    VIO Indoor Navigation
    3326
    • Maha RiyadM
      Maha Riyad
      Hello @modaltb ,
      We are trying to run MAVROS on voxl m500, but we're facing issues with the VIO. The VIO is enabled in the voxl-vision-px4 configuration file. However, when checking the x and y values in the odometry mavlink telemetry packets they're found to be 0s.
      The position mode is continuously rejected and it seems like the VIO data is not being transmitted. We did not change the flight core's PX4-EKF2 settings yet we tried to use the helper file here: https://gitlab.com/voxl-public/flight-core-px4/px4-parameters/-/blob/master/helpers/ekf2_indoor_vio.params
      and we still did not manage to get it to work. Could you please help?
      • modaltbM
        modaltb ModalAI Team
        Hi @Maha-Riyad ,
        One way to debug is using voxl-vision-px4 via command line, with the 0.6.8 production release, there's a -o option that prints out odometry data straight out of voxl-vision-px4 which is useful.
        https://gitlab.com/voxl-public/modal-pipe-architecture/voxl-vision-px4/-/blob/7b9f76c468045a023b35747deeef52e4f524b7de/src/main.c#L99
        If you run voxl-vision-px4 -o from command line, how are things looking there?
        • modaltbM
          I forgot, James has a great video here too: https://www.youtube.com/watch?v=0j7CjmDvluM&feature=emb_logo
          Lynn KoudsiL 1 Reply Last reply Reply Quote 0
          • Lynn KoudsiL
            Lynn Koudsi @modaltb
            Hi @modaltb,
            I'm getting the exact same problem with the same parameter settings. I tried running voxl-vision-px4 -o and I was seeing no messages when attempting to switch to position control. I'm also not seeing any Odometry section in MAVLink Inspector.
            I'm seeing no errors when running voxl-vision-px4 as a service or in command line.
            • modaltbM
              Hi @Lynn-Koudsi ,
              Hmmm, this one is confusing me a bit, if you're available maybe we could setup a screen share on Monday to troubleshoot? I'm be available 8:15-10:00, 12-2 and 4-5 PST, or Tuesday anytime after 8:15 AM PST.
              Thanks!!
              • Lynn KoudsiL
                @modaltb 12-2 works!
                Also just for more context, I had done a clean image installation at V3.1.0 and had removed my data folder. I'm thinking the issue is that calibration files are not there. I tried running voxl-cam-ros but it's not finding left and right yaml files. I tried just pushing the sample calibration files from https://gitlab.com/voxl-public/utilities/voxl-camera-calibration but it won't find ost.yaml.
                So I guess my question is, is there a default data folder available online? Or can you provide the default factory data folder?
                • modaltbM
                  Just sent out an invite for tomorrow, if I can get the SN of the m500 I can get you the calibration files we have in our production database in advance and that might get things going!
                  • Lynn KoudsiL
                    @modaltb Thank you!
                    Serial# is M20000000TJ
                    • LipingL
                      Liping
                      Hi @modaltb
                      I'm getting the same problem as described by Lynn. I had also done a clean image installation at V3.1.0 and had removed my data folder.
                      yocto:~# voxl-vision-px4 -o
                      loading our own config file
                      qgc_ip:                     192.168.43.84
                      en_localhost_mavlink_udp    1
                      en_secondary_qgc:           0
                      qgc_udp_port_number:        14550
                      en_vio:                     1
                      en_voa:                     0
                      en_send_vio_to_qgc:         0
                      en_send_voa_to_qgc:         0
                      en_adsb:                    1
                      adsb_uart_bus:              7
                      adsb_uart_baudrate:         57600
                      px4_uart_bus:               5
                      px4_uart_baudrate:          921600
                      follow_tag_id:              0
                      en_apriltag_fixed_frame:    0
                      fixed_frame_filter_len:     5
                      loading extrinsics and apriltag external config files
                      #0:
                          tag id:          0
                          size_m:            0.400
                          T_tag_wrt_fixed: 0.0  0.0  0.0
                          R_tag_to_fixed:  0.0 -1.0  0.0
                                           1.0  0.0  0.0
                                           0.0  0.0  1.0
                      #1:
                          tag id:          1
                          size_m:            0.400
                                           1.0  0.0  0.0
                                           0.0  0.0  1.0
                      loaded in 2 fixed apriltags
                      #0:
                          parent:                imu1
                          child:                 imu0
                          T_child_wrt_parent:   -0.048   0.037   0.002
                          RPY_parent_to_child:   0.0     0.0     0.0
                          R_child_to_parent:     1.000  -0.000   0.000
                                                 0.000   1.000  -0.000
                                                 0.000   0.000   1.000
                      #1:
                          parent:                imu0
                          child:                 tracking
                          T_child_wrt_parent:    0.065  -0.014   0.013
                          RPY_parent_to_child:   0.0    45.0    90.0
                          R_child_to_parent:     0.000  -0.707   0.707
                                                 1.000   0.000  -0.000
                                                -0.000   0.707   0.707
                      #2:
                          parent:                imu1
                          child:                 tracking
                          T_child_wrt_parent:    0.017   0.015   0.013
                                                 1.000   0.000  -0.000
                                                -0.000   0.707   0.707
                      #3:
                          parent:                body
                          child:                 imu0
                          T_child_wrt_parent:    0.020   0.014  -0.008
                                                 0.000   1.000  -0.000
                                                 0.000   0.000   1.000
                      #4:
                          parent:                body
                          child:                 imu1
                          T_child_wrt_parent:    0.068  -0.015  -0.008
                                                 0.000   1.000  -0.000
                                                 0.000   0.000   1.000
                      #5:
                          parent:                body
                          child:                 stereo_l
                          T_child_wrt_parent:    0.100  -0.040   0.000
                          RPY_parent_to_child:   0.0    90.0    90.0
                          R_child_to_parent:     0.000  -0.000   1.000
                                                 1.000   0.000  -0.000
                                                -0.000   1.000   0.000
                      #6:
                          parent:                body
                          child:                 tof
                          T_child_wrt_parent:    0.100   0.000   0.000
                                                 1.000   0.000  -0.000
                                                -0.000   1.000   0.000
                      #7:
                          parent:                body
                          child:                 ground
                          T_child_wrt_parent:    0.000   0.000   0.100
                                                 0.000   1.000  -0.000
                                                 0.000   0.000   1.000
                      exising instance of voxl-vision-px4 found, attempting to stop it
                      starting geometry module
                      starting uart mavlink
                      Successfully opened mavparser
                      starting udp mavlink
                      Detected PX4 Mavlink SYSID 1
                      Adding manual QGC IP address to udp connection list: 192.168.43.84
                      Added new UDP connection to 192.168.43.84
                      starting px4 shell
                      starting fixed pose input
                      starting vio manager
                      starting apriltag manager
                      starting adsb manager
                      ADSB thread starting
                      PX4 Connected over UART with sysid 1
                      But when I run 'voxl-test-vision-lib -o' I can see the VIO works.
                      [6619.210687] SNAV INFO: IMU sensor finished initializing.
                      [6619.211066] SNAV INFO: IMU sensor settings retrieved.
                      [6619.211122] SNAV INFO: Creating IMU thread.
                      [6619.211332] SNAV INFO: Creating VISLAM processing thread.
                      [6619.211463] SNAV INFO: ImuManager thread has tid = 3558, nice = -15
                      [6619.211483] SNAV INFO: Creating VISLAM publishing thread.
                      [6619.211768] SNAV INFO: VISLAM publishing thread has tid = 3560, nice = -5
                      VIO camera frame: points:  0 X:  0.000 Y:  0.000 Z:  0.000 R:  0.000 P: -0.000 Y:  0.000
                      [6619.211958] SNAV INFO: VISLAM processing thread has tid = 3559, nice = -5
                      VIO camera frame: points: 39 X:  0.000 Y:  0.000 Z:  0.000 R:  0.000 P: -0.000 Y:  0.000
                      VIO camera frame: points: 39 X: -0.000 Y:  0.000 Z: -0.000 R: -0.000 P: -0.000 Y: -0.000
                      VIO camera frame: points: 39 X: -0.000 Y:  0.000 Z:  0.000 R: -0.000 P:  0.000 Y: -0.000
                      VIO camera frame: points: 39 X: -0.000 Y:  0.001 Z:  0.000 R: -0.001 P: -0.000 Y: -0.000
                      VIO camera frame: points: 39 X: -0.001 Y: -0.002 Z: -0.005 R:  0.001 P: -0.001 Y: -0.000
                      VIO camera frame: points: 39 X:  0.000 Y: -0.000 Z: -0.008 R:  0.000 P: -0.001 Y: -0.001
                      VIO camera frame: points: 39 X: -0.000 Y: -0.001 Z: -0.010 R:  0.001 P: -0.002 Y: -0.001
                      VIO camera frame: points: 39 X: -0.000 Y: -0.000 Z: -0.014 R:  0.002 P: -0.003 Y: -0.001
                      VIO camera frame: points: 39 X:  0.002 Y:  0.002 Z: -0.019 R:  0.001 P: -0.003 Y: -0.002
                      VIO camera frame: points: 39 X:  0.003 Y:  0.002 Z: -0.022 R:  0.001 P: -0.004 Y: -0.002
                      VIO camera frame: points: 39 X:  0.004 Y:  0.002 Z: -0.023 R:  0.001 P: -0.004 Y: -0.001
                      VIO camera frame: points: 39 X:  0.004 Y:  0.001 Z: -0.020 R:  0.001 P: -0.004 Y: -0.001
                      VIO camera frame: points: 39 X:  0.002 Y:  0.001 Z: -0.015 R:  0.001 P: -0.004 Y: -0.001
                      In QGroundControl, I can not see the ODOMETRY section in the MAVLink inspector.
                      My serial # M20000005GT
                      • Lynn KoudsiL
                        Lynn Koudsi @Liping
                        @Liping My issue was resolved by installing voxl-qvio. You can reference the diagram here to learn what services are needed for the different interactions.
                        LipingL 1 Reply Last reply Reply Quote 0
                        • LipingL
                          Liping @Lynn Koudsi
                          @Lynn-Koudsi Thanks Lynn. But in my case, the issue still exists after installing the voxl-qvio.
                          What are your installed voxl package versions?
                          I installed some latest stable version packages.
                          yocto:~#  opkg list-installed | grep "voxl"
                          libvoxl_io - 0.5.4
                          voxl-cam-manager - 0.2.2
                          voxl-docker-support - 1.1.1
                          voxl-hal3-tof-cam-ros - 0.0.2
                          voxl-modem - 0.10.0
                          voxl-mpa-tools - 0.1.6
                          voxl-nodes - 0.0.8
                          voxl-qvio-server - 0.2.1
                          voxl-rtsp - 1.0.2
                          voxl-time-sync - 0.0.1
                          voxl-utils - 0.5.2
                          voxl-vision-px4 - 0.8.1
                          voxl-vpn - 0.0.2
                          voxl_imu - 0.0.4
                          • Lynn KoudsiL
                            Lynn Koudsi @Liping
                            @Liping Is voxl-qvio actually running? You can check by calling systemctl status voxl-qvio-server it might be that you need calibration files for the tracking camera
                            • LipingL
                              Liping @Lynn Koudsi
                              @Lynn-Koudsi It shows waiting for imu and camera. Could you help to point out where is the calibration file located? Is it this calibration process (https://docs.modalai.com/calibrate-cameras/) that you refer to?
                              yocto:~# systemctl status voxl-qvio-server
                              ā— voxl-qvio-server.service - voxl-qvio-server
                                 Loaded: loaded (/usr/bin/voxl-qvio-server; disabled; vendor preset: enabled)
                                 Active: active (running) since Mon 2021-03-08 15:13:41 UTC; 7min ago
                               Main PID: 3199 (voxl-qvio-serve)
                                 CGroup: /system.slice/voxl-qvio-server.service
                                         └─3199 /usr/bin/voxl-qvio-server
                              Mar 08 15:13:42 apq8096 voxl-qvio-server[3199]: LNX_8096 supported? 1
                              Mar 08 15:13:42 apq8096 voxl-qvio-server[3199]: LNX_IA64 supported? 1
                              Mar 08 15:13:42 apq8096 voxl-qvio-server[3199]: WINDOWS supported? 0
                              Mar 08 15:13:42 apq8096 voxl-qvio-server[3199]: AR ERROR: arFileOpen(): Failed to open file: //vislam/Configuration.SF.xml
                              Mar 08 15:13:42 apq8096 voxl-qvio-server[3199]: FASTCV: fcvAvailableHardware Linux
                              Mar 08 15:13:42 apq8096 voxl-qvio-server[3199]: mempool cur block size 307200, new block size 307200
                              Mar 08 15:13:42 apq8096 voxl-qvio-server[3199]: Please ignore the error about Configuration.SF.xml above. ^^^
                              Mar 08 15:13:42 apq8096 voxl-qvio-server[3199]: It's an optional file, and should be a warning not an error
                              Mar 08 15:13:42 apq8096 voxl-qvio-server[3199]: waiting for imu
                              Mar 08 15:13:42 apq8096 voxl-qvio-server[3199]: waiting for cam
                              Before, I was using the following two command to set the configuration file:
                              voxl-configure-vision-px4
                              voxl-configure-modalai-vl
                              • Lynn KoudsiL
                                Lynn Koudsi @Liping
                                @Liping that's a curious problem... try checking the status of the imu and camera servers:
                                systemctl status voxl-camera-server
                                systemctl status voxl-imu-server
                                If you check the status of voxl-qvio again, does it say it failed? or it waits forever?
                                You should have the following calibration files:
                                etc/snav/calibration.stereo.xml
                                home/root/.ros/camera_info/left.yaml
                                home/root/.ros/camera_info/right.yaml
                                etc/snav/calibration.downward.xml
                                home/root/.ros/camera_info/downward.yaml
                                But I'm pretty sure you're going to need
                                /data/modalai/opencv_stereo_intrinsics.yml
                                /data/modalai/opencv_stereo_extrinsics.yml
                                I got those by running the calibration process you referenced.
                                • Lynn KoudsiL
                                  Lynn Koudsi @Lynn Koudsi
                                  @Liping I just realized that you don't have voxl-camera-server installed. You will need that. I also found that having both voxl-camera-server and voxl-cam-manager has given me some issues so I would recommend uninstalling voxl-cam-manager
                                  Lynn KoudsiL LipingL 2 Replies Last reply Reply Quote 0
                                  • Lynn KoudsiL
                                    @Liping I'm also curious as to where you got voxl_imu from... I don't think I've ever seen that. The correct package is voxl-imu-server and you can find it here. You would have to uninstall voxl_imu
                                    • LipingL
                                      Liping @Lynn Koudsi
                                      @Lynn-Koudsi Thanks a lot! The issue has been solved. The QGroundControl shows meaningful ODOMETRY data now. As you mentioned, the issue comes from the voxl-camera-server and voxl-imu-server. voxl-qvio can not get data from both the camera and the imu.
                                      Besides, I noticed that the configuration of the camera and imu does not work as expected. It may be caused by the conflict of the old (imp_app, voxl-cam-manager)and new (voxl-camera-server, voxl-imu-server) camera and imu ipk.
                                      To make it simple, I flashed the image with the System Image 3.2.0 (https://developer.modalai.com/asset/eula-download/64) without installing the voxl-suite, since I want to use the new Modal Pipe Architecture (https://gitlab.com/voxl-public/modal-pipe-architecture).
                                      I manually installed the following voxl packages:
                                      yocto:/#  opkg list-installed | grep "libmodal"
                                      libmodal_json - 0.3.4
                                      libmodal_pipe - 1.7.6
                                      yocto:/#  opkg list-installed | grep "voxl"
                                      libvoxl_io - 0.5.4
                                      voxl-camera-server - 0.5.5
                                      voxl-dfs-server - 0.0.7
                                      voxl-imu-server - 0.7.8
                                      voxl-utils - 0.5.9
                                      Then I run the configuration commands for the qvio, voxl-vision-px4 and camera (voxl-imu-server has done some default configuration during the ipk installation):
                                      yocto:/# voxl-configure-qvio -f
                                      rm: cannot remove '/etc/modalai/voxl-qvio-server.conf': No such file or directory
                                      loading qvio config file
                                      Creating new config file: /etc/modalai/voxl-qvio-server.conf
                                      The config file was modified during parsing, saving the changes to disk
                                      enabling voxl-qvio-server systemd service
                                      Created symlink from /etc/systemd/system/multi-user.target.wants/voxl-qvio-server.service to /etc/systemd/system/voxl-qvio-server.service.
                                      starting voxl-qvio-server systemd service
                                      Done configuring voxl-qvio-server
                                      yocto:/# voxl-configure-vision-px4 -f
                                      rm: cannot remove '/etc/modalai/voxl-vision-px4.conf': No such file or directory
                                      Created new empty json file: /etc/modalai/voxl-vision-px4.conf
                                      The JSON config file data was modified during parsing, saving the changes to disk
                                      enabling voxl-vision-px4 systemd service
                                      Created symlink from /etc/systemd/system/multi-user.target.wants/voxl-vision-px4.service to /etc/systemd/system/voxl-vision-px4.service.
                                      starting voxl-vision-px4 systemd service
                                      DONE configuring voxl-vision-px4
                                      yocto:/# voxl-configure-cameras
                                      Regarding the configuration of the camera, i was following the guidance in https://gitlab.com/voxl-public/modal-pipe-architecture/voxl-camera-server to use the command voxl-configure-cameras provided by voxl-utils package.
                                      I rebooted the VOXL and checked related services (camera, imu, qvio, voxl-vision-px4) using
                                      systemctl status
                                      But I noticed that the voxl-camera-server was not automaticly started on boot.
                                      So I enabled it with:
                                      yocto:/# systemctl enable voxl-camera-server
                                      @modaltb Please correct me if any step was not right or there is a better way.
                                      In addition, I also followed the https://forum.modalai.com/topic/70/warning-px4-disconnected-error-message-from-voxl-vision-px4 to solve the WARNING PX4 DISCONNECTED error message from voxl-vision-px4
                                      • modaltbM
                                        WOW! Thanks @Lynn-Koudsi for the help, when we setup the forum this is the kind of interaction we were hoping for, just awesome!!
                                        Sorry for the setup and 'wonkyness' right now, we've been somewhat caught with getting pre-release software out there without all the setup/docs lined up.... so we're doing a little catchup it seems.
                                        @Liping there until we have our docs updated, if this is working, I'd say this is a good approach!
                                        Thank you both for the details, we'll relay this through the team.
