  2. VOXL SDK and Software
  3. What are my options for ROS support on VOXL?
ros
10 Posts 3 Posters 3.0k Views 2 Watching
  • Ed SutterE Offline
    Ed SutterE Offline
    Ed Sutter
    I am just getting started with VOXL Flight Deck. I've walked through several quick starts and have used ADB and SSH as well as QGC/WiFi to connect to my target. All good. I see that my shipped system is running a Yocto built version of Linux that has ROS Indigo.
    I was hoping to use ROS Melodic. Is there any upgrade path to be able to run ROS Melodic on VOXL?
      Here is a tutorial using mavros with kinetic.
      From there you can see instructions for running Docker on VOXL that points to the Dockerfile for the kinetic image. You should be able to upgrade to Melodic using similar techniques
      • Chad SweetC Chad Sweet
        Ed SutterE Offline
        Ed SutterE Offline
        Ed Sutter
        @Chad-Sweet Thanks, I'll dig into that...
        Am I correct to assume that it is common practice to run with the Yocto based Linux as the "base" platform and then launch various docker images with some form of Ubuntu in parallel with that?
        Assuming it is, has anyone already created a "rosmelodic-bionic" docker image?
        Seems the docker files here https://gitlab.com/voxl-public/voxl-docker-images/roskinetic-docker are where to start. True?
        Sorry, I'm editing this as I go. I'll stop now...
          Ed SutterE Offline
          Ed SutterE Offline
          Ed Sutter
          @Chad-Sweet I'm working on a docker image to support ROS melodic on Ubuntu 18.04; meanwhile, I'd still appreciate your thoughts on this...
          Just based on a pretty thorough docker-on-voxl page vs "coming soon" for the MPA-to-ROS page, it appears the better route is to push toward docker; especially if I have ROS-melodic experience. True? Thoughts?
          • ? Offline
            The "coming soon" for voxl-mpa-to-ros refers more to the documentation on our end as we finalize the structure of the package, it is already in a completely usable state. I think the issue for you is that it is not a new implementation of ros on voxl but just a rosnode for publishing MPA topics within the already existing indigo (or melodic on voxl2) infrastructure. We don't have any plans for supporting melodic natively on voxl1 since the voxl system is based on an older yocto build as opposed to a relatively standard Ubuntu 18 for voxl2.
              Ed SutterE Offline
              Ed Sutter
              Thanks for the quick response. I was offline for the last 36 hours waiting for a network repair...
              Anyway, the fundamental problem I'm having with voxl-mpa-to-ros is a build failure...
              I follow the instructions in the README.md but end up with a failure in build.sh...
              Several CMAKE warnings like this:
              CMake Warning at /opt/ros/indigo/share/cpp_common/cmake/cpp_commonConfig.cmake:111 (message):
                Project 'cpp_common' specifies 'NOTFOUND/usr/include' as an include dir,
                which is not found.  It does neither exist as an absolute directory nor in
                '/opt/ros/indigo/NOTFOUND/usr/include'.  Ask the maintainer 'Dirk Thomas
                <dthomas@osrfoundation.org>' to fix it.
              Call Stack (most recent call first):
                /opt/ros/indigo/share/roscpp/cmake/roscppConfig.cmake:169 (find_package)
                /opt/ros/indigo/share/catkin/cmake/catkinConfig.cmake:76 (find_package)
                CMakeLists.txt:43 (find_package)
              Then the final error:
              /home/root/catkin_ws/src/./include/interfaces/ai_detection_interface.h:38:41: fatal error: voxl_mpa_to_ros/AiDetection.h: No
              such file or directory
               #include <voxl_mpa_to_ros/AiDetection.h>
              compilation terminated.
              CMakeFiles/voxl_mpa_to_ros_node.dir/build.make:206: recipe for target 'CMakeFiles/voxl_mpa_to_ros_node.dir/src/interface_mana
              ger.cpp.o' failed
              make[2]: *** [CMakeFiles/voxl_mpa_to_ros_node.dir/src/interface_manager.cpp.o] Error 1
              Scanning dependencies of target voxl_mpa_to_ros_generate_messages_lisp
              [ 66%] Generating Lisp code from voxl_mpa_to_ros/AiDetection.msg
              [ 66%] Built target voxl_mpa_to_ros_generate_messages_lisp
              Scanning dependencies of target voxl_mpa_to_ros_generate_messages_py
              [ 73%] Generating Python from MSG voxl_mpa_to_ros/AiDetection
              [ 80%] Generating Python msg __init__.py for voxl_mpa_to_ros
              [ 80%] Built target voxl_mpa_to_ros_generate_messages_py
              [ 80%] Built target voxl_mpa_to_ros_generate_messages_cpp
              CMakeFiles/Makefile2:1546: recipe for target 'CMakeFiles/voxl_mpa_to_ros_node.dir/all' failed
              make[1]: *** [CMakeFiles/voxl_mpa_to_ros_node.dir/all] Error 2
              Makefile:138: recipe for target 'all' failed
              make: *** [all] Error 2
              Invoking "make install -j8 -l8" failed
              voxl-emulator:~$
              This is the result when running build.sh apq8096, which I assume is correct for Voxl-Flight-Deck. Are those instructions up to date? I am running with docker image "voxl-eumlator:V1.7".
                Maybe this post helps? https://forum.modalai.com/topic/1097/subscribe-to-voxl_mpa_to_ros-topics/2?_=1660186237636
                  Ed SutterE Offline
                  Ed Sutter
                  Not sure how that topic applies to my question (sorry, I certainly admit to being new to VOXL). Right now all I'm trying to do is build that repository by cloning it and following the build steps outlined in the README.md file. No changes, I'm just trying to verify that I have my host environment set up properly.
                  Am I correct to assume that this should build clean as is?
                  • ? Offline
                    I just pulled down master and it built successfully (you have the correct docker image and version , voxl-emulator-1.7).
                    voxl-emulator:~/voxl-mpa-to-ros$ ./install_build_deps.sh apq8096 stable
                    using apq8096 stable repo
                    adding arm64 to opkg conf
                    Downloading http://voxl-packages.modalai.com/dists/apq8096/stable/binary-arm64//Packages.gz.
                    Updated source 'stable'.
                    installing:
                    libmodal-json
                    libmodal-pipe
                    libvoxl-cutils
                    Installing libmodal-json (0.4.2) on root.
                    Downloading http://voxl-packages.modalai.com/dists/apq8096/stable/binary-arm64//libmodal-json_0.4.2.ipk.
                    Configuring libmodal-json.
                    Installing libmodal-pipe (2.4.0) on root.
                    Downloading http://voxl-packages.modalai.com/dists/apq8096/stable/binary-arm64//libmodal-pipe_2.4.0.ipk.
                    Configuring libmodal-pipe.
                    Installing libvoxl-cutils (0.1.1) on root.
                    Downloading http://voxl-packages.modalai.com/dists/apq8096/stable/binary-arm64//libvoxl-cutils_0.1.1.ipk.
                    Configuring libvoxl-cutils.
                    Done installing dependencies
                    voxl-emulator:~/voxl-mpa-to-ros$ ./clean.sh
                    voxl-emulator:~/voxl-mpa-to-ros$ ./build.sh apq8096
                    Base path: /home/root/voxl-mpa-to-ros/catkin_ws
                    Source space: /home/root/voxl-mpa-to-ros/catkin_ws/src
                    Build space: /home/root/voxl-mpa-to-ros/catkin_ws/build
                    Devel space: /home/root/voxl-mpa-to-ros/catkin_ws/devel
                    Install space: /home/root/voxl-mpa-to-ros/catkin_ws/install
                    #### Running command: "cmake /home/root/voxl-mpa-to-ros/catkin_ws/src -DCMAKE_BUILD_TYPE=Release -DCATKIN_DEVEL_PREFIX=/home/root/voxl-mpa-to-ros/catkin_ws/devel -DCMAKE_INSTALL_PREFIX=/home/root/voxl-mpa-to-ros/catkin_ws/install -G Unix Makefiles" in "/home/root/voxl-mpa-to-ros/catkin_ws/build"
                    -- The C compiler identification is GNU 4.9.3
                    -- The CXX compiler identification is GNU 4.9.3
                    -- Check for working C compiler: /usr/bin/cc
                    -- Check for working C compiler: /usr/bin/cc -- works
                    -- Check for working CXX compiler: /usr/bin/c++
                    -- Check for working CXX compiler: /usr/bin/c++ -- works
                    -- Using CATKIN_DEVEL_PREFIX: /home/root/voxl-mpa-to-ros/catkin_ws/devel
                    -- Using CMAKE_PREFIX_PATH: /opt/ros/indigo
                    -- This workspace overlays: /opt/ros/indigo
                    -- Found PythonInterp: /usr/bin/python (found version "2.7.9")
                    -- Using PYTHON_EXECUTABLE: /usr/bin/python
                    -- Using default Python package layout
                    -- Found PY_em: /usr/lib/python2.7/site-packages/em.pyc
                    -- Using empy: /usr/lib/python2.7/site-packages/em.pyc
                    -- Using CATKIN_ENABLE_TESTING: ON
                    -- Call enable_testing()
                    -- Using CATKIN_TEST_RESULTS_DIR: /home/root/voxl-mpa-to-ros/catkin_ws/build/test_results
                    -- Found gtest: gtests will be built
                    -- Using Python nosetests: /usr/bin/nosetests-2.7
                    -- catkin 0.6.19
                    { A bunch of cmake warnings here that I hid for readability }
                    -- voxl_mpa_to_ros: 1 messages, 0 services
                    -- Configuring done
                    -- Generating done
                    -- Build files have been written to: /home/root/voxl-mpa-to-ros/catkin_ws/build
                    #### Running command: "make install -j16 -l16" in "/home/root/voxl-mpa-to-ros/catkin_ws/build"
                    Scanning dependencies of target _voxl_mpa_to_ros_generate_messages_check_deps_AiDetection
                    Scanning dependencies of target voxl_mpa_to_ros_node
                    [  6%] Building CXX object CMakeFiles/voxl_mpa_to_ros_node.dir/src/interfaces/imu_interface.cpp.o
                    [ 13%] Building CXX object CMakeFiles/voxl_mpa_to_ros_node.dir/src/interfaces/camera_interface.cpp.o
                    [ 26%] Building CXX object CMakeFiles/voxl_mpa_to_ros_node.dir/src/interfaces/stereo_interface.cpp.o
                    [ 26%] Building CXX object CMakeFiles/voxl_mpa_to_ros_node.dir/src/interfaces/ai_detection_interface.cpp.o
                    [ 33%] Building CXX object CMakeFiles/voxl_mpa_to_ros_node.dir/src/interfaces/vio_interface.cpp.o
                    [ 40%] Building CXX object CMakeFiles/voxl_mpa_to_ros_node.dir/src/interfaces/point_cloud_interface.cpp.o
                    [ 46%] Building CXX object CMakeFiles/voxl_mpa_to_ros_node.dir/src/mpa_ros_node.cpp.o
                    [ 53%] Building CXX object CMakeFiles/voxl_mpa_to_ros_node.dir/src/interface_manager.cpp.o
                    [ 60%] Building CXX object CMakeFiles/voxl_mpa_to_ros_node.dir/src/utils/camera_helpers.cpp.o
                    [ 66%] Building CXX object CMakeFiles/voxl_mpa_to_ros_node.dir/src/utils/common_utils.cpp.o
                    [ 66%] Built target _voxl_mpa_to_ros_generate_messages_check_deps_AiDetection
                    Scanning dependencies of target voxl_mpa_to_ros_generate_messages_cpp
                    [ 73%] Generating C++ code from voxl_mpa_to_ros/AiDetection.msg
                    [ 80%] Generating Python from MSG voxl_mpa_to_ros/AiDetection
                    [ 86%] Generating Lisp code from voxl_mpa_to_ros/AiDetection.msg
                    [ 93%] Generating Python msg __init__.py for voxl_mpa_to_ros
                    [ 93%] Built target voxl_mpa_to_ros_generate_messages_lisp
                    [ 93%] Built target voxl_mpa_to_ros_generate_messages_py
                    [ 93%] Built target voxl_mpa_to_ros_generate_messages_cpp
                    [100%] Linking CXX executable /home/root/voxl-mpa-to-ros/catkin_ws/devel/lib/voxl_mpa_to_ros/voxl_mpa_to_ros_node
                    /usr/lib/gcc/arm-oemllib32-linux-gnueabi/4.9.3/../../../../arm-oemllib32-linux-gnueabi/bin/ld: warning: skipping incompatible /usr/lib64/libmodal_pipe.so while searching for modal_pipe
                    /usr/lib/gcc/arm-oemllib32-linux-gnueabi/4.9.3/../../../../arm-oemllib32-linux-gnueabi/bin/ld: warning: skipping incompatible /usr/lib64/libmodal_json.so while searching for modal_json
                    [100%] Built target voxl_mpa_to_ros_node
                    Install the project...
                    -- Install configuration: "Release"
                    -- Installing: /home/root/voxl-mpa-to-ros/catkin_ws/install/_setup_util.py
                    -- Installing: /home/root/voxl-mpa-to-ros/catkin_ws/install/env.sh
                    -- Installing: /home/root/voxl-mpa-to-ros/catkin_ws/install/setup.bash
                    -- Installing: /home/root/voxl-mpa-to-ros/catkin_ws/install/setup.sh
                    -- Installing: /home/root/voxl-mpa-to-ros/catkin_ws/install/setup.zsh
                    -- Installing: /home/root/voxl-mpa-to-ros/catkin_ws/install/.rosinstall
                    -- Installing: /home/root/voxl-mpa-to-ros/catkin_ws/install/share/voxl_mpa_to_ros/msg/AiDetection.msg
                    -- Installing: /home/root/voxl-mpa-to-ros/catkin_ws/install/share/voxl_mpa_to_ros/cmake/voxl_mpa_to_ros-msg-paths.cmake
                    -- Installing: /home/root/voxl-mpa-to-ros/catkin_ws/install/include/voxl_mpa_to_ros
                    -- Installing: /home/root/voxl-mpa-to-ros/catkin_ws/install/include/voxl_mpa_to_ros/AiDetection.h
                    -- Installing: /home/root/voxl-mpa-to-ros/catkin_ws/install/share/common-lisp/ros/voxl_mpa_to_ros
                    -- Installing: /home/root/voxl-mpa-to-ros/catkin_ws/install/share/common-lisp/ros/voxl_mpa_to_ros/msg
                    -- Installing: /home/root/voxl-mpa-to-ros/catkin_ws/install/share/common-lisp/ros/voxl_mpa_to_ros/msg/voxl_mpa_to_ros-msg.asd
                    -- Installing: /home/root/voxl-mpa-to-ros/catkin_ws/install/share/common-lisp/ros/voxl_mpa_to_ros/msg/_package_AiDetection.lisp
                    -- Installing: /home/root/voxl-mpa-to-ros/catkin_ws/install/share/common-lisp/ros/voxl_mpa_to_ros/msg/_package.lisp
                    -- Installing: /home/root/voxl-mpa-to-ros/catkin_ws/install/share/common-lisp/ros/voxl_mpa_to_ros/msg/AiDetection.lisp
                    Listing /home/root/voxl-mpa-to-ros/catkin_ws/devel/lib/python2.7/site-packages/voxl_mpa_to_ros ...
                    Compiling /home/root/voxl-mpa-to-ros/catkin_ws/devel/lib/python2.7/site-packages/voxl_mpa_to_ros/__init__.py ...
                    Listing /home/root/voxl-mpa-to-ros/catkin_ws/devel/lib/python2.7/site-packages/voxl_mpa_to_ros/msg ...
                    Compiling /home/root/voxl-mpa-to-ros/catkin_ws/devel/lib/python2.7/site-packages/voxl_mpa_to_ros/msg/_AiDetection.py ...
                    Compiling /home/root/voxl-mpa-to-ros/catkin_ws/devel/lib/python2.7/site-packages/voxl_mpa_to_ros/msg/__init__.py ...
                    -- Installing: /home/root/voxl-mpa-to-ros/catkin_ws/install/lib/python2.7/site-packages/voxl_mpa_to_ros
                    -- Installing: /home/root/voxl-mpa-to-ros/catkin_ws/install/lib/python2.7/site-packages/voxl_mpa_to_ros/__init__.py
                    -- Installing: /home/root/voxl-mpa-to-ros/catkin_ws/install/lib/python2.7/site-packages/voxl_mpa_to_ros/__init__.pyc
                    -- Installing: /home/root/voxl-mpa-to-ros/catkin_ws/install/lib/python2.7/site-packages/voxl_mpa_to_ros/msg
                    -- Installing: /home/root/voxl-mpa-to-ros/catkin_ws/install/lib/python2.7/site-packages/voxl_mpa_to_ros/msg/_AiDetection.pyc
                    -- Installing: /home/root/voxl-mpa-to-ros/catkin_ws/install/lib/python2.7/site-packages/voxl_mpa_to_ros/msg/__init__.py
                    -- Installing: /home/root/voxl-mpa-to-ros/catkin_ws/install/lib/python2.7/site-packages/voxl_mpa_to_ros/msg/__init__.pyc
                    -- Installing: /home/root/voxl-mpa-to-ros/catkin_ws/install/lib/pkgconfig/voxl_mpa_to_ros.pc
                    -- Installing: /home/root/voxl-mpa-to-ros/catkin_ws/install/share/voxl_mpa_to_ros/cmake/voxl_mpa_to_ros-msg-extras.cmake
                    -- Installing: /home/root/voxl-mpa-to-ros/catkin_ws/install/share/voxl_mpa_to_ros/cmake/voxl_mpa_to_rosConfig.cmake
                    -- Installing: /home/root/voxl-mpa-to-ros/catkin_ws/install/share/voxl_mpa_to_ros/cmake/voxl_mpa_to_rosConfig-version.cmake
                    -- Installing: /home/root/voxl-mpa-to-ros/catkin_ws/install/share/voxl_mpa_to_ros/package.xml
                    -- Installing: /home/root/voxl-mpa-to-ros/catkin_ws/install/share/voxl_mpa_to_ros/launch
                    -- Installing: /home/root/voxl-mpa-to-ros/catkin_ws/install/share/voxl_mpa_to_ros/launch/voxl_mpa_to_ros.launch
                    -- Installing: /home/root/voxl-mpa-to-ros/catkin_ws/install/lib/voxl_mpa_to_ros/voxl_mpa_to_ros_node
                    -- Removed runtime path from "/home/root/voxl-mpa-to-ros/catkin_ws/install/lib/voxl_mpa_to_ros/voxl_mpa_to_ros_node"
                    voxl-emulator:~/voxl-mpa-to-ros$ ./make_package.sh ipk
                    Package Name:  voxl-mpa-to-ros
                    version Number:  0.3.3
                    starting building IPK package
                    ar: creating voxl-mpa-to-ros_0.3.3.ipk
                    DONE
                    Ed SutterE 1 Reply Last reply
                    • ? A Former User
                      installing:
                      libmodal-json
                      libmodal-pipe
                      libvoxl-cutils
                      -- catkin 0.6.19
                      -- Configuring done
                      -- Generating done
                      DONE
                      Ed SutterE Offline
                      Ed SutterE Offline
                      Ed Sutter
                      @Alex-Gardner Ok, thanks much for running that. Since it built clean for you, that made it clear that there was something bad about my environment (the whole reason I'm down this rabbit hole!).
                      Anyway, my typical configuration is to ssh into my Linux machine from a W10 box using Cygwin/SSH. Apparently something in the build.sh script doesn't like that; hence my failures. When I build directly through the console of that Linux machine the build completes successfully.
                      Sorry for the confusion, and thanks to all for the responses.
