M0155 GPIO 109 Sync Output and IR/EO Camera Synchronization
Hardware: (board / drone / SKU, serial # if you have it): voxl2
Software version: (paste the output of
voxl-version)Configuration / services: (paste the output of
voxl-inspect-services)What I am trying to do:
- When the M0155 board is connected to VOXL 2, is GPIO 109 enabled to output a 30 Hz sync signal, as it is with the M0173 board?
- If we connect IR and EO cameras to the J6 and J7 connectors on VOXL 2 through the M0155 board, will the cameras be synchronized automatically, or are software configuration changes required?
What actually happens: (error messages, behavior)
Steps to reproduce:
Logs / pictures: (attach files; PX4 logs -> https://logs.px4.io)
Hi @김다연
- GPIO 109 sync through M0155
Yes. GPIO 109 is on pin 26 of J6, J7 and J8, and M0155 passes it through to the sensor. Same sync signal M0173 uses. It is driven by voxl-fsync-mod.
- IR + EO on J6 and J7
Not automatic. Two things are required in software. The sensors must be running a sensor module built with sync input enabled (the fsin variants under /usr/share/modalai/chi-cdk/, selected by camera HW ID), and voxl-fsync-mod must be enabled and configured for the correct GPIO. Without the fsin sensor module, the sensor ignores the trigger and free-runs.
The fsync period also sets the frame rate, which is the cleaner answer to your earlier 8.6 fps question: drive the rate from voxl-fsync-mod rather than adding a sensor mode to the driver.
Currently, none of the Thermal cameras (Boson) we support use hardware synchronization. The same is true for the EO cameras (IMX412, IMX664, etc).
Only AR0144 cameras are currently enabled with sync input and correct sensormodule for the camera needs to be selected (either _combo or _fsin). Sorry this is a bit vague, not sure how detailed we need to discuss here.
Also, please note that you cannot connect a thermal camera (Boson) via M0155 - this adapter is only for EO cameras. there is a difference in pinout and voltages provided. Please see https://www.modalai.com/products/m0155, it lists supported cameras.
If you let us know what functionality you are trying to achieve, we can provide more guidance. Please describe all the cameras that you want to connect and which should by sync'ed. Is it only one EO or one IR (which)?
