  3. "make modalai_rb5-flight_default" target not found while PX4 build
15 Posts 2 Posters 2.2k Views 1 Watching
  • A aquibrifath
    Hi i was trying to build PX4 on VOXL2 using https://gitlab.com/voxl-public/rb5-flight/rb5-flight-px4-build-docker/-/tree/master guide
    when i was in the docker running make modalai_rb5-flight_default gave me the following error
    root@da81ab4039ae:/usr/local/workspace/px4-firmware# make modalai_rb5-flight_default
    Makefile:528: *** "Make target modalai_rb5-flight_default not found. It either does not exist or modalai_rb5-flight_default cannot be the first argument. Use 'make help|list_config_targets' to get a list of all possible [configuration] targets.". Stop.
    so i ran make help to check
    root@da81ab4039ae:/usr/local/workspace/px4-firmware# make help
    Usage: make <target>
    Where <target> is one of:
    airframe_metadata
    airmind_mindpx-v2
    all
    all_config_targets
    all_default_targets
    ark_can-flow
    ark_can-gps
    ark_can-rtk-gps
    ark_cannode
    atl_mantis-edu
    av_x-v1
    beaglebone_blue
    bitcraze_crazyflie
    bitcraze_crazyflie21
    bootloaders_update
    check
    check_format
    check_linux
    check_nuttx
    check_nxp
    check_px4
    check_rtps
    clang-tidy
    clang-tidy-fix
    clang-tidy-quiet
    clean
    coverity_scan
    cppcheck
    cuav_can-gps-v1
    cuav_nora
    cuav_x7pro
    cubepilot_cubeorange
    cubepilot_cubeyellow
    cubepilot_io-v2
    diatone_mamba-f405-mk2
    distclean
    doxygen
    emlid_navio2
    extract_events
    format
    freefly_can-rtk-gps
    gazeboclean
    help
    holybro_can-gps-v1
    holybro_durandal-v1
    holybro_kakutef7
    holybro_kakuteh7
    holybro_pix32v5
    list_config_targets
    matek_gnss-m9n-f4
    matek_h743
    matek_h743-mini
    matek_h743-slim
    misc_qgc_extra_firmware
    modalai_fc-v1
    modalai_fc-v2
    module_documentation
    mro_ctrl-zero-classic
    mro_ctrl-zero-f7
    mro_ctrl-zero-f7-oem
    mro_ctrl-zero-h7
    mro_ctrl-zero-h7-oem
    mro_pixracerpro
    mro_x21
    mro_x21-777
    nxp_fmuk66-e
    nxp_fmuk66-v3
    nxp_fmurt1062-v1
    nxp_ucans32k146
    omnibus_f4sd
    parameters_metadata
    px4_fmu-v2
    px4_fmu-v3
    px4_fmu-v4
    px4_fmu-v4pro
    px4_fmu-v5
    px4_fmu-v5x
    px4_fmu-v6c
    px4_fmu-v6u
    px4_fmu-v6x
    px4_io-v2
    px4_metadata
    px4_raspberrypi
    px4_sitl
    px4_sitl_default-clang
    px4fmu_firmware
    px4io_update
    python_coverage
    qgc_firmware
    quick_check
    raspberrypi_pico
    rostest
    rostest_run
    scan-build
    scumaker_pilotpi
    shellcheck_all
    sizes
    sky-drones_smartap-airlink
    spracing_h7extreme
    submodulesclean
    submodulesupdate
    tests
    tests_avoidance
    tests_coverage
    tests_integration
    tests_integration_coverage
    tests_mission
    tests_mission_coverage
    tests_offboard
    uorb_graphs
    update_px4_msgs
    update_px4_ros_com
    update_ros2_bridge
    updateconfig
    uvify_core
    validate_module_configs
    Or, make <config_target> [<make_target(s)>]
    Use 'make list_config_targets' for a list of configuration targets.
    and i noticed that modalai_rb5-flight_default is not found, can you help me with this?
    @aquibrifath What version of px4 are you trying to build? After you clone the repository, which branch are you checking out?
    • A Offline
      aquibrifath
      @Eric-Katzfey oh i forgot to add that, tried the latest version, 1.13.0 stable and using the main branch
      • A aquibrifath
        @aquibrifath You have to clone this repo: https://github.com/modalai/px4-firmware.git and checkout branch voxl-dev.
        • A Offline
          aquibrifath
          Will try that, thank you
          • A Offline
            aquibrifath
            Hello, how do you burn PX4 to VOXL2? using make upload or QGC?
            • A aquibrifath
              @aquibrifath Our "wrapper" project is this: https://gitlab.com/voxl-public/voxl-sdk/services/voxl-px4. You can use master or dev branch to get the latest. This project will create a debian package that you can push to target and install.
              • A Offline
                aquibrifath
                do we need VOXL suite or anything of that sort? I just want to upload the lastest PX4 and do a manual flight on VOXL2 to make sure my hardware is running okay, I am trying the PX4 wrapper that you suggested
                • A Offline
                  aquibrifath
                  @Eric-Katzfey Okay, i did everything in https://gitlab.com/voxl-public/voxl-sdk/services/voxl-px4, but it did not create any debain package, can you help me locate it?
                  As far as i have understood, the PX4 images are build inside PX4/built
                  • A aquibrifath
                    @aquibrifath You can always get our latest PX4 dev package from our package feed. wget http://voxl-packages.modalai.com/dists/qrb5165/dev/binary-arm64/voxl-px4_1.4.24-202208252217_arm64.deb
                    A 1 Reply Last reply
                    • A aquibrifath
                      @aquibrifath The package is created when you run the ./make_package.sh deb script.
                        aquibrifath
                        wrote on last edited by aquibrifath
                        #12
                        @Eric-Katzfey all the packages here http://voxl-packages.modalai.com/dists are for arm64 architecture, am i supposed to run this on VOXL or my PC?
                          aquibrifath
                          @Eric-Katzfey okay i ran the ./make_package.sh and it created a voxl-px4_1.4.16_arm64.deb, should i send to VOXL2 via adb push and unpack it via dpkg?
                          • A aquibrifath
                            @aquibrifath Yep!
                            • A Offline
                              aquibrifath
                              #15
                              directly in the main folder or do i have to do it in the sub folder? @Eric-Katzfey
