  2. ESCs
  3. Third Party ESC integration w/ VOXL2
Scheduled Pinned Locked Moved ESCs
10 Posts 2 Posters 336 Views 1 Watching
  • P Online
    P Online
    PatkirkMartin
    wrote last edited by PatkirkMartin
    Hi all, some questions about the VOXL ESC
    Hardware
    • VOXL2 (MDK-M0154-1-01)
    • VOXL ESC FPV 4-in-1 (MDK-M0138-11-00)
    Software Version (voxl-version)
    voxl2-test-fixture (TF-M0054):/$ voxl-version
    kernel:       #1 SMP PREEMPT Wed Oct 22 04:13:18 UTC 2025 4.19.125
    hw platform:  M0054
    mach.var:     1.0.1
    SKU:          TF-M0054-4-V1-C11
    voxl-suite:   1.6.3
    Packages:
    Repo:  http://voxl-packages.modalai.com/ ./dists/qrb5165/sdk-1.6/binary-arm64/
    Last Updated: 2023-03-02 12:58:39
    List:
    libfc-sensor                   1.0.9
    libmodal-cv                    0.6.0
    libmodal-exposure              0.1.4
    libmodal-flow                  1.0.3
    libmodal-journal               0.2.7
    libmodal-json                  0.4.8
    libmodal-pipe                  2.14.11
    libqrb5165-io                  0.6.3
    libvoxl-cci-direct             0.3.3
    libvoxl-codec                  0.0.2
    libvoxl-cutils                 0.1.6
    modalai-slpi                   1.2.2
    mv-voxl                        0.1-r0
    qrb5165-bind                   0.1-r0
    qrb5165-dfs-server             0.2.0
    qrb5165-mini-tof-server        0.2.2
    qrb5165-rangefinder-server     0.1.6
    qrb5165-slpi-test-sig          01-r0
    qrb5165-tflite                 2.17.2
    voxl-bind-spektrum             0.1.1
    voxl-camera-calibration        0.6.1
    voxl-camera-server             2.2.19
    voxl-ceres-solver              2:2.0.0-2
    voxl-configurator              1.1.5
    voxl-cpu-monitor               0.7.7
    voxl-docker-support            1.3.1
    voxl-elrs                      1.1.0
    voxl-esc                       1.5.7
    voxl-esptool                   0.2.0
    voxl-feature-tracker           0.5.2
    voxl-flow-server               0.3.6
    voxl-gphoto2-server            0.0.10
    voxl-imu-server                2.0.1
    voxl-io-server                 0.0.8
    voxl-jpeg-turbo                2.1.3-7
    voxl-lepton-server             1.3.3
    voxl-lepton-tracker            0.0.4
    voxl-libgeographic             1.0.0
    voxl-libgphoto2                0.0.4
    voxl-libuvc                    1.0.7
    voxl-logger                    0.6.1
    voxl-mavcam-manager            0.6.0
    voxl-mavlink                   0.1.6
    voxl-mavlink-server            1.4.14
    voxl-modem                     1.2.3
    voxl-mongoose                  7.19.0
    voxl-mpa-to-ros                0.3.9
    voxl-mpa-tools                 1.5.6
    voxl-nano-tracker              0.1.7
    voxl-open-vins-server          0.6.0
    voxl-opencv                    4.5.5-3
    voxl-osd                       0.3.8
    voxl-portal                    0.8.7
    voxl-px4                       1.14.0-2.0.133
    voxl-px4-params                0.9.0
    voxl-qvio-server               1.2.3
    voxl-remote-id                 0.0.9
    voxl-reset-slpi                0.0.1
    voxl-state-estimator           0.0.6
    voxl-streamer                  0.8.0
    voxl-suite                     1.6.3
    voxl-tag-detector              0.1.0
    voxl-tflite-server             0.5.1
    voxl-utils                     2.0.2
    voxl-uvc-server                0.1.7
    voxl-vision-hub                1.9.21
    voxl-vtx                       2.0.2
    voxl-wavemux                   0.0.3
    voxl2-io                       0.0.3
    voxl2-security-hardening-utls  1.0-r0
    voxl2-system-image             1.8.06-r0
    voxl2-wlan                     1.0-r0
    Services/Config (voxl-inspect-services)
    voxl2-test-fixture (TF-M0054):/$ voxl-inspect-services
    Scanning services...
     Service Name             |  Enabled  |   Running   |  CPU Usage
     docker-autorun           | Disabled  | Not Running |
     modallink-relink         | Disabled  | Not Running |
     voxl-camera-server       |  Enabled  | Not Running |
     voxl-cpu-monitor         |  Enabled  |   Running   |     0.0%
     voxl-dfs-server          | Disabled  | Not Running |
     voxl-dma-latency         |  Enabled  |   Running   |
     voxl-feature-tracker     | Disabled  | Not Running |
     voxl-flow-server         | Disabled  | Not Running |
     voxl-imu-server          |  Enabled  |   Running   |     3.8%
     voxl-io-server           | Disabled  | Not Running |
     voxl-lepton-server       | Disabled  | Not Running |
     voxl-lepton-tracker      | Disabled  | Not Running |
     voxl-logger              | Disabled  | Not Running |
     voxl-mavcam-manager      | Disabled  | Not Running |
     voxl-mavlink-server      |  Enabled  |   Running   |     0.0%
     voxl-mini-tof-server     | Disabled  | Not Running |
     voxl-modem-doodle        | Disabled  | Not Running |
     voxl-modem               | Disabled  | Not Running |
     voxl-nano-tracker        | Disabled  | Not Running |
     voxl-open-vins-server    | Disabled  | Not Running |
     voxl-osd                 | Disabled  | Not Running |
     voxl-portal              |  Enabled  |   Running   |     0.0%
     voxl-px4                 | Disabled  | Not Running |
     voxl-qvio-server         | Disabled  | Not Running |
     voxl-rangefinder-server  | Disabled  | Not Running |
     voxl-remote-id           | Disabled  | Not Running |
     voxl-softap              | Disabled  | Not Running |
     voxl-state-estimator     | Disabled  | Not Running |
     voxl-static-ip-watcher   | Disabled  | Not Running |
     voxl-static-ip           | Disabled  | Not Running |
     voxl-streamer            | Disabled  | Not Running |
     voxl-tag-detector        | Disabled  | Not Running |
     voxl-tflite-server       | Disabled  | Not Running |
     voxl-time-sync           | Disabled  | Not Running |
     voxl-uvc-server          | Disabled  | Not Running |
     voxl-vision-hub          |  Enabled  |   Running   |     1.9%
     voxl-vrx                 | Disabled  | Not Running |
     voxl-vtx                 | Disabled  | Not Running |
     voxl-wait-for-fs         |  Enabled  |  Completed  |
    Integration with Third Party ESC
    This is a follow up to a previous post (link) regarding supported ESC hardware with the VOXL2. As directed by @vinny in that previous post, I am breaking out this follow up as its own topic.
    I am looking to integrate this 12S ESC from Mad Motor (link) for my project. For now, I am open to using the VOXL IO expander (link) to do this integration via PWM/ONESHOT with BLHELI32 firmware but I am finding the lack of DSHOT support in the VOXL ecosystem a real road block for future project development with this product.
    What I am particularly interested in is guidance on what it would take to get a DSHOT implementation working in the VOXL ecosystem. Is there a technical reason why this has not yet been implemented? If there are no plans for the Modal team to implement this, is this something I could attempt via the VOXL2 SDK?
    Any guidance is much appreciated.
    • Alex KushleyevA Offline
      Hello @patkirkmartin ,
      DShot could be used with VOXL2 when using Flight Core V2 as an external flight controller (stm32-based). However, Flight Core V2 is EOL.
      The IO expander board (M0065) does have capable hardware to generate DSHOT signals, however, integrating and testing DShot-based ESCs is not in the scope of our team's effort.
      Have you considered using a 3rd party flight controller as well as the ESC and using VOXL2 as a companion computer?
      • P Online
        P Online
        PatkirkMartin
        @alex-kushleyev
        A large part of my team's selection of your hardware was the small footprint we get by combining flight controller + companion computer on the same piece of silicon. If we move to a third party flight controller, we honestly may as well just move away from this ecosystem.
        I am not afraid of getting into some more technical details with your development team on what it might look like for us to work on a DSHOT integration.
        PS: As an aside, my team has a large order put in with your sales team that we have not heard back about in some time. Would you please pass along that we need a response on that? I have sent a follow up via your sales inquiry forum on the website with more information
        • P PatkirkMartin
          @alex-kushleyev
          @PatkirkMartin,
          I will pass on your note about the order to our team.
          Regarding DSHOT, can you please clarify which features are a must-have for your application? specifically, do you need both DSHOT control (lets say Dshot600) and DSHOT telemetry? Or UART Telemetry.. or no telemetry..
          P 1 Reply Last reply
            @PatkirkMartin,
            P Online
            P Online
            PatkirkMartin
            Thanks for passing my note along. Greatly appreciated.
            The biggest thing we need out of DSHOT is the telemetry. At this point, or for a first pass, any way we can get telemetry from a third party ESC if fine. Even if we are still using PWM or OneShot.
              Sorry for being very specific.. but there are two types of telemetry you can get from DSHOT-capable ESCs.
              • UART telemetry : the four ESCs send telemetry one at a time over a dedicated UART line, which can be fed into standard UART RX
              • DSHOT telemetry is sent from each ESC over the PWM lines (all at the same time) and do not use UART. The FC hardware as to change the PWM outputs to inputs while receiving telemetry (requires tight timing)
              So, do you have a requirement to use one or another.. or which specific fields in the telemetry are you looking for?
              • P Online
                P Online
                PatkirkMartin
                DSHOT Telemetry seems like the only option for the MadMotor ESC linked in the original post so that would be our requirement.
                  Hello @patkirkmartin , thanks for clarifying.
                  Just to give you some more background and the reason for my questions: we have previously experimented with enabling DSHOT output using VOXL2 IO board and it worked during testing. However, due to lack of need and time to properly test and release, the feature was never mainlined. Also, we tested receiving the telemetry via UART only (which some DSHOT ESCs support) - had to hijack a UART port on the voxl2 io board for that.
                  Further developing the (bi-directional) DSHOT on the voxl2 io board is currently not on our roadmap, however if you we willing to do your own code development for the voxl2 io board, we can look into releasing the source code for it (together with the initial DSHOT output implementation).
                  VOXL2 itself is not capable of outputting the required DSHOT signals.
                    P Online
                    P Online
                    PatkirkMartin
                    #9
                    I really appreciate you taking the time to answer this question! Thank you so much. Very helpful.
                    My team and I are definitely interested in making this work, so if you are willing to release the source to us that would be great. I will most likely need to continue reaching out for technical guidance as we work to get this implemented. What might be the best way to continue technical discourse on this subject? A new thread? Direct message?
                      #10
                      @patkirkmartin , let me double check with the team what the process for this will be and the timeline. I will get back to you soon.
                      Since the plan would be to provide the source to the public, it would be posted on gitlab, the feature-related discussion can happen there. We will certainly be able to help review the code and perform some testing.
