VOXL2 M0054-1 has no USB/ADB after SDK 1.8 upgrade and successful QDL recovery
Hardware: VOXL 2 M0054-1 (QRB5165M)
Original SKU: MRB-D0014-4-V1-C27-T0-M18-X8
ADB/fastboot serial: 3f621d35
Original machine/variant/config: 1.0.1
Recorded SoC ID: 455Software version:
Complete voxl-version output saved before the upgrade, when the board was still reachable over ADB:
──────────────────────────────────────────────────────────────────────────────── system-image: 1.8.06-M0054-14.1a-perf kernel: #1 SMP PREEMPT Wed Oct 22 04:13:18 UTC 2025 4.19.125 ──────────────────────────────────────────────────────────────────────────────── hw platform: M0054 mach.var: 1.0.1 SKU: MRB-D0014-4-V1-C27-T0-M18-X8 ──────────────────────────────────────────────────────────────────────────────── voxl-suite: 1.6.3 ──────────────────────────────────────────────────────────────────────────────── Packages: Repo: http://voxl-packages.modalai.com/ ./dists/qrb5165/sdk-1.6/binary-arm64/ Last Updated: 2023-03-02 12:59:12 WARNING: repo file has changed since last update, packages may have originated from a different repo List: libfc-sensor 1.0.9 libmodal-cv 0.6.0 libmodal-exposure 0.1.4 libmodal-flow 1.0.3 libmodal-journal 0.2.7 libmodal-json 0.4.8 libmodal-pipe 2.14.11 libqrb5165-io 0.6.3 libvoxl-cci-direct 0.3.3 libvoxl-codec 0.0.2 libvoxl-cutils 0.1.6 modalai-slpi 1.2.2 mv-voxl 0.1-r0 qrb5165-bind 0.1-r0 qrb5165-dfs-server 0.2.0 qrb5165-mini-tof-server 0.2.2 qrb5165-rangefinder-server 0.1.6 qrb5165-slpi-test-sig 01-r0 qrb5165-tflite 2.17.2 voxl-bind-spektrum 0.1.1 voxl-camera-calibration 0.6.1 voxl-camera-server 2.2.19 voxl-ceres-solver 2:2.0.0-2 voxl-configurator 1.1.5 voxl-cpu-monitor 0.7.7 voxl-docker-support 1.3.1 voxl-elrs 1.1.0 voxl-esc 1.5.7 voxl-esptool 0.2.0 voxl-feature-tracker 0.5.2 voxl-flow-server 0.3.6 voxl-gphoto2-server 0.0.10 voxl-imu-server 2.0.1 voxl-io-server 0.0.8 voxl-jpeg-turbo 2.1.3-7 voxl-lepton-server 1.3.3 voxl-lepton-tracker 0.0.4 voxl-libgeographic 1.0.0 voxl-libgphoto2 0.0.4 voxl-libuvc 1.0.7 voxl-logger 0.6.1 voxl-mavcam-manager 0.6.0 voxl-mavlink 0.1.6 voxl-mavlink-server 1.4.14 voxl-modem 1.2.3 voxl-mongoose 7.19.0 voxl-mpa-to-ros 0.3.9 voxl-mpa-tools 1.5.6 voxl-nano-tracker 0.1.7 voxl-open-vins-server 0.6.0 voxl-opencv 4.5.5-3 voxl-osd 0.3.8 voxl-portal 0.8.7 voxl-px4 1.14.0-2.0.133 voxl-px4-params 0.9.0 voxl-qvio-server 1.2.3 voxl-remote-id 0.0.9 voxl-reset-slpi 0.0.1 voxl-state-estimator 0.0.6 voxl-streamer 0.8.0 voxl-suite 1.6.3 voxl-tag-detector 0.1.0 voxl-tflite-server 0.5.1 voxl-utils 2.0.2 voxl-uvc-server 0.1.7 voxl-vision-hub 1.9.21 voxl-vtx 2.0.2 voxl-wavemux 0.0.3 voxl2-io 0.0.3 voxl2-security-hardening-utls 1.0-r0 voxl2-system-image 1.8.06-r0 voxl2-wlan 1.0-r0 ────────────────────────────────────────────────────────────────────────────────Attempted upgrade: official VOXL2 SDK 1.8.0, containing system image 1.8.09-M0054-14.1a-perf-20261009. The archive MD5 matches the published 7c83184458a3d4c89cf153fc8231f712.
The installer automatically selected M0054-1 Config 1/M0173:
kernel: m0054-1-var00.1-kernel.img devcfg: devcfg-m0054-1-v8.mbnThe system-image flash completed, but ADB never returned, so the SDK 1.8.0 packages were not installed.
Subsequent factory recovery used the official M0054(154)-1.zip flat build and ModalAI's modal-qdl tool, commit 136f4b7941fbaad37066552fbfea3eb47645f592.
This is the pre-upgrade output, not a reading of the recovered image. Current voxl-version output cannot be collected because normal boot exposes no USB/ADB.
Configuration / services:
Current voxl-inspect-services output is unavailable: the board exposes no USB/ADB after boot. Our saved diagnostics do not contain a pre-upgrade output of that command.
The board previously booted and ran PX4 HITL. The intended setup uses a NUC for ModalAI's Gazebo Classic simulator, J18 serial for HITL, and J9 USB for ADB.
For the latest boot checks, the VOXL is bare: only main power and J9 USB are connected, with no cameras, add-on boards or J18 wiring. SW2 is OFF and SW1 is released. Both power and USB were disconnected before each cold boot.
We tested USB on the Ubuntu 24.04 NUC and an Ubuntu 22.04.5 PC. USB 3 repeatedly reset during fastboot communication on both hosts. USB 2 through a hub allowed stable fastboot reads and the full QDL flash, but normal boot still exposes no USB device.
What I am trying to do:
Install SDK 1.8.0 on this VOXL2 and use it as a basic PX4 HITL development rig.
What actually happens:
The SDK system-image flash reports completion, but the board never returns to ADB. Loading the matching SDK kernel with fastboot boot also reports Booting OKAY, then exposes no USB/ADB.
Factory QDL recovery reports success, including both boot partitions, GPT patches and the bootable marker:
[PROGRAM] flashed "boot_a" successfully [PROGRAM] flashed "boot_b" successfully [MODALAI] ==== Completed patch_execute ==== partition 1 is now bootableThe final reset prints:
firehose operation timed out [MODALAI] ==== Completed firehose_reset ==== [MODALAI] Completed firehose_run QDL exit status: 0There were 965 successful program operations. After cold boot with SW2 OFF, lsusb shows no VOXL device and adb devices is empty. The current symptom is no USB enumeration, rather than a persistent 900e or 9008 device. In EDL before flashing, the device was detected as 05c6:9008 at 480 Mbps.
LEDs remain unchanged: DS1 solid green; DS2 slow green blinking, approximately a 1–2 second period; D1 greenish solid. Repeated bare-board power/USB cycles have not changed the result.
We have not encountered this problem on our other devices, so we suspect it may be related to this board being the M0054-1 (-1) hardware version. This is a hypothesis; we have not established the root cause.
Steps to reproduce:
- Start with the ADB-accessible M0054-1 and pre-upgrade versions above.
- Run the official SDK 1.8.0 installer with ./install.sh -n -m. It detects Config 1 and selects m0054-1-var00.1-kernel.img.
- Observe Done Flashing and a successful fastboot reboot, followed by an indefinite wait for ADB. Cold power/USB cycles do not restore detection.
- On a stable USB 2 connection, try fastboot boot with the matching SDK kernel. The command succeeds, but ADB still does not appear.
- Stop the waiting installer with no writes active. Enter EDL with SW2 ON and flash M0054(154)-1.zip using ModalAI's programmer, rawprogram XMLs and patch XMLs.
- Observe completed programming/patches, partition 1 is now bootable, the final reset timeout and QDL exit status 0.
- Disconnect both power and USB, set SW2 OFF, wait 10 seconds, then reconnect main power followed by J9 USB with SW1 released.
- With only power and USB attached, observe no VOXL USB device or ADB. Repeat the cold cycle and observe the same LEDs and detection result.
Only one factory QDL flash has been performed. We have stopped further flashing pending guidance. The SDK installer log also contains an unset TERM/tput warning and a shell arithmetic error before flashing; it subsequently reports all flash operations complete. These messages are retained in the log.
Logs / pictures:
Attachment prepared: modalai-support-2026-10-23.zip, containing:
- Full SDK installer log and exit marker (143 after stopping the waiting installer).
- Full QDL recovery log and exit marker (0).
- Original voxl-version output.
- Current USB/ADB/fastboot detection output and a filtered PC kernel USB event log.
- A detailed diagnostic report with image checksums and the recovery command.
No new PX4 flight log is available for this boot failure because we cannot reach or start PX4. The relevant evidence is the installer, recovery and USB logs listed above.
We followed https://docs.modalai.com/voxl2-unbricking/ and https://docs.modalai.com/voxl2-PX4-hitl/.
Could you confirm whether M0054(154)-1.zip and the SDK 1.8.0 Config 1/var00.1 kernel are correct for this board, and whether there is a known issue specific to the -1 hardware? Does the final Firehose reset timeout indicate a problem despite the successful programming and bootable marker? Please advise on a targeted boot-console diagnostic or other steps. Thanks.
Update on this, I tried following this post which has helped before, but it also did not help in this case:
https://forum.modalai.com/topic/2789/voxl2-stuck-in-fastboot?_=1792769614627So I tried SDK 1.8.0’s
flash-system-image.sh -f: all writes completed, but both boot slots became unbootable and ADB never returned.RAM boot of either M0054-1 kernel (
var00.0orvar00.1) fails withFailed to load/authenticate boot image: Load Error. -
We tried to roll it back to 1.6.3 but it now remains locked in fastboot. Any recommendations on this @eric-katzfey ?
Trying to line up the correct engineer to help out with this. As a side note regarding HITL, you can also now use SIH for simulation. This is much easier to setup and in many cases just as effective as HITL. https://docs.modalai.com/px4-sih/
@simiken1234 Thanks for the detailed report and logs.
The images are correct. Your saved mach.var of 1.0.1 means M0054-1 hardware running the var00.1 (M0173) kernel, so the SDK 1.8.0 installer picked the right kernel and M0054(154)-1.zip is the right flat build. See VOXL 2 HW Versions.
The firehose reset timeout is expected and not a problem. See the note in Flash Flat Build.
A full factory flat build that still shows no USB device on a bare, cold-booted board, plus USB 3 resetting on two different hosts, points to a hardware problem on this board rather than SDK 1.8.0 or the -1 revision. Please do one more clean QDL flash of M0054(154)-1.zip over the USB 2 connection that worked. If it still does not come up as 05c6:901d, follow this section and request an RMA with the board serial (3f621d35), a link to this thread, and your support zip. Please hold off on further flash-system-image.sh or fastboot boot attempts in the meantime.
