  3. USB camera live streaming through Microhard carrier board
15 Posts 3 Posters 1.1k Views 1 Watching
  • Eric KatzfeyE Offline
    Have you attempted any trouble shooting? What if you stream a connected camera with voxl-streamer, does it still do the same thing? Did you try streaming over WiFi or Ethernet? Does the voxl-uvc-server generate any error or diagnostic messages? Can you try a different USB camera (non-Lepton)? I'd recommend trying with a Logitech C270.
      Jetson NanoJ Offline
      Jetson Nano
      Veteran
      I did not try streaming over wifi, i only try using Microhard.
      The following arr log files of lepton.
      This is the log file while trying to recreate the scenario. I am not able to connect to the VLC through rtsp but the rtsp stream is visible through ffplay, I attaching that log too.
      the following are the log files of rtsp stream and connecting through vlc only.
      voxl2:/$ voxl-streamer --standalone --port 8904 -i uvc
      Waiting for pipe uvc to appear
      Found Pipe
      detected following stats from pipe:
      w: 160 h: 120 fps: 9 format: YUV422_UYVY
      Stream available at rtsp://127.0.0.1:8904/live
      A new client rtsp://192.168.168.150:46960(null) has connected, total clients: 1
      Camera server Connected
      A new client rtsp://192.168.168.150:46976(null) has connected, total clients: 2
      rtsp client disconnected, total clients: 1
      rtsp client disconnected, total clients: 0
      no more rtsp clients, closing source pipe intentionally
      this is the log file of when I ran first using ffplay, then tried with vlc. that when the error again was observed.
      voxl2:/$ voxl-streamer --standalone --port 8901 -i uvc
      Found Pipe
      Stream available at rtsp://127.0.0.1:8901/live
      A new client rtsp://192.168.168.150:60200(null) has connected, total clients: 1
      A new client rtsp://192.168.168.150:60210(null) has connected, total clients: 2
      ERROR:   New frame rejected, status = -2
      Removed 1 sessions
      A new client rtsp://192.168.168.150:49562(null) has connected, total clients: 1
      A new client rtsp://192.168.168.150:49570(null) has connected, total clients: 2
      (voxl-streamer:28035): GLib-GObject-WARNING **: 16:00:31.725: instance with invalid (NULL) class pointer
      (voxl-streamer:28035): GLib-GObject-CRITICAL **: 16:00:31.726: g_signal_emit_by_name: assertion 'G_TYPE_CHECK_INSTANCE (instance)' failed
      A new client rtsp://192.168.168.150:58654(null) has connected, total clients: 1
      A new client rtsp://192.168.168.150:58656(null) has connected, total clients: 2
      A new client rtsp://192.168.168.150:45852(null) has connected, total clients: 1
      Removed 1 sessions
      t@t:~$ ffplay -rtsp_transport tcp rtsp://192.168.168.100:8901/live
      ffplay version 4.4.2-0ubuntu0.22.04.1 Copyright (c) 2003-2021 the FFmpeg developers
        built with gcc 11 (Ubuntu 11.2.0-19ubuntu1)
        configuration: --prefix=/usr --extra-version=0ubuntu0.22.04.1 --toolchain=hardened --libdir=/usr/lib/x86_64-linux-gnu --incdir=/usr/include/x86_64-linux-gnu --arch=amd64 --enable-gpl --disable-stripping --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libdav1d --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librabbitmq --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libsrt --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzimg --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opencl --enable-opengl --enable-sdl2 --enable-pocketsphinx --enable-librsvg --enable-libmfx --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --enable-shared
        libavutil      56. 70.100 / 56. 70.100
        libavcodec     58.134.100 / 58.134.100
        libavformat    58. 76.100 / 58. 76.100
        libavdevice    58. 13.100 / 58. 13.100
        libavfilter     7.110.100 /  7.110.100
        libswscale      5.  9.100 /  5.  9.100
        libswresample   3.  9.100 /  3.  9.100
        libpostproc    55.  9.100 / 55.  9.100
      Input #0, rtsp, from 'rtsp://192.168.168.100:8901/live': 0B f=0/0
        Metadata:
          title           : Session streamed with GStreamer
          comment         : rtsp-server
        Duration: N/A, start: 0.592211, bitrate: N/A
        Stream #0:0: Video: h264 (Main), yuv420p(progressive), 160x120, 9 fps, 8.75 tbr, 90k tbn, 18 tbc
      t@t:~$ d=   4 aq=    0KB vq=    0KB sq=    0B f=1/1
      this is running without any interruptions
      voxl2:/$ voxl-uvc-server  -d
      loading config file
      Enabling debug messages
      width:                            160
      height:                           120
      fps:                              9
      pipe_name:                        uvc
      voxl-uvc-server starting
      Image resolution 160x120, 9 fps chosen
      UVC initialized
      Device found
      Device opened
      uvc_get_stream_ctrl_format_size succeeded for format UYVY
      Streaming starting
      Got frame callback! frame_format = 4, width = 160, height = 120, length = 640, ptr = (nil)
       * got image 30
       * got image 60
       * got image 90
       * got image 120
       * got image 150
       * got image 180
       * got image 210
       * got image 240
       * got image 270
       * got image 300
       * got image 330
       * got image 360
       * got image 390
       * got image 420
       * got image 450
       * got image 480
       * got image 510
       * got image 540
       * got image 570
       * got image 600
       * got image 630
       * got image 660
       * got image 690
       * got image 720
       * got image 750
       * got image 780
       * got image 810
      • Jetson NanoJ Jetson Nano
        Found Pipe
        Found Pipe
        Removed 1 sessions
        Removed 1 sessions
          Metadata:
        loading config file
        width:                            160
        height:                           120
        fps:                              9
        pipe_name:                        uvc
        UVC initialized
        Device found
        Device opened
        Streaming starting
         * got image 30
         * got image 60
         * got image 90
         * got image 120
         * got image 150
         * got image 180
         * got image 210
         * got image 240
         * got image 270
         * got image 300
         * got image 330
         * got image 360
         * got image 390
         * got image 420
         * got image 450
         * got image 480
         * got image 510
         * got image 540
         * got image 570
         * got image 600
         * got image 630
         * got image 660
         * got image 690
         * got image 720
         * got image 750
         * got image 780
         * got image 810
        Jetson Nano
        Veteran
        @eric-katzfey
        I tried with c270 camera, the observation was similar was not able to stream in vlc, but was able to stream through ffplay.
          I'm confused by all of the new data. Can you summarize? You have tested with 2 different USB cameras: Lepton and c270. You have tested with 3 viewers: QGC, VLC, and ffplay. You have tested with 2 applications: voxl-uvc-server and voxl-streamer. Only one network connection: Microhard. Can you also try a MIPI camera instead of a USB camera? Then can you create a matrix saying which ones worked and which ones didn't?
            Jetson Nano
            Veteran
            sure I can summarize,
            Camera 1 - Lepton,
            QGC - Did not test
            VLC - Did not stream, error message.
            ffplay - stream worked
            Camera 2 - logitech c270 camera
            QGC - Did not test
            I did not understand what you meant by mipi camera, if it is normal hires camera connected to the yellow board, it is streaming fine, slightly slow through the microhard connection, but I can see the video stream on the portal.
            the following message showed up when i tried to trigged the rtsp stream through vlc
              MIPI is the physical connection to the VOXL2 board. So, yes, the "normal hires camera" is connected via mipi instead of USB. I'm trying to help you debug this. Normally, when something doesn't work, you try to narrow down the issue by trying some carefully thought out variations to see what works and what doesn't. That can determine the part that is not working. For example, if you have USB camera -> voxl-uvc-server -> voxl-streamer -> Microhard -> VLC and that is showing problems and then you switch to a stream with MIPI camera -> voxl-camera-server -> voxl-streamer -> Microhard -> VLC and that doesn't have problems then it's logical to focus on the USB camera -> voxl-uvc-server part of the pipeline as the problematic part. In your first post you mention QGC stream works and then in your last reply you said you did not test with QGC so that is confusing. And I'm not sure what your end goal is. In the first post you say "Please help to stream live video from the lepton camera through the microhard board." Then you say that it is working from ffplay. So, is that okay now? Or is ffplay not an acceptable solution for you?
                Jetson Nano
                Veteran
                @Eric-Katzfey ,
                Please excuse me for the confusion caused by me.
                Goal -
                my goal is to achieve continuous video stream from lepton camera connected through USB cable. the USB port I am using is Microhard.
                Issues I faced -
                1. During my initial testing, I was able to stream the lepton video through VLC, but the camera stream kept on getting interrupted (the camera stream ended), once I restart the uvc-service and the stream-service , it starts again. This observation was in loop.
                  I wanted your help to solve this issue.
                2. Once you asked for the log file, I tried to replicate this test, but the stream was not working through VLC.
                  I attached the log file.
                3. To verify the camera is working fine I tried with ffplay, the stream was working fine.
                4. I verified the MIPI camera, I was able to see the video on the voxl-portal, but while using the stream-service, it was not working on VLC.
                Now, I would like your help to solve the following problems
                1. Get the video stream on VLC
                2. Get the video stream to work continuously with out any interruption.
                3. Also it would be great if you clear one more query of mine, whether I can setup the USB port with any camera(which supports USB protocol), If I make necessary changes to the codes or UVC-service and Stream-service.
                  Thank you for your patience and looking forward to response.
                  That's kind of pointing to VLC as the issue. Can you try with QGC?
                    Jetson Nano
                    Veteran
                    Hi, Sorry for the late reply.
                    I tested the rtsp with QGC. The stream was working fine, until suddenly the stream got stuck and I had to restart the voxl-stream command.
                    • I have one major question, does usb camera support continuous live video stream.
                    • I am planning to purchase the voxl2 mini and use the usb port for lepton, I just want to be sure that the port can support continuous rtsp stream without having any issues.
                    • Is there any setup, I should be knowing for seamless streaming other than what is mentioned in the docs.
                    thank you for time, looking forward to your response.
                      Yes, we have tested a few USB (UVC) cameras and they can continuously live stream. So we need to figure out what is causing the problem on your setup.
                      • Zachary Lowell 0Z Offline
                        Zachary Lowell 0
                        @jetson-nano I am testing this right now and am not seeing an issue - can you describe the following:
                        1. How long is the voxl on when you see this issue/how long has the stream been going?
                        2. Have you confirmed that voxl uvc camera library did not die and that is the cause?
                        3. Have you confirmed via the voxl streamer logs that the service did not die?
                        I am trying to understand which library is the source of the error in the mpa.
                          Jetson Nano
                          Veteran
                          @eric-katzfey @Zachary-Lowell-0
                          Thank you guys for the response.
                          1. The voxl 2 was on max 8 minutes. The video streamed for 2 minutes, then the frame froze on QGC. I had to restart the voxl-stream command to restart the rtsp on QGC.
                          2. There was no error message on the debug window, the frames were passed constantly, during the RTSP freeze also.
                          3. The voxl-Stream only through error once I tried to connect to the VLC. While connecting to QGC,and while the video freeze there was no error message.
                            Zachary Lowell 0
                            https://www.loom.com/share/41699fad8b6842a6bf25c986c98c1c3b
                            Had it running on 8 minutes via voxl-uvc-server.
                            Can you confirm that you had good bandwidth the entire time? This is also over a microhard hat (although I have a wifi stick plugged into the usb port on here alongside the usb camera)
                            This sounds more like a networking issue than anything hardware or software related.
                              Jetson Nano
                              Veteran
                              @Zachary-Lowell-0
                              Thank you for testing it out and for fast response. I am also feeling it is a network issue.
                              I will also try to replicate the same test condition as yours, also will verify the bandwidth.
