  3. Unable to access px4 with qgc in voxl 2 using usb-jst cable
15 Posts 4 Posters 2.8k Views 3 Watching
  • modaltbM Offline
    modaltbM Offline
    modaltb
    Hi @Tamas-Pal-0 ,
    On VOXL2 J18 is a UART that connects to the DSP that is used for ESCs --> https://docs.modalai.com/voxl2-connectors/#j18-uart-esc
    At this time, you need to use an IP connection to get to QGC.... Here's some options that I use on my bench:
    https://docs.modalai.com/voxl2-hardware-setup/#wi-fi-connectivity
    https://docs.modalai.com/voxl2-hardware-setup/#ethernet-connectivity
    That cable above works with the STM32 based flight controller (Flight Core and VOXL Flight) but not on J18 of VOXL2.
    • Tamas Pal 0T Offline
      Tamas Pal 0
      @MODALTB could you please share a dedicated manual for running hitl with voxl 2 only ?
      https://docs.modalai.com/voxl2-PX4-hitl/
      The docs webpage is a bit confusing
      • Zachary LowellZ Offline
        Zachary Lowell
        Hi Tamas, this video is how to get the voxl2 running with HITL: https://www.youtube.com/watch?v=ysvpJdXFWaM&ab_channel=AscendEngineering
        Also - unless you are running the voxl-dev branch, then you will not be able to do a SERIAL connection from the voxl2 to QGC, you can only leverage a UDP connection. If you are running the voxl-dev branch and flashed the board, then you can leverage the voxl-px4-hitl executable and connect to QGC. However, you cannot have gazebo open simultaneously because the serial connection will then be interrupted.
        If you wish to run HITL while running QGC, then run this using an FTDI cable and then turn on the required services (voxl-vision-px4, voxl-mavlink-server) and then connect to gazebo serially, and QGC via UDP signal.
        Let me know if this makes sense.
          Tamas Pal 0
          I have flashed the voxl-dev branch files to the voxl 2's /etc/modalai/ folder. It seems like voxl-dev branch's voxl-px4-hitl is not an executable file. I am facing this issue.
          voxl2:~$ voxl-px4-hitl
          bash: voxl-px4-hitl: command not found
          How to fix the problem?
          • Tamas Pal 0T Tamas Pal 0
            @Tamas-Pal-0 You can get a voxl-dev branch package from here: http://voxl-packages.modalai.com/dists/qrb5165/dev/binary-arm64/voxl-px4_1.4.19-202208111710_arm64.deb. Install that package instead of trying to copy files over manually.
            Tamas Pal 0T 1 Reply Last reply
              Tamas Pal 0
              The voxl-px4-hitl is still missing in the package. I have installed it and tried to run voxl-px4-hitl command. It is not working. I have shared the terminal syntax below. How to fix it?
              voxl2:/$ sudo dpkg -i voxl-px4_1.4.19-202208111710_arm64.deb
              (Reading database ... 81777 files and directories currently installed.)
              Preparing to unpack voxl-px4_1.4.19-202208111710_arm64.deb ...
              Unpacking voxl-px4 (1.4.19-202208111710) over (1.4.19-202208111710) ...
              Setting up voxl-px4 (1.4.19-202208111710) ...
              Found DSP signature file
              voxl2:/$ sudo apt-get install -f
              Reading package lists... Done
              Building dependency tree
              0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
              voxl2:/$ voxl-px4-hitl
              bash: /usr/bin/voxl-px4-hitl: Permission denied
              voxl2:/$ sudo voxl-px4-hitl
              sudo: voxl-px4-hitl: command not found
                Zachary Lowell
                Hi Tamas - please run a chmod +x /usr/bin/voxl-px4-hitl and that will enable permissions. After running that, you can run voxl-px4-hitl from any directory and it will work.
                • Zachary LowellZ Zachary Lowell
                  Tamas Pal 0
                  wrote on last edited by Tamas Pal 0
                  #9
                  @Zachary-Lowell
                  Aftert running the voxl-px4-hitl command I am still gettting an output like this. Is it fine? If not how to solve the problem?
                  voxl2:/usr/bin$ chmod +x /usr/bin/voxl-px4-hitl
                  voxl2:/usr/bin$ voxl-px4-hitl
                  Setting GPS Parameters for HITL
                  INFO  [px4] PX4 daemon already running for instance 0 (Success)
                  voxl2:/usr/bin$
                    @Zachary-Lowell
                    voxl2:/usr/bin$
                    @Tamas-Pal-0 Looks like px4 was already running. It was probably automatically started on system bootup using the systemd service. What is the output from voxl-inspect-services?
                      Tamas Pal 0
                      #11
                       modallink-relink     |  Enabled  | Not Running |
                       voxl-camera-server   |  Enabled  | Not Running |
                       voxl-cpu-monitor     |  Enabled  |   Running   |     0.0
                       voxl-dfs-server      |  Enabled  | Not Running |
                       voxl-imu-server      |  Enabled  |   Running   |     0.0
                       voxl-mavlink-server  |  Enabled  |   Running   |     0.0
                       voxl-portal          |  Enabled  |   Running   |     0.0
                       voxl-px4-imu-server  |  Enabled  |   Running   |     0.0
                       voxl-px4             |  Enabled  |   Running   |     0.0
                       voxl-qvio-server     |  Enabled  | Not Running |
                       voxl-softap          | Disabled  | Not Running |
                       voxl-static-ip       |  Enabled  | Not Running |
                       voxl-streamer        |  Enabled  |   Running   |     0.0
                       voxl-tag-detector    |  Enabled  | Not Running |
                       voxl-tflite-server   |  Enabled  |   Running   |     0.0
                       voxl-vision-px4      |  Enabled  |   Running   |     0.0
                      voxl2:/$
                      As mentioned by @Zachary-Lowell the voxl-px4-hitl file is not executable as shown in the youtube video https://www.youtube.com/watch?v=ysvpJdXFWaM&ab_channel=AscendEngineering
                      how to get the voxl-px4-hitl executable file?
                        voxl2:/$
                        @Tamas-Pal-0 sudo chmod +x /usr/bin/voxl-px4-hitl
                          Tamas Pal 0
                          @Eric-Katzfey The voxl-px4-hitl is still missing. I followed all the steps but the executable file voxl-px4-hitl is still not there
                          voxl2:/$ wget  http://voxl-packages.modalai.com/dists/qrb5165/dev/binary-arm64/voxl-px4_1.4.19-202208111710_arm64.deb
                          --2022-08-25 10:05:37--  http://voxl-packages.modalai.com/dists/qrb5165/dev/binary-arm64/voxl-px4_1.4.19-202208111710_arm64.deb
                          Resolving voxl-packages.modalai.com (voxl-packages.modalai.com)... 35.215.116.197
                          Connecting to voxl-packages.modalai.com (voxl-packages.modalai.com)|35.215.116.197|:80... connected.
                          HTTP request sent, awaiting response... 200 OK
                          Length: 5093080 (4.9M) [application/octet-stream]
                          Saving to: 'voxl-px4_1.4.19-202208111710_arm64.deb'
                          voxl-px4_1.4.19-202 100%[===================>]   4.86M  1.86MB/s    in 2.6s
                          2022-08-25 10:05:41 (1.86 MB/s) - 'voxl-px4_1.4.19-202208111710_arm64.deb' saved [5093080/5093080]
                          voxl2:/$ dpkg -i voxl-px4_1.4.19-202208111710_arm64.deb
                          voxl2:/$ apt-get install -f
                          voxl2:/$ sudo chmod +x /usr/bin/voxl-px4-hitl
                          voxl2:/$
                          how to fix this ?
                            voxl2:/$
                            how to fix this ?
                            @Tamas-Pal-0 voxl-px4-hitl isn't missing. Your screen shot shows you executing it. But as I said in the earlier response you already have px4 running and when you execute the command it won't allow you to run a second instance of px4.
                              voxl2:/$
                              how to fix this ?
                              @Tamas-Pal-0 In order to prevent px4 from running automatically in the background as a daemon on system startup use systemctl disable voxl-px4 and then sync. Reboot voxl 2 and then try voxl-px4-hitl again.
