  3. modifying voxl-mapper
23 Posts 4 Posters 8.1k Views 1 Watching
  • ? A Former User
    @Nishkala you can instead use ./install_build_deps.sh apq8096 sdk-0.8
    Arjun JainA Offline
    Arjun JainA Offline
    Arjun Jain
    @Matthew-Booker Thanks a lot!
    What works for me is:
    voxl-cross:~/voxl-mapper(master)(0.0.7)$ ./install_build_deps.sh apq8096 sdk-0.8
    voxl-cross:~/voxl-mapper(master)(0.0.7)$ ./build.sh apq8096
    voxl-cross:~/voxl-mapper(master)(0.0.7)$ ./make_package.sh ipk
    scp voxl-mapper_0.0.7.ipk root@10.0.1.10:
    On voxl 1 board, I added arm64 7 to /etc/opkg/arch.conf
    voxl:~$ voxl-configure-opkg dev
    opkg install --force-reinstall --force-downgrade --force-depends --force-overwrite voxl-mapper_0.0.7.ipk
    Then everything seems to work so far!
    N 2 Replies Last reply
    • ? A Former User
      Arjun JainA Offline
      Arjun JainA Offline
      Arjun Jain
      @Matthew-Booker However, when I try to save the mesh from the portal, in my compiled version, I get this symbol not found error. Any ideas why it can not find this function and how to fix it? Many thanks in advance.
      skipped 2 point clouds
      WARNING bytes left in tof point cloud pipe
      skipped 3 point clouds
      skipped 1 point clouds
      voxl-mapper: symbol lookup error: voxl-mapper: undefined symbol: _ZNK7voxblox5LayerINS_9TsdfVoxelEE10saveToFileESsb
      Fault address: 0x7f60053888
      Access to this address is not allowed.
      Segmentation fault
      • ? Offline
        @Arjun-Jain Looks like a mismatch in the voxl-voxblox version. Since you've already configured opkg you should just be able to run opkg install voxl-voxblox and it should work.
        • Arjun JainA Arjun Jain
          N Offline
          N Offline
          Nishkala
          wrote on last edited by Nishkala
          #17
          @Matthew-Booker How to do the same on voxl2
          I tried the below commands
          voxl-cross:~/voxl-mapper(master)(0.0.7)$ ./deploy_to_voxl.sh
          On the voxl2 board
          voxl2:/$ voxl-configure-pkg-manager
          Chose sdk 0.8
          voxl2:/$ apt update
          voxl2:/$ voxl-mapper
          I got the below error
          Loading our own config file
          Loading extrinsics config file
          Trying to init tsdf server
          terminate called after throwing an instance of 'std::bad_alloc'
          what(): std::bad_alloc
          Aborted
          ? 1 Reply Last reply
          • N Nishkala
            On the voxl2 board
            Chose sdk 0.8
            voxl2:/$ apt update
            Aborted
            @Nishkala When you build for voxl2 you need to use qrb5165 not apq8096 so the full command would be:
            ./install_build_deps.sh qrb5165 sdk-0.8
            ./build.sh qrb5165
            ./make_package.sh
              N Offline
              N Offline
              Nishkala
              @Matthew-Booker
              I ran the below commands on voxl cross:
              ./build.sh qrb5165
              ./make_package.sh
              ./deploy_to_voxl.sh
              I ran voxl-mapper after this on the board and got the error 'voxl-mapper: symbol lookup error: voxl-mapper: undefined symbol: _ZNK7voxblox5LayerINS_9EsdfVoxelEE10saveToFileENSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEEb
              I wanted to add arm64 to /etc/opkg/arch.conf but voxl2 uses apt. How to solve the above issue?
              • ? Offline
                That error occurs when theres a voxl-voxblox version mismatch. The version of voxl-voxblox on your voxl2 is older. On your voxl2 if you run the following it should update
                apt install voxl-voxblox
                • ? A Former User
                  N Offline
                  N Offline
                  Nishkala
                  • ? A Former User
                    N Offline
                    N Offline
                    Nishkala
                    @Matthew-Booker
                    This worked! Thank you
                    • N Offline
                      N Offline
                      Nishkala
                      #23
