    error compiling voxl-vision-px4 from source
    1323
    • Aldo Castro FreireA
      Aldo Castro Freire
      it says cannot find -lsensor_imu and not sure how to fix it !!
        tom admin
        See this thread to see if the solution works for you.
          Aldo Castro Freire
          I still have this errors :
          CMakeFiles/voxl-vision-px4.dir/fixed_frame_pipe.c.o:fixed_frame_pipe.c:function fixed_frame_pipe_init: error: undefined reference to 'pipe_sink_set_data_cb'
          CMakeFiles/voxl-vision-px4.dir/px4_shell.c.o:px4_shell.c:function px4_shell_init: error: undefined reference to 'pipe_sink_set_data_cb'
            tom admin
            Are you building from master? Which version of voxl-emulator are you using?
              Aldo Castro Freire
              I am building from tag v0.6.8 because when I build from master I got this error while pushing to the companion computer:
              voxl-vision-px4 is crashing on the voxl right now. I am not sure how to fix it !!
                tom admin
                I would rebuild using the master branch and do the following:
                You can use the opkg server in order to install the dependencies.
                In /etc/opkg/opkg.conf uncomment the line #src/gz dev http://voxl-packages.modalai.com/dev.
                Then, call opkg update
                • Install libmodal_json with opkg install libmodal_json
                • Install voxl-mpa-tools with opkg install voxl-mpa-tools
                • Back on your host pc, run ./install-on-voxl.sh
                  Aldo Castro Freire
                  Thank you, that one work and I can changed the port for qgc
                    tom admin @Aldo Castro Freire
                    @Aldo-Castro-Freire Great to hear!
