<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[voxl_qvio_server version problem]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">I built the latest libmodal_json and libmodal_pipe from gitlab and the latest voxl_mpa_to_ros in a ROS medolic container. But when I tried to subscribe /qvio topic, I got this error,</p>
<p dir="auto">RROR validating VIO data received through pipe: read partial packet<br />
read 156 bytes, but it should be a multiple of 324</p>
<p dir="auto">It turns out voxl_qvio_server is using a older version of libmodal_pipe. The data structure vio_data_t changed in the latest version.</p>
<p dir="auto">What is proper solution for this?</p>
<p dir="auto">Is there newer SDK with latest libmodal_pipe available I can upgrade to? Or should I build my container using the older version of libmodal_pipe?</p>
<p dir="auto">Thanks,</p>
<p dir="auto">Dong</p>
]]></description><link>https://forum.modalai.com/topic/1410/voxl_qvio_server-version-problem</link><generator>RSS for Node</generator><lastBuildDate>Tue, 10 Mar 2026 22:31:41 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/1410.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 30 Sep 2022 13:37:48 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to voxl_qvio_server version problem on Fri, 30 Sep 2022 19:52:39 GMT]]></title><description><![CDATA[<p dir="auto">@Alex-Gardner Thanks!</p>
]]></description><link>https://forum.modalai.com/post/6585</link><guid isPermaLink="true">https://forum.modalai.com/post/6585</guid><dc:creator><![CDATA[Dong Liu]]></dc:creator><pubDate>Fri, 30 Sep 2022 19:52:39 GMT</pubDate></item><item><title><![CDATA[Reply to voxl_qvio_server version problem on Fri, 30 Sep 2022 18:53:34 GMT]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">The "platform release" that we ship is a system image paired with a release of the sdk, so that one that you flashed (3.8.0-0.7) is system image 3.8.0 alongside sdk 0.7, so you should use the sdk-0.7 repos.</p>
]]></description><link>https://forum.modalai.com/post/6581</link><guid isPermaLink="true">https://forum.modalai.com/post/6581</guid><dc:creator><![CDATA[[[global:former_user]]]]></dc:creator><pubDate>Fri, 30 Sep 2022 18:53:34 GMT</pubDate></item><item><title><![CDATA[Reply to voxl_qvio_server version problem on Fri, 30 Sep 2022 18:00:15 GMT]]></title><description><![CDATA[<p dir="auto">@Alex-Gardner Thanks Alex. Could you please tell what the SDK version the drone is currently using?</p>
<p dir="auto">Thanks!</p>
]]></description><link>https://forum.modalai.com/post/6576</link><guid isPermaLink="true">https://forum.modalai.com/post/6576</guid><dc:creator><![CDATA[Dong Liu]]></dc:creator><pubDate>Fri, 30 Sep 2022 18:00:15 GMT</pubDate></item><item><title><![CDATA[Reply to voxl_qvio_server version problem on Fri, 30 Sep 2022 17:57:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/3">@Chad-Sweet</a></p>
<p dir="auto">My question if I use the latest stable binary release. Which label branch should to checkout to build mpa_to_ros in ROS melodic docker?</p>
]]></description><link>https://forum.modalai.com/post/6574</link><guid isPermaLink="true">https://forum.modalai.com/post/6574</guid><dc:creator><![CDATA[Dong Liu]]></dc:creator><pubDate>Fri, 30 Sep 2022 17:57:02 GMT</pubDate></item><item><title><![CDATA[Reply to voxl_qvio_server version problem on Fri, 30 Sep 2022 17:39:48 GMT]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">You can also pull from a specific release in your install-build-deps script. If your drone is on the 0.7 release and you'd like to make some modifications, you can checkout the sdk-0.7 tag, make your modifications, and run <code>install-build-deps.sh sdk-0.7</code> to have everything from the last voxl1 stable release.</p>
]]></description><link>https://forum.modalai.com/post/6573</link><guid isPermaLink="true">https://forum.modalai.com/post/6573</guid><dc:creator><![CDATA[[[global:former_user]]]]></dc:creator><pubDate>Fri, 30 Sep 2022 17:39:48 GMT</pubDate></item><item><title><![CDATA[Reply to voxl_qvio_server version problem on Fri, 30 Sep 2022 17:23:42 GMT]]></title><description><![CDATA[<p dir="auto">You should try the latest stable then. You cannot mix new and old code.</p>
]]></description><link>https://forum.modalai.com/post/6571</link><guid isPermaLink="true">https://forum.modalai.com/post/6571</guid><dc:creator><![CDATA[Chad Sweet]]></dc:creator><pubDate>Fri, 30 Sep 2022 17:23:42 GMT</pubDate></item><item><title><![CDATA[Reply to voxl_qvio_server version problem on Fri, 30 Sep 2022 16:23:13 GMT]]></title><description><![CDATA[<p dir="auto">Thank you Chad!</p>
<p dir="auto">I'm not using the dev branch. I just build my mpa_to_ros using the master branch of libmodal_json, libmodal_pipe and voxl_mpa_to_ros.</p>
<p dir="auto">If I upgrade my voxl seeker to the stable release of VOXL Platform 3.8.0-0.7, which branch should I use to build my package?</p>
<p dir="auto">Thanks again!</p>
]]></description><link>https://forum.modalai.com/post/6566</link><guid isPermaLink="true">https://forum.modalai.com/post/6566</guid><dc:creator><![CDATA[Dong Liu]]></dc:creator><pubDate>Fri, 30 Sep 2022 16:23:13 GMT</pubDate></item><item><title><![CDATA[Reply to voxl_qvio_server version problem on Fri, 30 Sep 2022 13:44:11 GMT]]></title><description><![CDATA[<p dir="auto">If you are working from dev branch, you need to use the dev branch for all of your packages.</p>
<p dir="auto">See package configuration here: <a href="https://docs.modalai.com/configure-pkg-manager/" rel="nofollow ugc">https://docs.modalai.com/configure-pkg-manager/</a></p>
]]></description><link>https://forum.modalai.com/post/6556</link><guid isPermaLink="true">https://forum.modalai.com/post/6556</guid><dc:creator><![CDATA[Chad Sweet]]></dc:creator><pubDate>Fri, 30 Sep 2022 13:44:11 GMT</pubDate></item></channel></rss>
