  2. VOXL Accessories
  3. Power Modules
  4. Did I just fry my flight core?
Scheduled Pinned Locked Moved Power Modules
4 Posts 3 Posters 1.7k Views 1 Watching
  • J Offline
    J Offline
    jskard
    I inadvertently connected a 19V supply to the Barrel Jack on my Voxl m500 drone. What are the odds I only damaged the power module and not my flight core? Are there any easy ways to check?
    • VinnyV Offline
      On older drones where we have a V2 power module with barrel jack access port for the flight controller, the maximum that can sustain is 5.5V (5V +/- 10%).
      It is very likely you exposed several circuits on FlightCore to a condition much worse than absolute maximum and I would expect either outright failure to operate or worse (fusing/smoking). If by chance your hardware still works, it likely has a latent defect that will fail later. In my honest opinion, I would only power it on outside in the event of fusing/smoke, but would tag it and recycle it or use it for a mechanical reference.
      The power module is still likely OK. Most components on that design allow operation above 20V.
      Hope that helps.
      • J Offline
        J Offline
        jskard
        wrote on last edited by jskard
        • J jskard
          Eric KatzfeyE Online
          @jskard Would it be possible for you to please open up new forum posts for these new questions so that they can be better tracked? Thanks!
