  3. HITL with voxl 2
HITL with voxl 2
24 Posts 4 Posters 7.3k Views 1 Watching
    @Tamas-Pal-0 For UART it is just GND, TX, and RX
    Tamas Pal 0T Offline
    Tamas Pal 0
    @Eric-Katzfey you mean we only have to connect 3 pins in j18 port ?
    • Tamas Pal 0T Tamas Pal 0
      @Tamas-Pal-0 Yes, the fourth pin is power and we don't want that one.
      • Tamas Pal 0T Offline
        Tamas Pal 0
        Is there any way to verify that FTDI cable is connected properly with J18 port ?
          #16
          @Tamas-Pal-0 The easiest way would be to recompile the modalai_dsp PX4 driver to add more debug messages. But if you aren't comfortable with that then we'll need to come up with something else.
            Tamas Pal 0
            wrote on last edited by Tamas Pal 0
            #17
            How to do that? Is there any other way to this ?
              @Tamas-Pal-0 The simulator will be sending heartbeat messages out over the serial cable. You can use the screen program to see if anything is coming from voxl 2 in the serial cable.
              Tamas Pal 0T 1 Reply Last reply
                Tamas Pal 0
                @Eric-Katzfey How to use screen program in this case ?
                  @Tamas-Pal-0 screen is just a standard Linux program. There are many ways to check the output of the serial port. To start, you could always just do cat /dev/ttyUSB0 and see if anything is coming out. This post shows how to get a hex dump: https://superuser.com/questions/1402386/view-serial-device-output-in-console-in-hex
                    Tamas Pal 0
                    #21
                    The problem is solved. The problem was with ftdi cable. Thank you for your valuable inputs
                      @Tamas-Pal-0 Excellent! How were you able to determine that it was the cable?
                      • Taylor PresleyT Offline
                        Taylor Presley
                        @Eric-Katzfey @Tamas-Pal-0 For future users troubleshooting HITL setup, I was having the same issue as above. This cable would not allow me to set the latency or share data with the VOXL 2 through J18 port, but this cable works as intended.
                        • Taylor PresleyT Taylor Presley
                          Tamas Pal 0
                          #24
                          @Taylor-Presley Right. Some cables work some don't.
