  3. VIO Indoor Navigation
18 Posts 4 Posters 4.6k Views 4 Watching
  • modaltbM modaltb
    Hi @Lynn-Koudsi ,
    Hmmm, this one is confusing me a bit, if you're available maybe we could setup a screen share on Monday to troubleshoot? I'm be available 8:15-10:00, 12-2 and 4-5 PST, or Tuesday anytime after 8:15 AM PST.
    Thanks!!
    Lynn KoudsiL Offline
    Lynn Koudsi
    @modaltb 12-2 works!
    Also just for more context, I had done a clean image installation at V3.1.0 and had removed my data folder. I'm thinking the issue is that calibration files are not there. I tried running voxl-cam-ros but it's not finding left and right yaml files. I tried just pushing the sample calibration files from https://gitlab.com/voxl-public/utilities/voxl-camera-calibration but it won't find ost.yaml.
    So I guess my question is, is there a default data folder available online? Or can you provide the default factory data folder?
    • modaltbM Offline
      modaltbM Offline
      modaltb
      Just sent out an invite for tomorrow, if I can get the SN of the m500 I can get you the calibration files we have in our production database in advance and that might get things going!
      Lynn KoudsiL 1 Reply Last reply
      • modaltbM modaltb
        Lynn Koudsi
        @modaltb Thank you!
        Serial# is M20000000TJ
        • LipingL Offline
          LipingL Offline
          Liping
          Hi @modaltb
          I'm getting the same problem as described by Lynn. I had also done a clean image installation at V3.1.0 and had removed my data folder.
          yocto:~# voxl-vision-px4 -o
          loading our own config file
          qgc_ip:                     192.168.43.84
          en_localhost_mavlink_udp    1
          en_secondary_qgc:           0
          qgc_udp_port_number:        14550
          en_vio:                     1
          en_voa:                     0
          en_send_vio_to_qgc:         0
          en_send_voa_to_qgc:         0
          en_adsb:                    1
          adsb_uart_bus:              7
          adsb_uart_baudrate:         57600
          px4_uart_bus:               5
          px4_uart_baudrate:          921600
          follow_tag_id:              0
          en_apriltag_fixed_frame:    0
          fixed_frame_filter_len:     5
          loading extrinsics and apriltag external config files
          #0:
              tag id:          0
              size_m:            0.400
              T_tag_wrt_fixed: 0.0  0.0  0.0
              R_tag_to_fixed:  0.0 -1.0  0.0
                               1.0  0.0  0.0
                               0.0  0.0  1.0
          #1:
              tag id:          1
              size_m:            0.400
                               1.0  0.0  0.0
                               0.0  0.0  1.0
          loaded in 2 fixed apriltags
          #0:
              parent:                imu1
              child:                 imu0
              T_child_wrt_parent:   -0.048   0.037   0.002
              RPY_parent_to_child:   0.0     0.0     0.0
              R_child_to_parent:     1.000  -0.000   0.000
                                     0.000   1.000  -0.000
                                     0.000   0.000   1.000
          #1:
              parent:                imu0
              child:                 tracking
              T_child_wrt_parent:    0.065  -0.014   0.013
              RPY_parent_to_child:   0.0    45.0    90.0
              R_child_to_parent:     0.000  -0.707   0.707
                                     1.000   0.000  -0.000
                                    -0.000   0.707   0.707
          #2:
              parent:                imu1
              child:                 tracking
              T_child_wrt_parent:    0.017   0.015   0.013
                                     1.000   0.000  -0.000
                                    -0.000   0.707   0.707
          #3:
              parent:                body
              child:                 imu0
              T_child_wrt_parent:    0.020   0.014  -0.008
                                     0.000   1.000  -0.000
                                     0.000   0.000   1.000
          #4:
              parent:                body
              child:                 imu1
              T_child_wrt_parent:    0.068  -0.015  -0.008
                                     0.000   1.000  -0.000
                                     0.000   0.000   1.000
          #5:
              parent:                body
              child:                 stereo_l
              T_child_wrt_parent:    0.100  -0.040   0.000
              RPY_parent_to_child:   0.0    90.0    90.0
              R_child_to_parent:     0.000  -0.000   1.000
                                     1.000   0.000  -0.000
                                    -0.000   1.000   0.000
          #6:
              parent:                body
              child:                 tof
              T_child_wrt_parent:    0.100   0.000   0.000
                                     1.000   0.000  -0.000
                                    -0.000   1.000   0.000
          #7:
              parent:                body
              child:                 ground
              T_child_wrt_parent:    0.000   0.000   0.100
                                     0.000   1.000  -0.000
                                     0.000   0.000   1.000
          exising instance of voxl-vision-px4 found, attempting to stop it
          starting geometry module
          starting uart mavlink
          Successfully opened mavparser
          starting udp mavlink
          Detected PX4 Mavlink SYSID 1
          Adding manual QGC IP address to udp connection list: 192.168.43.84
          Added new UDP connection to 192.168.43.84
          starting px4 shell
          starting fixed pose input
          starting vio manager
          starting apriltag manager
          starting adsb manager
          ADSB thread starting
          PX4 Connected over UART with sysid 1
          But when I run 'voxl-test-vision-lib -o' I can see the VIO works.
          [6619.210687] SNAV INFO: IMU sensor finished initializing.
          [6619.211066] SNAV INFO: IMU sensor settings retrieved.
          [6619.211122] SNAV INFO: Creating IMU thread.
          [6619.211332] SNAV INFO: Creating VISLAM processing thread.
          [6619.211463] SNAV INFO: ImuManager thread has tid = 3558, nice = -15
          [6619.211483] SNAV INFO: Creating VISLAM publishing thread.
          [6619.211768] SNAV INFO: VISLAM publishing thread has tid = 3560, nice = -5
          VIO camera frame: points:  0 X:  0.000 Y:  0.000 Z:  0.000 R:  0.000 P: -0.000 Y:  0.000
          [6619.211958] SNAV INFO: VISLAM processing thread has tid = 3559, nice = -5
          VIO camera frame: points: 39 X:  0.000 Y:  0.000 Z:  0.000 R:  0.000 P: -0.000 Y:  0.000
          VIO camera frame: points: 39 X: -0.000 Y:  0.000 Z: -0.000 R: -0.000 P: -0.000 Y: -0.000
          VIO camera frame: points: 39 X: -0.000 Y:  0.000 Z:  0.000 R: -0.000 P:  0.000 Y: -0.000
          VIO camera frame: points: 39 X: -0.000 Y:  0.001 Z:  0.000 R: -0.001 P: -0.000 Y: -0.000
          VIO camera frame: points: 39 X: -0.001 Y: -0.002 Z: -0.005 R:  0.001 P: -0.001 Y: -0.000
          VIO camera frame: points: 39 X:  0.000 Y: -0.000 Z: -0.008 R:  0.000 P: -0.001 Y: -0.001
          VIO camera frame: points: 39 X: -0.000 Y: -0.001 Z: -0.010 R:  0.001 P: -0.002 Y: -0.001
          VIO camera frame: points: 39 X: -0.000 Y: -0.000 Z: -0.014 R:  0.002 P: -0.003 Y: -0.001
          VIO camera frame: points: 39 X:  0.002 Y:  0.002 Z: -0.019 R:  0.001 P: -0.003 Y: -0.002
          VIO camera frame: points: 39 X:  0.003 Y:  0.002 Z: -0.022 R:  0.001 P: -0.004 Y: -0.002
          VIO camera frame: points: 39 X:  0.004 Y:  0.002 Z: -0.023 R:  0.001 P: -0.004 Y: -0.001
          VIO camera frame: points: 39 X:  0.004 Y:  0.001 Z: -0.020 R:  0.001 P: -0.004 Y: -0.001
          VIO camera frame: points: 39 X:  0.002 Y:  0.001 Z: -0.015 R:  0.001 P: -0.004 Y: -0.001
          In QGroundControl, I can not see the ODOMETRY section in the MAVLink inspector.
          My serial # M20000005GT
          • LipingL Liping
            Hi @modaltb
            en_secondary_qgc:           0
            en_vio:                     1
            en_voa:                     0
            en_adsb:                    1
            adsb_uart_bus:              7
            px4_uart_bus:               5
            follow_tag_id:              0
            #0:
                tag id:          0
                size_m:            0.400
                                 1.0  0.0  0.0
                                 0.0  0.0  1.0
            #1:
                tag id:          1
                size_m:            0.400
                                 1.0  0.0  0.0
                                 0.0  0.0  1.0
            #0:
                parent:                imu1
                child:                 imu0
                                       0.000   1.000  -0.000
                                       0.000   0.000   1.000
            #1:
                parent:                imu0
                child:                 tracking
                                       1.000   0.000  -0.000
                                      -0.000   0.707   0.707
            #2:
                parent:                imu1
                child:                 tracking
                                       1.000   0.000  -0.000
                                      -0.000   0.707   0.707
            #3:
                parent:                body
                child:                 imu0
                                       0.000   1.000  -0.000
                                       0.000   0.000   1.000
            #4:
                parent:                body
                child:                 imu1
                                       0.000   1.000  -0.000
                                       0.000   0.000   1.000
            #5:
                parent:                body
                child:                 stereo_l
                                       1.000   0.000  -0.000
                                      -0.000   1.000   0.000
            #6:
                parent:                body
                child:                 tof
                                       1.000   0.000  -0.000
                                      -0.000   1.000   0.000
            #7:
                parent:                body
                child:                 ground
                                       0.000   1.000  -0.000
                                       0.000   0.000   1.000
            starting px4 shell
            Lynn Koudsi
            wrote on last edited by Lynn Koudsi
            #10
            @Liping My issue was resolved by installing voxl-qvio. You can reference the diagram here to learn what services are needed for the different interactions.
            LipingL 1 Reply Last reply
            • Lynn KoudsiL Lynn Koudsi
              LipingL Offline
              LipingL Offline
              Liping
              @Lynn-Koudsi Thanks Lynn. But in my case, the issue still exists after installing the voxl-qvio.
              What are your installed voxl package versions?
              I installed some latest stable version packages.
              yocto:~#  opkg list-installed | grep "voxl"
              libvoxl_io - 0.5.4
              voxl-cam-manager - 0.2.2
              voxl-docker-support - 1.1.1
              voxl-hal3-tof-cam-ros - 0.0.2
              voxl-modem - 0.10.0
              voxl-mpa-tools - 0.1.6
              voxl-nodes - 0.0.8
              voxl-qvio-server - 0.2.1
              voxl-rtsp - 1.0.2
              voxl-time-sync - 0.0.1
              voxl-utils - 0.5.2
              voxl-vision-px4 - 0.8.1
              voxl-vpn - 0.0.2
              voxl_imu - 0.0.4
              • LipingL Liping
                libvoxl_io - 0.5.4
                voxl-modem - 0.10.0
                voxl-nodes - 0.0.8
                voxl-rtsp - 1.0.2
                voxl-utils - 0.5.2
                voxl-vpn - 0.0.2
                voxl_imu - 0.0.4
                Lynn Koudsi
                @Liping Is voxl-qvio actually running? You can check by calling systemctl status voxl-qvio-server it might be that you need calibration files for the tracking camera
                  LipingL Offline
                  LipingL Offline
                  Liping
                  @Lynn-Koudsi It shows waiting for imu and camera. Could you help to point out where is the calibration file located? Is it this calibration process (https://docs.modalai.com/calibrate-cameras/) that you refer to?
                  yocto:~# systemctl status voxl-qvio-server
                  ● voxl-qvio-server.service - voxl-qvio-server
                     Loaded: loaded (/usr/bin/voxl-qvio-server; disabled; vendor preset: enabled)
                     Active: active (running) since Mon 2021-03-08 15:13:41 UTC; 7min ago
                   Main PID: 3199 (voxl-qvio-serve)
                     CGroup: /system.slice/voxl-qvio-server.service
                             └─3199 /usr/bin/voxl-qvio-server
                  Mar 08 15:13:42 apq8096 voxl-qvio-server[3199]: LNX_8096 supported? 1
                  Mar 08 15:13:42 apq8096 voxl-qvio-server[3199]: LNX_IA64 supported? 1
                  Mar 08 15:13:42 apq8096 voxl-qvio-server[3199]: WINDOWS supported? 0
                  Mar 08 15:13:42 apq8096 voxl-qvio-server[3199]: AR ERROR: arFileOpen(): Failed to open file: //vislam/Configuration.SF.xml
                  Mar 08 15:13:42 apq8096 voxl-qvio-server[3199]: FASTCV: fcvAvailableHardware Linux
                  Mar 08 15:13:42 apq8096 voxl-qvio-server[3199]: mempool cur block size 307200, new block size 307200
                  Mar 08 15:13:42 apq8096 voxl-qvio-server[3199]: Please ignore the error about Configuration.SF.xml above. ^^^
                  Mar 08 15:13:42 apq8096 voxl-qvio-server[3199]: It's an optional file, and should be a warning not an error
                  Mar 08 15:13:42 apq8096 voxl-qvio-server[3199]: waiting for imu
                  Mar 08 15:13:42 apq8096 voxl-qvio-server[3199]: waiting for cam
                  Before, I was using the following two command to set the configuration file:
                  voxl-configure-vision-px4
                  voxl-configure-modalai-vl
                  • LipingL Liping
                    Lynn Koudsi
                    #14
                    @Liping that's a curious problem... try checking the status of the imu and camera servers:
                    systemctl status voxl-camera-server
                    systemctl status voxl-imu-server
                    If you check the status of voxl-qvio again, does it say it failed? or it waits forever?
                    You should have the following calibration files:
                    etc/snav/calibration.stereo.xml
                    home/root/.ros/camera_info/left.yaml
                    home/root/.ros/camera_info/right.yaml
                    etc/snav/calibration.downward.xml
                    home/root/.ros/camera_info/downward.yaml
                    But I'm pretty sure you're going to need
                    /data/modalai/opencv_stereo_intrinsics.yml
                    /data/modalai/opencv_stereo_extrinsics.yml
                    I got those by running the calibration process you referenced.
                      Lynn Koudsi
                      @Liping I just realized that you don't have voxl-camera-server installed. You will need that. I also found that having both voxl-camera-server and voxl-cam-manager has given me some issues so I would recommend uninstalling voxl-cam-manager
                      Lynn KoudsiL LipingL 2 Replies Last reply
                        Lynn Koudsi
                        @Liping I'm also curious as to where you got voxl_imu from... I don't think I've ever seen that. The correct package is voxl-imu-server and you can find it here. You would have to uninstall voxl_imu
                          LipingL Offline
                          LipingL Offline
                          Liping
                          @Lynn-Koudsi Thanks a lot! The issue has been solved. The QGroundControl shows meaningful ODOMETRY data now. As you mentioned, the issue comes from the voxl-camera-server and voxl-imu-server. voxl-qvio can not get data from both the camera and the imu.
                          Besides, I noticed that the configuration of the camera and imu does not work as expected. It may be caused by the conflict of the old (imp_app, voxl-cam-manager)and new (voxl-camera-server, voxl-imu-server) camera and imu ipk.
                          To make it simple, I flashed the image with the System Image 3.2.0 (https://developer.modalai.com/asset/eula-download/64) without installing the voxl-suite, since I want to use the new Modal Pipe Architecture (https://gitlab.com/voxl-public/modal-pipe-architecture).
                          I manually installed the following voxl packages:
                          yocto:/#  opkg list-installed | grep "libmodal"
                          libmodal_json - 0.3.4
                          libmodal_pipe - 1.7.6
                          yocto:/#  opkg list-installed | grep "voxl"
                          libvoxl_io - 0.5.4
                          voxl-camera-server - 0.5.5
                          voxl-dfs-server - 0.0.7
                          voxl-imu-server - 0.7.8
                          voxl-utils - 0.5.9
                          Then I run the configuration commands for the qvio, voxl-vision-px4 and camera (voxl-imu-server has done some default configuration during the ipk installation):
                          yocto:/# voxl-configure-qvio -f
                          rm: cannot remove '/etc/modalai/voxl-qvio-server.conf': No such file or directory
                          loading qvio config file
                          Creating new config file: /etc/modalai/voxl-qvio-server.conf
                          The config file was modified during parsing, saving the changes to disk
                          enabling voxl-qvio-server systemd service
                          Created symlink from /etc/systemd/system/multi-user.target.wants/voxl-qvio-server.service to /etc/systemd/system/voxl-qvio-server.service.
                          starting voxl-qvio-server systemd service
                          Done configuring voxl-qvio-server
                          yocto:/# voxl-configure-vision-px4 -f
                          rm: cannot remove '/etc/modalai/voxl-vision-px4.conf': No such file or directory
                          Created new empty json file: /etc/modalai/voxl-vision-px4.conf
                          The JSON config file data was modified during parsing, saving the changes to disk
                          enabling voxl-vision-px4 systemd service
                          Created symlink from /etc/systemd/system/multi-user.target.wants/voxl-vision-px4.service to /etc/systemd/system/voxl-vision-px4.service.
                          starting voxl-vision-px4 systemd service
                          DONE configuring voxl-vision-px4
                          yocto:/# voxl-configure-cameras
                          Regarding the configuration of the camera, i was following the guidance in https://gitlab.com/voxl-public/modal-pipe-architecture/voxl-camera-server to use the command voxl-configure-cameras provided by voxl-utils package.
                          I rebooted the VOXL and checked related services (camera, imu, qvio, voxl-vision-px4) using
                          systemctl status
                          But I noticed that the voxl-camera-server was not automaticly started on boot.
                          So I enabled it with:
                          yocto:/# systemctl enable voxl-camera-server
                          @modaltb Please correct me if any step was not right or there is a better way.
                          In addition, I also followed the https://forum.modalai.com/topic/70/warning-px4-disconnected-error-message-from-voxl-vision-px4 to solve the WARNING PX4 DISCONNECTED error message from voxl-vision-px4
                          • modaltbM Offline
                            modaltbM Offline
                            modaltb
                            WOW! Thanks @Lynn-Koudsi for the help, when we setup the forum this is the kind of interaction we were hoping for, just awesome!!
                            Sorry for the setup and 'wonkyness' right now, we've been somewhat caught with getting pre-release software out there without all the setup/docs lined up.... so we're doing a little catchup it seems.
                            @Liping there until we have our docs updated, if this is working, I'd say this is a good approach!
                            Thank you both for the details, we'll relay this through the team.
