  3. HITL with voxl 2
HITL with voxl 2
24 Posts 4 Posters 6.9k Views 1 Watching
    @Tamas-Pal-0 I'm not sure. This works in our development environment so something must be different in your environment. What version of Linux are you using? What cable are you using?
    Tamas Pal 0T Offline
    Tamas Pal 0
    The issue is fixed. It was a hardware issue. I changed the ftdi cable and the issue was solved. The previous FTDI cable was not allowing me to change anything in /sys/bus/usb-serial/devices/ttyUSB0 directory. The file latency_timer was also not there. However with the other cable, there is no such issue. Thank you for your valuable input.
    • Tamas Pal 0T Offline
      Tamas Pal 0
      For 3.3v J18 jst port which port of ftdi cable should be used, CTS# or RTS# ?
      • Tamas Pal 0T Tamas Pal 0
        @Tamas-Pal-0 For UART it is just GND, TX, and RX
        Tamas Pal 0T 1 Reply Last reply
          Tamas Pal 0
          @Eric-Katzfey you mean we only have to connect 3 pins in j18 port ?
            @Tamas-Pal-0 Yes, the fourth pin is power and we don't want that one.
              Tamas Pal 0
              Is there any way to verify that FTDI cable is connected properly with J18 port ?
                #16
                @Tamas-Pal-0 The easiest way would be to recompile the modalai_dsp PX4 driver to add more debug messages. But if you aren't comfortable with that then we'll need to come up with something else.
                  Tamas Pal 0
                  wrote on last edited by Tamas Pal 0
                  #17
                  How to do that? Is there any other way to this ?
                    @Tamas-Pal-0 The simulator will be sending heartbeat messages out over the serial cable. You can use the screen program to see if anything is coming from voxl 2 in the serial cable.
                      Tamas Pal 0
                      @Eric-Katzfey How to use screen program in this case ?
                        @Tamas-Pal-0 screen is just a standard Linux program. There are many ways to check the output of the serial port. To start, you could always just do cat /dev/ttyUSB0 and see if anything is coming out. This post shows how to get a hex dump: https://superuser.com/questions/1402386/view-serial-device-output-in-console-in-hex
                          Tamas Pal 0
                          #21
                          The problem is solved. The problem was with ftdi cable. Thank you for your valuable inputs
                            @Tamas-Pal-0 Excellent! How were you able to determine that it was the cable?
                            • Taylor PresleyT Offline
                              Taylor Presley
                              @Eric-Katzfey @Tamas-Pal-0 For future users troubleshooting HITL setup, I was having the same issue as above. This cable would not allow me to set the latency or share data with the VOXL 2 through J18 port, but this cable works as intended.
                              • Taylor PresleyT Taylor Presley
                                Tamas Pal 0
                                #24
                                @Taylor-Presley Right. Some cables work some don't.
