    Reading data from J13 - Expansion B2B connection on m500
    • yu zhangY
      yu zhang
      Hi team,
      Since m500 has a J13 Expansion B2B connection, I am wondering if I could plug in a general type of sensor by using the J13 and reading data in VOXL?
      I understand it should be used for USB extension board or connecting LET, but I would think to use this connector for other sensors. The J13 looks like a general 60-pin HD connector, right? So, I am thinking if it could be compatible with a sensor that has a general 60-pin connector.
      If so, can you please advise how could I read data from J13 or will it be used just like a normal one (reading data from terminal)?
      • Chad SweetC
        Chad Sweet ModalAI Team
        J13 is the connector we use for add-on boards. There are no 3rd party sensors that plug into that port. The debug board can be used with USB for general expansion
        yu zhangY 1 Reply Last reply Reply Quote 0
        • yu zhangY
          yu zhang @Chad Sweet
          @Chad-Sweet Thanks, I see. I had the debug board, but it may not be able to work for special expansion. Anyways, I will think about that.
