  3. Voxl cam to qgc
Voxl cam to qgc
4 Posts 3 Posters 666 Views 3 Watching
  • H Offline
    H Offline
    howard
    I would like to stream video from voxl cam to qgc using voxl streamer.I followed the steps but the video is not visible in qgc.I have voxl-camera-server running and voxl-streamer running, and I have also added the rtsp url in qgc video settings,am I missing something? please help
    • H howard
      Eric KatzfeyE Online
      @keil It would be helpful to get some debug output from voxl to help diagnose the issue. Can you send the output of voxl-inspect-services? There is a debug command line option for voxl-streamer. It would be helpful to get the output from that as well. The flag is -d. You'll want to start voxl-streamer from the command line using whatever options you normally use plus the -d option. Make sure that voxl-streamer is not already running when you do this. If it has been auto started with a systemd service then you can stop it with systemctl stop voxl-streamer. And I'm guessing that you already looked through the voxl-streamer documentation at https://docs.modalai.com/voxl-streamer/?
      • H Offline
        H Offline
        howard
        this is the output when I run voxl-streamer -d
        Enabling debug messages
        Using configuration file /etc/modalai/voxl-streamer.conf
        MPA interface chosen
        Input pipe name /run/mpa/tracking/
        Output stream width 640
        Output stream height 480
        Output stream bitrate 1000000
        Output stream rotation 0
        Output frame decimator 2
        No image overlay specified
        when I run voxl-inspect-services
        docker-autorun       | Disabled  | Not Running | Not Running
         docker-daemon        | Disabled  | Not Running | Not Running
         modallink-relink     | Disabled  | Not Running | Not Running
         voxl-camera-server   |  Enabled  | Not Running | Not Running
         voxl-mavlink-server  | Disabled  | Not Running | Not Running
         voxl-modem           | Disabled  | Not Running | Not Running
         voxl-portal          |  Enabled  | Not Running | Not Running
         voxl-qvio-server     |  Enabled  |   Running   |     0.0
         voxl-streamer        | Disabled  | Not Running | Not Running
         voxl-time-sync       | Disabled  | Not Running | Not Running
         voxl-vision-px4      |  Enabled  |   Running   |     4.0
         voxl-wait-for-fs     |  Enabled  |  Completed  |  Completed
        • ? Offline
          @keil said in Voxl cam to qgc:
          It looks like the camera server has encountered an error when trying to start since it's enabled but not running, this is usually due to either a misconfiguration or a hardware issue. Can you show what journalctl -u voxl-camera-server and cat /etc/modalai/voxl-camera-server.conf look like. These are the camera server logs and config file respectively.
