  3. m500 enabling RTK GPS
m500
18 Posts 4 Posters 3.4k Views 1 Watching
  • X Offline
    X Offline
    xav04
    wrote on last edited by xav04
    Hi @Eric-Katzfey and @yu-zhang. I'm trying to use the same module you're talking about in this chat (https://www.sparkfun.com/products/15136) with VOXL2, but I haven't been able to get it to work. I would like to know if it is compatible with VOXL2 and what would be the steps to make it work. Thanks!
    • X xav04
      @xav04 We have not tried that GPS board with VOXL 2. The PX4 implementation on VOXL 2 is custom and many device drivers need modification to be able to run correctly. That is because the architecture is split between the applications processor (ARM multicore running Linux) and a DSP running an RTOS. Most device drivers run on the DSP and due the differences in the environment need customization. However, you could run the GPS driver on the applications processor instead. It's much more likely that you can use the standard PX4 GPS driver on the applications processor without customization. However, you would need to have access to a UART that is visible from the applications processor for IO. This add on board would provide that: https://www.modalai.com/collections/voxl-2-add-ons/products/usb-3-uart-expansion-adapter?variant=40740708876339. If you were to use that board, what would you be using for a compass (magnetometer)?
      X 1 Reply Last reply
        X Offline
        X Offline
        xav04
        @Eric-Katzfey Thanks for your reply! I'm not quite sure what compass I'm going to use, but if you know of any reliable module, I'd really appreciate it if you let me know. On the other hand, I may not be able to use that board since I'm using the 5G Modem Carrier Board which uses the same port (J3) as the VOXL 2 USB3.0 / UART Expansion Adapter. Is there any other way to connect this add on board or the gps?
        • X xav04
          @xav04 I'll see if I can get any recommendations on compass, but usually these come integrated with the GPS. I think the best way to use the sparkfun GPS will be to try to get it going on the DSP. I'll take a look at it and see if there is an easy way to get it working.
            X Offline
            X Offline
            xav04
            @Eric-Katzfey Thank you very much! I will be waiting for your message
            • yu zhangY Offline
              yu zhangY Offline
              yu zhang
              Hi @xav04, GPS board on VOXL 1 can work with sparkfun GPS via the standard PX4 GPS driver.
              I went to Holybro F9P instead of the sparkfun, and it works fine with VOXL 1. For VOXL 2, as Eric said, you may have access to a UART to see if it works.
              • X Offline
                X Offline
                xav04
                Hi @yu-zhang, thank you for your reply! To give you more context, I'm using VOXL2 with the 5G Modem Carrier Board, so I'm not able to use the VOXL 2 USB3.0 / UART Expansion as @Eric-Katzfey suggested to access to that UART port. However, I found that the 5G Modem, in the J9 port has an i2c+Apps UART. Do you think I could use this port to connect the sparkfun via the standard PX4 GPS driver?
                Also, do you know if the Holybro F9P comes with a PX4 compatible built-in compass?
                Eric KatzfeyE S 3 Replies Last reply
                • X xav04
                  @xav04 According to their spec http://www.holybro.com/manual/Holybro_H-RTK_F9P_GNSS_Spec.pdf it does have an ist8310 magnetometer which is supported by VOXL 2.
                  • X xav04
                    @xav04 Yes, the M0090 5G board does have a UART and I2C that you can use on J9.
                    • X Offline
                      X Offline
                      xav04
                      @Eric-Katzfey and @yu-zhang thank you very much! I'll get the module and test it.
                      • X xav04
                        S Offline
                        S Offline
                        SMRazaRizvi
                        @xav04 I am trying to do the same thing as you, by using the J9 port on the 5G Modem to attach an RTK GPS.
                        Were you able to do so?
