    Building new docker image error - Cmake version not good
    Software Development
    3078
    • M
      marian
      I'm trying to build a new docker image on Voxl Flight deck and I get this error:
      Step 10 : RUN cmake -DCMAKE_BUILD_TYPE=Debug -DBUILD_SHARED_LIBS=ON -Bbuild/default -H.
      ---> Running in 88527c85a1aa
      CMake Error at CMakeLists.txt:1 (cmake_minimum_required):
      CMake 3.13 or higher is required. You are running version 3.10.2
      In the existent image the verison is till 3.10.2 and is the newest as seeing below:
      root@apq8096:/home/MAVSDK/examples/takeoff_land# apt-get install cmake
      Reading package lists... Done
      Building dependency tree
      cmake is already the newest version (3.10.2-1ubuntu2.18.04.2).
      0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
      Please let me know how to deal with it.
      • Chad SweetC
        Chad Sweet ModalAI Team
        It looks like you need to be using a newer version of cmake. Can you share the Docker file? make sure you're running 'apt update' to get the latest packages
          Eric Katzfey ModalAI Team
          What file system are you using in your Docker? A version of Ubuntu?
          • M
            marian
            @Chad-Sweet The docker file was downloaded from here https://gitlab.com/voxl-public/voxl-docker-images/voxl-docker-mavsdk-cpp
            The Docker file:
            yocto:/data/docker/mavsdk-cpp$ more Dockerfile
            FROM arm64v8/ubuntu:bionic
            WORKDIR /home
            RUN apt-get update
            RUN apt-get install cmake build-essential colordiff git doxygen -y
            RUN apt install git -y
            RUN git clone https://github.com/mavlink/MAVSDK.git
            WORKDIR /home/MAVSDK
            RUN git checkout main
            RUN git submodule update --init --recursive
            RUN cmake --build build/default --target install
            RUN ldconfig
            WORKDIR /home/MAVSDK/examples/takeoff_land
            COPY takeoff_and_land.cpp .
            RUN cmake .
            RUN make
            CMD ["/bin/bash"]
            @Eric-Katzfey I activated docker on VOXL with voxl-configure-docker.sh and i use the system versiondelivered with the voxl deck, I didn't change it.
            Here are the info of system version:
            / # bash
            yocto:/$ uname -a
            Linux apq8096 3.18.71-perf #1 SMP PREEMPT Sun Jun 6 19:41:01 UTC 2021 aarch64 GNU/Linux
            yocto:/$
            yocto:/$ docker run -it --rm --privileged --net=host gcr.io/modalai-public/voxl-mavsdk-cpp:v1.0 /bin/bash
            root@apq8096:/home/MAVSDK/examples/takeoff_land# uname -a
            Linux apq8096 3.18.71-perf #1 SMP PREEMPT Sun Jun 6 19:41:01 UTC 2021 aarch64 aarch64 aarch64 GNU/Linux
              I found these instructions for updating cmake https://askubuntu.com/questions/355565/how-do-i-install-the-latest-version-of-cmake-from-the-command-line. You can try these instructions to update the cmake version.
              • M
                marian
                Hi @Eric-Katzfey I followed up the full reinstall of the cmake in docker on voxl platform, and it is goes well but once I exited from the docker and come back it put back the 3.10.2 version as show below:
                Could you, please, guide me forward to resolve this?
                • Chad SweetC
                  This post on stack overflow might help? https://stackoverflow.com/questions/44480740/how-to-save-a-docker-container-state
                  • C
                    CY-1992
                    @marian Try to use base image arm64v8/ubuntu:20.04 in Dockerfile. It has the latest cmake version.
                    FROM arm64v8/ubuntu:20.04
                      Eric Katzfey ModalAI Team @marian
                      @marian Anything you do while a docker image is running (as a container) isn't saved back to the base image. There are generally 2 ways to approach this. The preferred method is to add the new commands to the dockerfile and rebuild the image. The second approach is to run docker commit to save changes to a currently running container https://docs.docker.com/engine/reference/commandline/commit/.
                      • M
                        marian
                        @CY-1992 said in Building new docker image error - Cmake version not good:
                        ubuntu:20.04
                        Thanks @CY-1992 is working just fine!
