<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[PWM Pinout 5 only has signal with camera trigger.]]></title><description><![CDATA[<p dir="auto">I am using a Joystick controller and last week on QGC I was able to change the parameter COM_RC_IN_MODE to Joystick with Virtual RC and map an RC channel to RC_MAP_AUX1.</p>
<p dir="auto">This allowed me move the servo into three different positions by setting PWM_MAIN_MAX5 and PWM_MAIN_MIN5 to two different values. The servo signal wire was plugged into the pin 5 on the pwm breakout board (<a href="https://www.modalai.com/products/flight-core-pwm-output-cable-and-break-out-board" rel="nofollow ugc">https://www.modalai.com/products/flight-core-pwm-output-cable-and-break-out-board</a>).</p>
<p dir="auto">I updated the firmware and flashed the system image between then and now. However, I ended up reverting to the versions that were previously installed because the servo was no longer getting the signal from the breakout. It seems that the 5 pinout on the pwm breakout board is only receiving signal when I enable TRIG_MODE.</p>
<p dir="auto">I did the same setup with a Pixhawk and the servo signal rail did power on and let me move the servo but the Voxl-Flight board does not. Is there anything I can check or any information on how to do this? I have already looked through the steps for <a href="https://docs.modalai.com/voxl-m500-gimbal-user-guide/#auxillary-outputs" rel="nofollow ugc">https://docs.modalai.com/voxl-m500-gimbal-user-guide/#auxillary-outputs</a>.</p>
<p dir="auto">Thank you</p>
]]></description><link>https://forum.modalai.com/topic/1096/pwm-pinout-5-only-has-signal-with-camera-trigger</link><generator>RSS for Node</generator><lastBuildDate>Tue, 11 Aug 2026 02:48:20 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/1096.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 07 Jul 2022 21:45:32 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to PWM Pinout 5 only has signal with camera trigger. on Sun, 10 Jul 2022 20:23:09 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/caleb-rievley" aria-label="Profile: Caleb-Rievley">@<bdi>Caleb-Rievley</bdi></a> I've only seen channels 5/6 work.  I myself am not versed much in the use of mixers etc, but I'm sure it's possible.</p>
]]></description><link>https://forum.modalai.com/post/5118</link><guid isPermaLink="true">https://forum.modalai.com/post/5118</guid><dc:creator><![CDATA[modaltb]]></dc:creator><pubDate>Sun, 10 Jul 2022 20:23:09 GMT</pubDate></item><item><title><![CDATA[Reply to PWM Pinout 5 only has signal with camera trigger. on Fri, 08 Jul 2022 20:52:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/modaltb" aria-label="Profile: modaltb">@<bdi>modaltb</bdi></a><br />
I am now working with the firmware that you stated. We are able to passthrough the PWM 5 and 6 pins. Is there anyway to use pins 7 and 8 aswell?</p>
]]></description><link>https://forum.modalai.com/post/5099</link><guid isPermaLink="true">https://forum.modalai.com/post/5099</guid><dc:creator><![CDATA[Caleb Rievley]]></dc:creator><pubDate>Fri, 08 Jul 2022 20:52:05 GMT</pubDate></item><item><title><![CDATA[Reply to PWM Pinout 5 only has signal with camera trigger. on Fri, 08 Jul 2022 17:26:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/caleb-rievley" aria-label="Profile: Caleb-Rievley">@<bdi>Caleb-Rievley</bdi></a> That is not the right one to pull from. See link posted above. You should get the firmware for Modalai products from modalai website.</p>
<p dir="auto">I have made the exact same mistake in the past</p>
]]></description><link>https://forum.modalai.com/post/5095</link><guid isPermaLink="true">https://forum.modalai.com/post/5095</guid><dc:creator><![CDATA[wilkinsaf]]></dc:creator><pubDate>Fri, 08 Jul 2022 17:26:50 GMT</pubDate></item><item><title><![CDATA[Reply to PWM Pinout 5 only has signal with camera trigger. on Fri, 08 Jul 2022 17:15:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wilkinsaf" aria-label="Profile: wilkinsaf">@<bdi>wilkinsaf</bdi></a><br />
I have been uploading from</p>
<p dir="auto"><a href="https://github.com/PX4/PX4-Autopilot/releases/download/v1.13.0/modalai_fc-v1_default.px4" rel="nofollow ugc">https://github.com/PX4/PX4-Autopilot/releases/download/v1.13.0/modalai_fc-v1_default.px4</a></p>
]]></description><link>https://forum.modalai.com/post/5093</link><guid isPermaLink="true">https://forum.modalai.com/post/5093</guid><dc:creator><![CDATA[Caleb Rievley]]></dc:creator><pubDate>Fri, 08 Jul 2022 17:15:09 GMT</pubDate></item><item><title><![CDATA[Reply to PWM Pinout 5 only has signal with camera trigger. on Fri, 08 Jul 2022 14:56:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/caleb-rievley" aria-label="Profile: Caleb-Rievley">@<bdi>Caleb-Rievley</bdi></a> are you loading firmware 1.12 and 1.13 on the VOXL Flight?</p>
<p dir="auto">ModalAI comes out with their own versions of PX4. Let me dig up that URL:</p>
<a href="https://docs.modalai.com/flight-core-firmware/" title="Flight Core Firmware">
<img src="https://docs.modalai.com/images/social/docs-card.png" class="card-img-top not-responsive" style="max-height:15rem" alt="Link Preview Image" />
</a>
<div class="card-body">
<h5 class="card-title">
<a class="text-decoration-none" href="https://docs.modalai.com/flight-core-firmware/">
</a>
</h5>
<p class="card-text line-clamp-3">ModalAI technical documentation for VOXL and VOXL 2 Companion Computers for PX4 and ArduPilot Obstacle Avoidance and GPS-denied navigation, assembled in the USA</p>
</div>
<a href="https://docs.modalai.com/flight-core-firmware/" class="card-footer text-body-secondary small d-flex gap-2 align-items-center lh-2">
<img src="https://docs.modalai.com/favicon.ico" alt="favicon" class="not-responsive overflow-hiddden" style="max-width:21px;max-height:21px" />
<p class="d-inline-block text-truncate mb-0">ModalAI Technical Docs <span class="text-secondary">(docs.modalai.com)</span></p>
</a>
</div><p></p>
]]></description><link>https://forum.modalai.com/post/5088</link><guid isPermaLink="true">https://forum.modalai.com/post/5088</guid><dc:creator><![CDATA[wilkinsaf]]></dc:creator><pubDate>Fri, 08 Jul 2022 14:56:03 GMT</pubDate></item><item><title><![CDATA[Reply to PWM Pinout 5 only has signal with camera trigger. on Fri, 08 Jul 2022 00:34:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/modaltb" aria-label="Profile: modaltb">@<bdi>modaltb</bdi></a><br />
With our joystick (<a href="https://www.uxvtechnologies.com/ground-control-stations/micronav/" rel="nofollow ugc">https://www.uxvtechnologies.com/ground-control-stations/micronav/</a>) , Radio Setup (Calibrate) works on Firmware 1.12.3. However no signal from the PWM board from pin 5-8.</p>
<p dir="auto">We were able to get signal to the servo rail on the Firmware 1.13 (using sys_ctrl_alloc and the Actuators tab). We are unable to assign joystick controls to the servo. We tried to assign the servo as a gimbal, and use a button on the joystick as gimbal left/right. However the servo does not move.</p>
<p dir="auto">Additionally, Radio Setup calibration returns  "Detected 0 radio channels. 5 Channels needed". This was not an issue on the previous firmware.</p>
]]></description><link>https://forum.modalai.com/post/5085</link><guid isPermaLink="true">https://forum.modalai.com/post/5085</guid><dc:creator><![CDATA[Caleb Rievley]]></dc:creator><pubDate>Fri, 08 Jul 2022 00:34:19 GMT</pubDate></item><item><title><![CDATA[Reply to PWM Pinout 5 only has signal with camera trigger. on Fri, 08 Jul 2022 00:31:44 GMT]]></title><description><![CDATA[<p dir="auto">Can you please provide the versions you tested against?</p>
<p dir="auto">We ship with a 1.11.3-0.2.3 version currently.</p>
]]></description><link>https://forum.modalai.com/post/5084</link><guid isPermaLink="true">https://forum.modalai.com/post/5084</guid><dc:creator><![CDATA[modaltb]]></dc:creator><pubDate>Fri, 08 Jul 2022 00:31:44 GMT</pubDate></item><item><title><![CDATA[Reply to PWM Pinout 5 only has signal with camera trigger. on Fri, 08 Jul 2022 00:20:50 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/caleb-rievley" aria-label="Profile: Caleb-Rievley">@<bdi>Caleb-Rievley</bdi></a> let me look into this and I'll get back to you shortly</p>
]]></description><link>https://forum.modalai.com/post/5083</link><guid isPermaLink="true">https://forum.modalai.com/post/5083</guid><dc:creator><![CDATA[modaltb]]></dc:creator><pubDate>Fri, 08 Jul 2022 00:20:50 GMT</pubDate></item></channel></rss>
