    Cannot run voxl-mapper: ERROR fetching tf from tf ringbuffer there wasn't sufficient data in the buffer
    • A
      ahmed-mustahid
      I have been getting the following error when starting voxl-mapper in the terminal, even though as per the instructions, all the services (voxl-vision-px4, voxl-qvio-server, voxl-camera-server) are running.
      I wonder what might have been the problem in this case.
      root@apq8096:~# voxl-mapper
      Loading our own config file
      Loading extrinsics config file
      Trying to init tsdf server
      created tsdf server
      waiting for server at /run/mpa/vvpx4_body_wrt_fixed/
      waiting for server at /run/mpa/tof
      Initializing ESDF structs
      Connected to VIO server
      Connected to depth pipe
      root@apq8096:~# voxl-inspect-services
       modallink-relink     | Disabled  | Not Running |
       voxl-camera-server   |  Enabled  |   Running   |    33.2
       voxl-cpu-monitor     |  Enabled  |   Running   |     0.0
       voxl-dfs-server      |  Enabled  |   Running   |     2.5
       voxl-imu-server      |  Enabled  |   Running   |     0.0
       voxl-mavlink-server  |  Enabled  |   Running   |     0.0
       voxl-portal          |  Enabled  |   Running   |     2.5
       voxl-qvio-server     |  Enabled  |   Running   |    10.2
       voxl-streamer        | Disabled  | Not Running |
       voxl-tag-detector    | Disabled  | Not Running |
       voxl-tflite-server   | Disabled  | Not Running |
       voxl-vision-px4      |  Enabled  |   Running   |     2.5
      /etc/modalai/voxl-mapper.conf
      	"tof_pipe":	"/run/mpa/tof",
      	"tof_enable":	true,
      	"tof_rate":	10,
      	"depth_pipe_0":	"/run/mpa/dfs_point_cloud",
      	"depth_pipe_0_enable":	false,
      	"extrinsics0_name":	"stereo_l",
      	"depth0_rate":	10,
      	"depth_pipe_1":	"/run/mpa/stereo_front_pc",
      	"depth_pipe_1_enable":	false,
      	"extrinsics1_name":	"stereo_front_l",
      	"depth1_rate":	10,
      	"depth_pipe_2":	"/run/mpa/stereo_rear_pc",
      	"depth_pipe_2_enable":	false,
      	"extrinsics2_name":	"stereo_rear_l",
      	"depth2_rate":	10,
      	"depth_pipe_3":	"/run/mpa/dfs_point_cloud",
      	"depth_pipe_3_enable":	false,
      	"extrinsics3_name":	"stereo_l",
      	"depth3_rate":	10,
      	"robot_radius":	0.3,
      	"voxel_size":	0.20000000298023224,
      	"voxels_per_side":	16,
      	"esdf_save_path":	"/data/voxl_mapper/esdf_map",
      	"tsdf_save_path":	"/data/voxl_mapper/tsdf_map",
      	"mesh_save_path":	"/data/voxl_mapper/mesh.ply",
      	"esdf_max_distance":	4,
      	"esdf_min_distance":	0.10000000149011612,
      	"esdf_default_distance":	2,
      	"esdf_inner_sphere_radius":	0.20000000298023224,
      	"esdf_outer_sphere_radius":	0.600000023841858,
      	"rrt_min_distance":	0.2,
      	"rrt_max_runtime_nanoseconds":	1000000000,
      	"rrt_use_first_solution":	false,
      	"rrt_treat_unknown_as_occupied":	true,
      	"rrt_send_tree":	false,
      	"loco_num_segments":	10,
      	"loco_derivative_to_optimize":	3,
      	"loco_poly_degree":	10,
      	"loco_smoothness_cost_weight":	2.5,
      	"loco_collision_cost_weight":	14,
      	"loco_waypoint_cost_weight":	0,
      	"loco_min_collision_sampling_dist":	0.05,
      	"loco_add_waypoints":	true,
      	"loco_scale_time":	true,
      	"loco_split_at_collisions":	true,
      	"loco_resample_trajectory":	true,
      	"loco_verbose":	false
      • Arjun JainA
        Arjun Jain
        Hi @ahmed-mustahid : I am no expert, but I too get that warning sometimes but the voxl-mapper still works and generates a valid scene. I thought it is just when the camera is blocked or it doesn't have enough features or something like that it displays that warning. I am also curious to learn from the voxl team what this warning means.
          Typically that error presents itself when we do not have a pose from the qvio server. If you block the tracking camera or qvio server loses tracking that error will occur.
          • J
            jamiek @Guest
            @Matthew-Booker Hi Matthew, can you clarify on this? I'm also having this problem, even with the tracking camera not blocked (and all of ahmeds aforementioned pre-reqs).
            Will the error result in no map at all being generated? (Thats where I'm at 😢 ) or will it generate regardless?
            How can I monitor whether the qvio server loses tracking or does not have a pose?
            Is all I'm getting from the mapper.
            Best,
            Jamie
              Hey @jamiek,
              If this error occurs, it will result in no map generation at the time of error. This is because we need to grab a pose from our ringbuffer (at the timestamp of our pointcloud) in order to insert each pointcloud correctly into the map.
              This is caused by either voxl-qvio-server or voxl-vision-px4 not properly publishing a pose estimate.
              You can monitor the output of voxl-qvio-server using voxl-inspect-qvio on voxl or viewing the qvio overlay in voxl-portal. If everything looks good there and qvio is properly publishing pose info, the next place to check is voxl-vision-px4.
              This error means that we are not receiving a fixed pose data out of voxl-vision-px4, so once you have verified qvio is not reporting any error codes, monitor the output of voxl-inspect-pose -f on voxl and make sure that you are receiving pose data.
