  3. Cannot run voxl-mapper: ERROR fetching tf from tf ringbuffer there wasn't sufficient data in the buffer
5 Posts 5 Posters 1.6k Views
  • A Offline
    ahmed-mustahid
    wrote on last edited by ahmed-mustahid
    I have been getting the following error when starting voxl-mapper in the terminal, even though as per the instructions, all the services (voxl-vision-px4, voxl-qvio-server, voxl-camera-server) are running.
    I wonder what might have been the problem in this case.
    root@apq8096:~# voxl-mapper
    Loading our own config file
    Loading extrinsics config file
    Trying to init tsdf server
    created tsdf server
    waiting for server at /run/mpa/vvpx4_body_wrt_fixed/
    waiting for server at /run/mpa/tof
    Initializing ESDF structs
    Connected to VIO server
    Connected to depth pipe
    root@apq8096:~# voxl-inspect-services
     modallink-relink     | Disabled  | Not Running |
     voxl-camera-server   |  Enabled  |   Running   |    33.2
     voxl-cpu-monitor     |  Enabled  |   Running   |     0.0
     voxl-dfs-server      |  Enabled  |   Running   |     2.5
     voxl-imu-server      |  Enabled  |   Running   |     0.0
     voxl-mavlink-server  |  Enabled  |   Running   |     0.0
     voxl-portal          |  Enabled  |   Running   |     2.5
     voxl-qvio-server     |  Enabled  |   Running   |    10.2
     voxl-streamer        | Disabled  | Not Running |
     voxl-tag-detector    | Disabled  | Not Running |
     voxl-tflite-server   | Disabled  | Not Running |
     voxl-vision-px4      |  Enabled  |   Running   |     2.5
    /etc/modalai/voxl-mapper.conf
    	"tof_pipe":	"/run/mpa/tof",
    	"tof_enable":	true,
    	"tof_rate":	10,
    	"depth_pipe_0":	"/run/mpa/dfs_point_cloud",
    	"depth_pipe_0_enable":	false,
    	"extrinsics0_name":	"stereo_l",
    	"depth0_rate":	10,
    	"depth_pipe_1":	"/run/mpa/stereo_front_pc",
    	"depth_pipe_1_enable":	false,
    	"extrinsics1_name":	"stereo_front_l",
    	"depth1_rate":	10,
    	"depth_pipe_2":	"/run/mpa/stereo_rear_pc",
    	"depth_pipe_2_enable":	false,
    	"extrinsics2_name":	"stereo_rear_l",
    	"depth2_rate":	10,
    	"depth_pipe_3":	"/run/mpa/dfs_point_cloud",
    	"depth_pipe_3_enable":	false,
    	"extrinsics3_name":	"stereo_l",
    	"depth3_rate":	10,
    	"robot_radius":	0.3,
    	"voxel_size":	0.20000000298023224,
    	"voxels_per_side":	16,
    	"esdf_save_path":	"/data/voxl_mapper/esdf_map",
    	"tsdf_save_path":	"/data/voxl_mapper/tsdf_map",
    	"mesh_save_path":	"/data/voxl_mapper/mesh.ply",
    	"esdf_max_distance":	4,
    	"esdf_min_distance":	0.10000000149011612,
    	"esdf_default_distance":	2,
    	"esdf_inner_sphere_radius":	0.20000000298023224,
    	"esdf_outer_sphere_radius":	0.600000023841858,
    	"rrt_min_distance":	0.2,
    	"rrt_max_runtime_nanoseconds":	1000000000,
    	"rrt_use_first_solution":	false,
    	"rrt_treat_unknown_as_occupied":	true,
    	"rrt_send_tree":	false,
    	"loco_num_segments":	10,
    	"loco_derivative_to_optimize":	3,
    	"loco_poly_degree":	10,
    	"loco_smoothness_cost_weight":	2.5,
    	"loco_collision_cost_weight":	14,
    	"loco_waypoint_cost_weight":	0,
    	"loco_min_collision_sampling_dist":	0.05,
    	"loco_add_waypoints":	true,
    	"loco_scale_time":	true,
    	"loco_split_at_collisions":	true,
    	"loco_resample_trajectory":	true,
    	"loco_verbose":	false
    • Arjun JainA Offline
      Arjun JainA Offline
      Arjun Jain
      Hi @ahmed-mustahid : I am no expert, but I too get that warning sometimes but the voxl-mapper still works and generates a valid scene. I thought it is just when the camera is blocked or it doesn't have enough features or something like that it displays that warning. I am also curious to learn from the voxl team what this warning means.
      • ? Offline
        wrote on last edited by A Former User
        Typically that error presents itself when we do not have a pose from the qvio server. If you block the tracking camera or qvio server loses tracking that error will occur.
        J 1 Reply Last reply
        • ? A Former User
          J Offline
          J Offline
          jamiek
          wrote on last edited by jamiek
          @Matthew-Booker Hi Matthew, can you clarify on this? I'm also having this problem, even with the tracking camera not blocked (and all of ahmeds aforementioned pre-reqs).
          Will the error result in no map at all being generated? (Thats where I'm at 😢 ) or will it generate regardless?
          How can I monitor whether the qvio server loses tracking or does not have a pose?
          Is all I'm getting from the mapper.
          Best,
          Jamie
          • ? Offline
            Hey @jamiek,
            If this error occurs, it will result in no map generation at the time of error. This is because we need to grab a pose from our ringbuffer (at the timestamp of our pointcloud) in order to insert each pointcloud correctly into the map.
            This is caused by either voxl-qvio-server or voxl-vision-px4 not properly publishing a pose estimate.
            You can monitor the output of voxl-qvio-server using voxl-inspect-qvio on voxl or viewing the qvio overlay in voxl-portal. If everything looks good there and qvio is properly publishing pose info, the next place to check is voxl-vision-px4.
            This error means that we are not receiving a fixed pose data out of voxl-vision-px4, so once you have verified qvio is not reporting any error codes, monitor the output of voxl-inspect-pose -f on voxl and make sure that you are receiving pose data.
