got this error,
    RROR validating VIO data received through pipe: read partial packet
    read 156 bytes, but it should be a multiple of 324
    It turns out voxl_qvio_server is using a older version of libmodal_pipe. The data structure vio_data_t changed in the latest version.
    What is proper solution for this?
    Is there newer SDK with latest libmodal_pipe available I can upgrade to? Or should I build my container using the older version of libmodal_pipe?
    Dong
      If you are working from dev branch, you need to use the dev branch for all of your packages.
      See package configuration here: https://docs.modalai.com/configure-pkg-manager/
      • Dong LiuD Offline
        Dong LiuD Offline
        Dong Liu
        Thank you Chad!
        I'm not using the dev branch. I just build my mpa_to_ros using the master branch of libmodal_json, libmodal_pipe and voxl_mpa_to_ros.
        If I upgrade my voxl seeker to the stable release of VOXL Platform 3.8.0-0.7, which branch should I use to build my package?
        Thanks again!
          You should try the latest stable then. You cannot mix new and old code.
          Dong LiuD 1 Reply Last reply
          • ? Offline
            You can also pull from a specific release in your install-build-deps script. If your drone is on the 0.7 release and you'd like to make some modifications, you can checkout the sdk-0.7 tag, make your modifications, and run install-build-deps.sh sdk-0.7 to have everything from the last voxl1 stable release.
            • Chad SweetC Chad Sweet
              Dong LiuD Offline
              Dong LiuD Offline
              Dong Liu
              @Chad-Sweet
              My question if I use the latest stable binary release. Which label branch should to checkout to build mpa_to_ros in ROS melodic docker?
              • ? A Former User
                Dong LiuD Offline
                Dong LiuD Offline
                Dong Liu
                @Alex-Gardner Thanks Alex. Could you please tell what the SDK version the drone is currently using?
                • ? Offline
                  The "platform release" that we ship is a system image paired with a release of the sdk, so that one that you flashed (3.8.0-0.7) is system image 3.8.0 alongside sdk 0.7, so you should use the sdk-0.7 repos.
                  • ? A Former User
                    Dong LiuD Offline
                    Dong LiuD Offline
                    Dong Liu
                    @Alex-Gardner Thanks!
