  2. VOXL SDK and Software
  3. Building new docker image error - Cmake version not good
10 Posts 4 Posters 3.8k Views 3 Watching
  • M Offline
    M Offline
    marian
    I'm trying to build a new docker image on Voxl Flight deck and I get this error:
    Step 10 : RUN cmake -DCMAKE_BUILD_TYPE=Debug -DBUILD_SHARED_LIBS=ON -Bbuild/default -H.
    ---> Running in 88527c85a1aa
    CMake Error at CMakeLists.txt:1 (cmake_minimum_required):
    CMake 3.13 or higher is required. You are running version 3.10.2
    In the existent image the verison is till 3.10.2 and is the newest as seeing below:
    root@apq8096:/home/MAVSDK/examples/takeoff_land# apt-get install cmake
    Reading package lists... Done
    Building dependency tree
    cmake is already the newest version (3.10.2-1ubuntu2.18.04.2).
    0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
    Please let me know how to deal with it.
      It looks like you need to be using a newer version of cmake. Can you share the Docker file? make sure you're running 'apt update' to get the latest packages
      • Eric KatzfeyE Offline
        What file system are you using in your Docker? A version of Ubuntu?
        • M Offline
          M Offline
          marian
          @Chad-Sweet The docker file was downloaded from here https://gitlab.com/voxl-public/voxl-docker-images/voxl-docker-mavsdk-cpp
          The Docker file:
          yocto:/data/docker/mavsdk-cpp$ more Dockerfile
          FROM arm64v8/ubuntu:bionic
          WORKDIR /home
          RUN apt-get update
          RUN apt-get install cmake build-essential colordiff git doxygen -y
          RUN apt install git -y
          RUN git clone https://github.com/mavlink/MAVSDK.git
          WORKDIR /home/MAVSDK
          RUN git checkout main
          RUN git submodule update --init --recursive
          RUN cmake --build build/default --target install
          RUN ldconfig
          WORKDIR /home/MAVSDK/examples/takeoff_land
          COPY takeoff_and_land.cpp .
          RUN cmake .
          RUN make
          CMD ["/bin/bash"]
          @Eric-Katzfey I activated docker on VOXL with voxl-configure-docker.sh and i use the system versiondelivered with the voxl deck, I didn't change it.
          Here are the info of system version:
          / # bash
          yocto:/$ uname -a
          Linux apq8096 3.18.71-perf #1 SMP PREEMPT Sun Jun 6 19:41:01 UTC 2021 aarch64 GNU/Linux
          yocto:/$
          yocto:/$ docker run -it --rm --privileged --net=host gcr.io/modalai-public/voxl-mavsdk-cpp:v1.0 /bin/bash
          root@apq8096:/home/MAVSDK/examples/takeoff_land# uname -a
          Linux apq8096 3.18.71-perf #1 SMP PREEMPT Sun Jun 6 19:41:01 UTC 2021 aarch64 aarch64 aarch64 GNU/Linux
            I found these instructions for updating cmake https://askubuntu.com/questions/355565/how-do-i-install-the-latest-version-of-cmake-from-the-command-line. You can try these instructions to update the cmake version.
            • M Offline
              M Offline
              marian
              Hi @Eric-Katzfey I followed up the full reinstall of the cmake in docker on voxl platform, and it is goes well but once I exited from the docker and come back it put back the 3.10.2 version as show below:
              Could you, please, guide me forward to resolve this?
                This post on stack overflow might help? https://stackoverflow.com/questions/44480740/how-to-save-a-docker-container-state
                • C Offline
                  C Offline
                  CY-1992
                  @marian Try to use base image arm64v8/ubuntu:20.04 in Dockerfile. It has the latest cmake version.
                  FROM arm64v8/ubuntu:20.04
                  • M marian
                    @marian Anything you do while a docker image is running (as a container) isn't saved back to the base image. There are generally 2 ways to approach this. The preferred method is to add the new commands to the dockerfile and rebuild the image. The second approach is to run docker commit to save changes to a currently running container https://docs.docker.com/engine/reference/commandline/commit/.
                    • M Offline
                      M Offline
                      marian
                      @CY-1992 said in Building new docker image error - Cmake version not good:
                      ubuntu:20.04
                      Thanks @CY-1992 is working just fine!
