<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[About camera configuration for M500 frame.]]></title><description><![CDATA[<p dir="auto">Hello, i want to ask about camera configuration. After reset m500 by  <strong>voxl-configure-modalai-vl</strong> and setup again follow the guide. I also re-config  <strong>voxl-vision-px4</strong> to the factory set-up because it's look like when reset modalai-vl the NED position also lost. When i tried with position mode it seem the UAV flies is not good as well as the first time flight.</p>
<ul>
<li>for voxl-configure-cameras i choose the option 3.<br />
<img src="/assets/uploads/files/1611800333686-c6237751-57a1-4d03-9c33-f76409bbb05c-image.png" alt="c6237751-57a1-4d03-9c33-f76409bbb05c-image.png" class=" img-fluid img-markdown" /></li>
<li>Here is some information. i think the config is not same as the manual document.<br />
<img src="/assets/uploads/files/1611800030159-026e376e-a37d-4bc3-875a-0f89bb7e55b5-image.png" alt="026e376e-a37d-4bc3-875a-0f89bb7e55b5-image.png" class=" img-fluid img-markdown" /><br />
<img src="/assets/uploads/files/1611800047468-9fb042a5-2d32-4977-8826-2783d678ea41-image.png" alt="9fb042a5-2d32-4977-8826-2783d678ea41-image.png" class=" img-fluid img-markdown" /></li>
<li>cat /etc/snav/camera.downward.xml<br />
<img src="/assets/uploads/files/1611800135773-1e777ba3-0f60-4123-88a1-29548a24957a-image.png" alt="1e777ba3-0f60-4123-88a1-29548a24957a-image.png" class=" img-fluid img-markdown" /><br />
<img src="/assets/uploads/files/1611800179166-e9378da2-2676-4541-9203-6c32452cecab-image.png" alt="e9378da2-2676-4541-9203-6c32452cecab-image.png" class=" img-fluid img-markdown" /></li>
<li>cat /etc/snav/camera.stereo.xml<br />
<img src="/assets/uploads/files/1611800251367-cf54d95d-6b48-42c0-b7ee-705b4033e266-image.png" alt="cf54d95d-6b48-42c0-b7ee-705b4033e266-image.png" class=" img-fluid img-markdown" /><br />
<img src="/assets/uploads/files/1611800266374-923e47e6-edd9-43b6-8748-9fc7149facb0-image.png" alt="923e47e6-edd9-43b6-8748-9fc7149facb0-image.png" class=" img-fluid img-markdown" /><br />
-&gt; Did i was wrong? M500 driff so much when tried to flies in position mode.</li>
</ul>
]]></description><link>https://forum.modalai.com/topic/115/about-camera-configuration-for-m500-frame</link><generator>RSS for Node</generator><lastBuildDate>Mon, 07 Sep 2026 23:51:39 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/115.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 28 Jan 2021 02:23:20 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to About camera configuration for M500 frame. on Thu, 28 Jan 2021 16:16:59 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/kaiba-kun" aria-label="Profile: Kaiba-Kun">@<bdi>Kaiba-Kun</bdi></a> ,</p>
<p dir="auto">Hmm, we normally use <code>voxl-configure-vision-px4</code> when setting up the vehicle.</p>
<p dir="auto">For the m500, we have a <code>-f</code> option which will set it to factory state with respect to voxl-vision-px4, so <code>voxl-configure-vision-px4 -f</code></p>
<p dir="auto">The camera configs in the ENV variables should be fine after this.</p>
<p dir="auto">I'd try that option above, if you've configured your GCS  IP address in the config file needs  to be updated, eg.</p>
<p dir="auto"><code>vi /etc/modalai/voxl-vision-px4.conf</code> and setup your GCS IP after running with the <code>-f</code> flag.</p>
<p dir="auto">After that, I'd then reboot the system, and then do a 'hand flight' validation, where you can pick the vehicle up and move around, validating local position NED in QGC.</p>
<p dir="auto">Here's a video where I do this: <a href="https://youtu.be/gTuSaHLCz8w?t=571" rel="nofollow ugc">https://youtu.be/gTuSaHLCz8w?t=571</a></p>
]]></description><link>https://forum.modalai.com/post/477</link><guid isPermaLink="true">https://forum.modalai.com/post/477</guid><dc:creator><![CDATA[modaltb]]></dc:creator><pubDate>Thu, 28 Jan 2021 16:16:59 GMT</pubDate></item><item><title><![CDATA[Reply to About camera configuration for M500 frame. on Thu, 28 Jan 2021 02:31:53 GMT]]></title><description><![CDATA[<p dir="auto">do you have any idea? <a class="plugin-mentions-user plugin-mentions-a" href="/user/modaltb" aria-label="Profile: modaltb">@<bdi>modaltb</bdi></a>.</p>
]]></description><link>https://forum.modalai.com/post/474</link><guid isPermaLink="true">https://forum.modalai.com/post/474</guid><dc:creator><![CDATA[Kaiba-Kun]]></dc:creator><pubDate>Thu, 28 Jan 2021 02:31:53 GMT</pubDate></item></channel></rss>
