  3. PWM Pinout 5 only has signal with camera trigger.
9 Posts 3 Posters 2.2k Views 1 Watching
  • Caleb RievleyC Offline
    Caleb Rievley
    I am using a Joystick controller and last week on QGC I was able to change the parameter COM_RC_IN_MODE to Joystick with Virtual RC and map an RC channel to RC_MAP_AUX1.
    This allowed me move the servo into three different positions by setting PWM_MAIN_MAX5 and PWM_MAIN_MIN5 to two different values. The servo signal wire was plugged into the pin 5 on the pwm breakout board (https://www.modalai.com/products/flight-core-pwm-output-cable-and-break-out-board).
    I updated the firmware and flashed the system image between then and now. However, I ended up reverting to the versions that were previously installed because the servo was no longer getting the signal from the breakout. It seems that the 5 pinout on the pwm breakout board is only receiving signal when I enable TRIG_MODE.
    I did the same setup with a Pixhawk and the servo signal rail did power on and let me move the servo but the Voxl-Flight board does not. Is there anything I can check or any information on how to do this? I have already looked through the steps for https://docs.modalai.com/voxl-m500-gimbal-user-guide/#auxillary-outputs.
    Thank you
    • modaltbM Offline
      modaltbM Offline
      modaltb
      Hi @Caleb-Rievley let me look into this and I'll get back to you shortly
      • modaltbM Offline
        modaltbM Offline
        modaltb
        Can you please provide the versions you tested against?
        We ship with a 1.11.3-0.2.3 version currently.
        Caleb RievleyC 1 Reply Last reply
          Caleb Rievley
          @modaltb
          With our joystick (https://www.uxvtechnologies.com/ground-control-stations/micronav/) , Radio Setup (Calibrate) works on Firmware 1.12.3. However no signal from the PWM board from pin 5-8.
          We were able to get signal to the servo rail on the Firmware 1.13 (using sys_ctrl_alloc and the Actuators tab). We are unable to assign joystick controls to the servo. We tried to assign the servo as a gimbal, and use a button on the joystick as gimbal left/right. However the servo does not move.
          Additionally, Radio Setup calibration returns "Detected 0 radio channels. 5 Channels needed". This was not an issue on the previous firmware.
          • wilkinsafW Offline
            wilkinsafW Offline
            wilkinsaf
            @Caleb-Rievley are you loading firmware 1.12 and 1.13 on the VOXL Flight?
            ModalAI comes out with their own versions of PX4. Let me dig up that URL:
            https://docs.modalai.com/flight-core-firmware/
            • wilkinsafW wilkinsaf
              Caleb Rievley
              @wilkinsaf
              I have been uploading from
              https://github.com/PX4/PX4-Autopilot/releases/download/v1.13.0/modalai_fc-v1_default.px4
              wilkinsafW 1 Reply Last reply
              • Caleb RievleyC Caleb Rievley
                @wilkinsaf
                wilkinsafW Offline
                wilkinsafW Offline
                wilkinsaf
                @Caleb-Rievley That is not the right one to pull from. See link posted above. You should get the firmware for Modalai products from modalai website.
                I have made the exact same mistake in the past
                • modaltbM modaltb
                  Caleb Rievley
                  @modaltb
                  I am now working with the firmware that you stated. We are able to passthrough the PWM 5 and 6 pins. Is there anyway to use pins 7 and 8 aswell?
                  • modaltbM Offline
                    modaltbM Offline
                    modaltb
                    Hi @Caleb-Rievley I've only seen channels 5/6 work. I myself am not versed much in the use of mixers etc, but I'm sure it's possible.
