<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M0155 GPIO 109 Sync Output and IR/EO Camera Synchronization]]></title><description><![CDATA[<p dir="auto"><strong>Hardware:</strong> (board / drone / SKU, serial # if you have it): voxl2</p>
<p dir="auto"><strong>Software version:</strong> (paste the output of <code>voxl-version</code>)</p>
<p dir="auto"><strong>Configuration / services:</strong> (paste the output of <code>voxl-inspect-services</code>)</p>
<p dir="auto"><strong>What I am trying to do:</strong></p>
<ol>
<li>When the M0155 board is connected to VOXL 2, is GPIO 109 enabled to output a 30 Hz sync signal, as it is with the M0173 board?</li>
<li>If we connect IR and EO cameras to the J6 and J7 connectors on VOXL 2 through the M0155 board, will the cameras be synchronized automatically, or are software configuration changes required?</li>
</ol>
<p dir="auto"><strong>What actually happens:</strong> (error messages, behavior)</p>
<p dir="auto"><strong>Steps to reproduce:</strong></p>
<p dir="auto"><strong>Logs / pictures:</strong> (attach files; PX4 logs -&gt; <a href="https://logs.px4.io" rel="nofollow ugc">https://logs.px4.io</a>)</p>
]]></description><link>https://forum.modalai.com/topic/5536/m0155-gpio-109-sync-output-and-ir-eo-camera-synchronization</link><generator>RSS for Node</generator><lastBuildDate>Wed, 04 Nov 2026 02:29:56 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/5536.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 03 Nov 2026 07:36:00 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M0155 GPIO 109 Sync Output and IR/EO Camera Synchronization on Tue, 03 Nov 2026 22:47:17 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/%EA%B9%80%EB%8B%A4%EC%97%B0" aria-label="Profile: 김다연">@<bdi>김다연</bdi></a></p>
<ol>
<li>GPIO 109 sync through M0155</li>
</ol>
<p dir="auto">Yes. GPIO 109 is on pin 26 of J6, J7 and J8, and M0155 passes it through to the sensor. Same sync signal M0173 uses. It is driven by voxl-fsync-mod.</p>
<ol start="2">
<li>IR + EO on J6 and J7</li>
</ol>
<p dir="auto">Not automatic. Two things are required in software. The sensors must be running a sensor module built with sync input enabled (the <em>fsin</em> variants under /usr/share/modalai/chi-cdk/, selected by camera HW ID), and voxl-fsync-mod must be enabled and configured for the correct GPIO. Without the fsin sensor module, the sensor ignores the trigger and free-runs.</p>
<p dir="auto">The fsync period also sets the frame rate, which is the cleaner answer to your earlier 8.6 fps question: drive the rate from voxl-fsync-mod rather than adding a sensor mode to the driver.</p>
]]></description><link>https://forum.modalai.com/post/27030</link><guid isPermaLink="true">https://forum.modalai.com/post/27030</guid><dc:creator><![CDATA[Vinny]]></dc:creator><pubDate>Tue, 03 Nov 2026 22:47:17 GMT</pubDate></item></channel></rss>
