  3. modifying voxl-mapper
23 Posts 4 Posters 6.5k Views 1 Watching
  • ? Offline
    wrote on last edited by A Former User
    #9
    Can I double check. Did you run ./install_build_deps.sh before trying to build?
    If building for a VOXL 2 the full command would be ./install_build_deps.sh qrb5165 stable
    • N Offline
      N Offline
      Nishkala
      wrote on last edited by Nishkala
      #10
      If we are building it for voxlcam, what should be used?
      If we use ./install_build_deps.sh apq8096 stable, we get the error,
      '-- Configuring done
      -- Generating done
      -- Build files have been written to: /home/root/voxlcam_mapper/voxl-mapper/build64
      Consolidate compiler generated dependencies of target mav_trajectory_generation
      [ 25%] Built target mav_trajectory_generation
      Consolidate compiler generated dependencies of target mav_planning_common
      [ 36%] Built target mav_planning_common
      Consolidate compiler generated dependencies of target voxblox_planning_common
      Consolidate compiler generated dependencies of target mav_path_smoothing
      [ 44%] Built target voxblox_planning_common
      [ 58%] Built target mav_path_smoothing
      Consolidate compiler generated dependencies of target voxblox_loco_planner
      [ 69%] Built target voxblox_loco_planner
      Consolidate compiler generated dependencies of target mav_local_planner
      [ 77%] Built target mav_local_planner
      Consolidate compiler generated dependencies of target voxl-mapper
      [ 80%] Building CXX object server/voxl-mapper/CMakeFiles/voxl-mapper.dir/voxl_mapper.cc.o
      /home/root/voxlcam_mapper/voxl-mapper/server/voxl-mapper/voxl_mapper.cc: In member function 'virtual bool voxblox::TsdfServer::loadMap(std::string, std::string)':
      /home/root/voxlcam_mapper/voxl-mapper/server/voxl-mapper/voxl_mapper.cc:1164:54: error: 'class voxblox::Layervoxblox::TsdfVoxel' has no member named 'loadBlocksFromFile'
      bool tsdf_loaded = tsdf_map_->getTsdfLayerPtr()->loadBlocksFromFile(
      /home/root/voxlcam_mapper/voxl-mapper/server/voxl-mapper/voxl_mapper.cc:1172:54: error: 'class voxblox::Layervoxblox::EsdfVoxel' has no member named 'loadBlocksFromFile'
      bool esdf_loaded = esdf_map_->getEsdfLayerPtr()->loadBlocksFromFile(
      server/voxl-mapper/CMakeFiles/voxl-mapper.dir/build.make:159: recipe for target 'server/voxl-mapper/CMakeFiles/voxl-mapper.dir/voxl_mapper.cc.o' failed
      make[2]: *** [server/voxl-mapper/CMakeFiles/voxl-mapper.dir/voxl_mapper.cc.o] Error 1
      CMakeFiles/Makefile2:398: recipe for target 'server/voxl-mapper/CMakeFiles/voxl-mapper.dir/all' failed
      make[1]: *** [server/voxl-mapper/CMakeFiles/voxl-mapper.dir/all] Error 2
      Makefile:135: recipe for target 'all' failed
      make: *** [all] Error 2
      • ? Offline
        @Nishkala you can instead use ./install_build_deps.sh apq8096 sdk-0.8
        Arjun JainA 3 Replies Last reply
        • ? A Former User
          Arjun JainA Offline
          Arjun JainA Offline
          Arjun Jain
          Arjun JainA 1 Reply Last reply
          • Arjun JainA Arjun Jain
            Arjun JainA Offline
            Arjun JainA Offline
            Arjun Jain
            • ? A Former User
              Arjun JainA Offline
              Arjun JainA Offline
              Arjun Jain
              @Matthew-Booker Thanks a lot!
              What works for me is:
              voxl-cross:~/voxl-mapper(master)(0.0.7)$ ./install_build_deps.sh apq8096 sdk-0.8
              voxl-cross:~/voxl-mapper(master)(0.0.7)$ ./build.sh apq8096
              voxl-cross:~/voxl-mapper(master)(0.0.7)$ ./make_package.sh ipk
              scp voxl-mapper_0.0.7.ipk root@10.0.1.10:
              On voxl 1 board, I added arm64 7 to /etc/opkg/arch.conf
              voxl:~$ voxl-configure-opkg dev
              opkg install --force-reinstall --force-downgrade --force-depends --force-overwrite voxl-mapper_0.0.7.ipk
              Then everything seems to work so far!
              N 2 Replies Last reply
              • ? A Former User
                Arjun JainA Offline
                Arjun JainA Offline
                Arjun Jain
                @Matthew-Booker However, when I try to save the mesh from the portal, in my compiled version, I get this symbol not found error. Any ideas why it can not find this function and how to fix it? Many thanks in advance.
                skipped 2 point clouds
                WARNING bytes left in tof point cloud pipe
                skipped 3 point clouds
                skipped 1 point clouds
                voxl-mapper: symbol lookup error: voxl-mapper: undefined symbol: _ZNK7voxblox5LayerINS_9TsdfVoxelEE10saveToFileESsb
                Fault address: 0x7f60053888
                Access to this address is not allowed.
                Segmentation fault
                • ? Offline
                  @Arjun-Jain Looks like a mismatch in the voxl-voxblox version. Since you've already configured opkg you should just be able to run opkg install voxl-voxblox and it should work.
                    N Offline
                    N Offline
                    Nishkala
                    #17
                    @Matthew-Booker How to do the same on voxl2
                    I tried the below commands
                    voxl-cross:~/voxl-mapper(master)(0.0.7)$ ./deploy_to_voxl.sh
                    On the voxl2 board
                    voxl2:/$ voxl-configure-pkg-manager
                    Chose sdk 0.8
                    voxl2:/$ apt update
                    voxl2:/$ voxl-mapper
                    I got the below error
                    Loading our own config file
                    Loading extrinsics config file
                    Trying to init tsdf server
                    terminate called after throwing an instance of 'std::bad_alloc'
                    what(): std::bad_alloc
                    Aborted
                    ? 1 Reply Last reply
                    • N Nishkala
                      On the voxl2 board
                      Chose sdk 0.8
                      voxl2:/$ apt update
                      Aborted
                      @Nishkala When you build for voxl2 you need to use qrb5165 not apq8096 so the full command would be:
                      ./install_build_deps.sh qrb5165 sdk-0.8
                      ./build.sh qrb5165
                      ./make_package.sh
                        N Offline
                        N Offline
                        Nishkala
                        @Matthew-Booker
                        I ran the below commands on voxl cross:
                        ./build.sh qrb5165
                        ./make_package.sh
                        ./deploy_to_voxl.sh
                        I ran voxl-mapper after this on the board and got the error 'voxl-mapper: symbol lookup error: voxl-mapper: undefined symbol: _ZNK7voxblox5LayerINS_9EsdfVoxelEE10saveToFileENSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEEb
                        I wanted to add arm64 to /etc/opkg/arch.conf but voxl2 uses apt. How to solve the above issue?
                        • ? Offline
                          That error occurs when theres a voxl-voxblox version mismatch. The version of voxl-voxblox on your voxl2 is older. On your voxl2 if you run the following it should update
                          apt install voxl-voxblox
                          • ? A Former User
                            N Offline
                            N Offline
                            Nishkala
                            • ? A Former User
                              N Offline
                              N Offline
                              Nishkala
                              @Matthew-Booker
                              This worked! Thank you
                              • N Offline
                                N Offline
                                Nishkala
                                #23
