  3. modifying voxl-mapper
23 Posts 4 Posters 7.8k Views 1 Watching
  • Arjun JainA Arjun Jain
    [[topic:post-is-deleted]]
    Arjun JainA Offline
    Arjun JainA Offline
    Arjun Jain
    • ? A Former User
      @Nishkala you can instead use ./install_build_deps.sh apq8096 sdk-0.8
      Arjun JainA Offline
      Arjun JainA Offline
      Arjun Jain
      @Matthew-Booker Thanks a lot!
      What works for me is:
      voxl-cross:~/voxl-mapper(master)(0.0.7)$ ./install_build_deps.sh apq8096 sdk-0.8
      voxl-cross:~/voxl-mapper(master)(0.0.7)$ ./build.sh apq8096
      voxl-cross:~/voxl-mapper(master)(0.0.7)$ ./make_package.sh ipk
      scp voxl-mapper_0.0.7.ipk root@10.0.1.10:
      On voxl 1 board, I added arm64 7 to /etc/opkg/arch.conf
      voxl:~$ voxl-configure-opkg dev
      opkg install --force-reinstall --force-downgrade --force-depends --force-overwrite voxl-mapper_0.0.7.ipk
      Then everything seems to work so far!
      N 2 Replies Last reply
      • ? A Former User
        Arjun JainA Offline
        Arjun JainA Offline
        Arjun Jain
        @Matthew-Booker However, when I try to save the mesh from the portal, in my compiled version, I get this symbol not found error. Any ideas why it can not find this function and how to fix it? Many thanks in advance.
        skipped 2 point clouds
        WARNING bytes left in tof point cloud pipe
        skipped 3 point clouds
        skipped 1 point clouds
        voxl-mapper: symbol lookup error: voxl-mapper: undefined symbol: _ZNK7voxblox5LayerINS_9TsdfVoxelEE10saveToFileESsb
        Fault address: 0x7f60053888
        Access to this address is not allowed.
        Segmentation fault
        • ? Offline
          @Arjun-Jain Looks like a mismatch in the voxl-voxblox version. Since you've already configured opkg you should just be able to run opkg install voxl-voxblox and it should work.
            N Offline
            N Offline
            Nishkala
            wrote on last edited by Nishkala
            #17
            @Matthew-Booker How to do the same on voxl2
            I tried the below commands
            voxl-cross:~/voxl-mapper(master)(0.0.7)$ ./deploy_to_voxl.sh
            On the voxl2 board
            voxl2:/$ voxl-configure-pkg-manager
            Chose sdk 0.8
            voxl2:/$ apt update
            voxl2:/$ voxl-mapper
            I got the below error
            Loading our own config file
            Loading extrinsics config file
            Trying to init tsdf server
            terminate called after throwing an instance of 'std::bad_alloc'
            what(): std::bad_alloc
            Aborted
            ? 1 Reply Last reply
            • N Nishkala
              On the voxl2 board
              Chose sdk 0.8
              voxl2:/$ apt update
              Aborted
              @Nishkala When you build for voxl2 you need to use qrb5165 not apq8096 so the full command would be:
              ./install_build_deps.sh qrb5165 sdk-0.8
              ./build.sh qrb5165
              ./make_package.sh
                N Offline
                N Offline
                Nishkala
                @Matthew-Booker
                I ran the below commands on voxl cross:
                ./build.sh qrb5165
                ./make_package.sh
                ./deploy_to_voxl.sh
                I ran voxl-mapper after this on the board and got the error 'voxl-mapper: symbol lookup error: voxl-mapper: undefined symbol: _ZNK7voxblox5LayerINS_9EsdfVoxelEE10saveToFileENSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEEb
                I wanted to add arm64 to /etc/opkg/arch.conf but voxl2 uses apt. How to solve the above issue?
                • ? Offline
                  That error occurs when theres a voxl-voxblox version mismatch. The version of voxl-voxblox on your voxl2 is older. On your voxl2 if you run the following it should update
                  apt install voxl-voxblox
                  • ? A Former User
                    N Offline
                    N Offline
                    Nishkala
                    • ? A Former User
                      N Offline
                      N Offline
                      Nishkala
                      @Matthew-Booker
                      This worked! Thank you
                      • N Offline
                        N Offline
                        Nishkala
                        #23
