    About camera configuration for M500 frame.
    VOXL m500 Reference Drone
    • Kaiba-KunK
      Kaiba-Kun
      Hello, i want to ask about camera configuration. After reset m500 by voxl-configure-modalai-vl and setup again follow the guide. I also re-config voxl-vision-px4 to the factory set-up because it's look like when reset modalai-vl the NED position also lost. When i tried with position mode it seem the UAV flies is not good as well as the first time flight.
      • for voxl-configure-cameras i choose the option 3.
      • Here is some information. i think the config is not same as the manual document.
      • cat /etc/snav/camera.downward.xml
      • cat /etc/snav/camera.stereo.xml
        -> Did i was wrong? M500 driff so much when tried to flies in position mode.
      • Kaiba-KunK
        Kaiba-Kun
        do you have any idea? @modaltb.
        • modaltbM
          modaltb ModalAI Team
          Hi @Kaiba-Kun ,
          Hmm, we normally use voxl-configure-vision-px4 when setting up the vehicle.
          For the m500, we have a -f option which will set it to factory state with respect to voxl-vision-px4, so voxl-configure-vision-px4 -f
          The camera configs in the ENV variables should be fine after this.
          I'd try that option above, if you've configured your GCS IP address in the config file needs to be updated, eg.
          vi /etc/modalai/voxl-vision-px4.conf and setup your GCS IP after running with the -f flag.
          After that, I'd then reboot the system, and then do a 'hand flight' validation, where you can pick the vehicle up and move around, validating local position NED in QGC.
          Here's a video where I do this: https://youtu.be/gTuSaHLCz8w?t=571
