  2. ESCs
  3. Third Party ESC integration w/ VOXL2
Scheduled Pinned Locked Moved ESCs
5 Posts 2 Posters 162 Views 1 Watching
  • P Online
    P Online
    PatkirkMartin
    wrote last edited by PatkirkMartin
    Hi all, some questions about the VOXL ESC
    Hardware
    • VOXL2 (MDK-M0154-1-01)
    • VOXL ESC FPV 4-in-1 (MDK-M0138-11-00)
    Software Version (voxl-version)
    voxl2-test-fixture (TF-M0054):/$ voxl-version
    kernel:       #1 SMP PREEMPT Wed Oct 22 04:13:18 UTC 2025 4.19.125
    hw platform:  M0054
    mach.var:     1.0.1
    SKU:          TF-M0054-4-V1-C11
    voxl-suite:   1.6.3
    Packages:
    Repo:  http://voxl-packages.modalai.com/ ./dists/qrb5165/sdk-1.6/binary-arm64/
    Last Updated: 2023-03-02 12:58:39
    List:
    libfc-sensor                   1.0.9
    libmodal-cv                    0.6.0
    libmodal-exposure              0.1.4
    libmodal-flow                  1.0.3
    libmodal-journal               0.2.7
    libmodal-json                  0.4.8
    libmodal-pipe                  2.14.11
    libqrb5165-io                  0.6.3
    libvoxl-cci-direct             0.3.3
    libvoxl-codec                  0.0.2
    libvoxl-cutils                 0.1.6
    modalai-slpi                   1.2.2
    mv-voxl                        0.1-r0
    qrb5165-bind                   0.1-r0
    qrb5165-dfs-server             0.2.0
    qrb5165-mini-tof-server        0.2.2
    qrb5165-rangefinder-server     0.1.6
    qrb5165-slpi-test-sig          01-r0
    qrb5165-tflite                 2.17.2
    voxl-bind-spektrum             0.1.1
    voxl-camera-calibration        0.6.1
    voxl-camera-server             2.2.19
    voxl-ceres-solver              2:2.0.0-2
    voxl-configurator              1.1.5
    voxl-cpu-monitor               0.7.7
    voxl-docker-support            1.3.1
    voxl-elrs                      1.1.0
    voxl-esc                       1.5.7
    voxl-esptool                   0.2.0
    voxl-feature-tracker           0.5.2
    voxl-flow-server               0.3.6
    voxl-gphoto2-server            0.0.10
    voxl-imu-server                2.0.1
    voxl-io-server                 0.0.8
    voxl-jpeg-turbo                2.1.3-7
    voxl-lepton-server             1.3.3
    voxl-lepton-tracker            0.0.4
    voxl-libgeographic             1.0.0
    voxl-libgphoto2                0.0.4
    voxl-libuvc                    1.0.7
    voxl-logger                    0.6.1
    voxl-mavcam-manager            0.6.0
    voxl-mavlink                   0.1.6
    voxl-mavlink-server            1.4.14
    voxl-modem                     1.2.3
    voxl-mongoose                  7.19.0
    voxl-mpa-to-ros                0.3.9
    voxl-mpa-tools                 1.5.6
    voxl-nano-tracker              0.1.7
    voxl-open-vins-server          0.6.0
    voxl-opencv                    4.5.5-3
    voxl-osd                       0.3.8
    voxl-portal                    0.8.7
    voxl-px4                       1.14.0-2.0.133
    voxl-px4-params                0.9.0
    voxl-qvio-server               1.2.3
    voxl-remote-id                 0.0.9
    voxl-reset-slpi                0.0.1
    voxl-state-estimator           0.0.6
    voxl-streamer                  0.8.0
    voxl-suite                     1.6.3
    voxl-tag-detector              0.1.0
    voxl-tflite-server             0.5.1
    voxl-utils                     2.0.2
    voxl-uvc-server                0.1.7
    voxl-vision-hub                1.9.21
    voxl-vtx                       2.0.2
    voxl-wavemux                   0.0.3
    voxl2-io                       0.0.3
    voxl2-security-hardening-utls  1.0-r0
    voxl2-system-image             1.8.06-r0
    voxl2-wlan                     1.0-r0
    Services/Config (voxl-inspect-services)
    voxl2-test-fixture (TF-M0054):/$ voxl-inspect-services
    Scanning services...
     Service Name             |  Enabled  |   Running   |  CPU Usage
     docker-autorun           | Disabled  | Not Running |
     modallink-relink         | Disabled  | Not Running |
     voxl-camera-server       |  Enabled  | Not Running |
     voxl-cpu-monitor         |  Enabled  |   Running   |     0.0%
     voxl-dfs-server          | Disabled  | Not Running |
     voxl-dma-latency         |  Enabled  |   Running   |
     voxl-feature-tracker     | Disabled  | Not Running |
     voxl-flow-server         | Disabled  | Not Running |
     voxl-imu-server          |  Enabled  |   Running   |     3.8%
     voxl-io-server           | Disabled  | Not Running |
     voxl-lepton-server       | Disabled  | Not Running |
     voxl-lepton-tracker      | Disabled  | Not Running |
     voxl-logger              | Disabled  | Not Running |
     voxl-mavcam-manager      | Disabled  | Not Running |
     voxl-mavlink-server      |  Enabled  |   Running   |     0.0%
     voxl-mini-tof-server     | Disabled  | Not Running |
     voxl-modem-doodle        | Disabled  | Not Running |
     voxl-modem               | Disabled  | Not Running |
     voxl-nano-tracker        | Disabled  | Not Running |
     voxl-open-vins-server    | Disabled  | Not Running |
     voxl-osd                 | Disabled  | Not Running |
     voxl-portal              |  Enabled  |   Running   |     0.0%
     voxl-px4                 | Disabled  | Not Running |
     voxl-qvio-server         | Disabled  | Not Running |
     voxl-rangefinder-server  | Disabled  | Not Running |
     voxl-remote-id           | Disabled  | Not Running |
     voxl-softap              | Disabled  | Not Running |
     voxl-state-estimator     | Disabled  | Not Running |
     voxl-static-ip-watcher   | Disabled  | Not Running |
     voxl-static-ip           | Disabled  | Not Running |
     voxl-streamer            | Disabled  | Not Running |
     voxl-tag-detector        | Disabled  | Not Running |
     voxl-tflite-server       | Disabled  | Not Running |
     voxl-time-sync           | Disabled  | Not Running |
     voxl-uvc-server          | Disabled  | Not Running |
     voxl-vision-hub          |  Enabled  |   Running   |     1.9%
     voxl-vrx                 | Disabled  | Not Running |
     voxl-vtx                 | Disabled  | Not Running |
     voxl-wait-for-fs         |  Enabled  |  Completed  |
    Integration with Third Party ESC
    This is a follow up to a previous post (link) regarding supported ESC hardware with the VOXL2. As directed by @vinny in that previous post, I am breaking out this follow up as its own topic.
    I am looking to integrate this 12S ESC from Mad Motor (link) for my project. For now, I am open to using the VOXL IO expander (link) to do this integration via PWM/ONESHOT with BLHELI32 firmware but I am finding the lack of DSHOT support in the VOXL ecosystem a real road block for future project development with this product.
    What I am particularly interested in is guidance on what it would take to get a DSHOT implementation working in the VOXL ecosystem. Is there a technical reason why this has not yet been implemented? If there are no plans for the Modal team to implement this, is this something I could attempt via the VOXL2 SDK?
    Any guidance is much appreciated.
    • Alex KushleyevA Offline
      Hello @patkirkmartin ,
      DShot could be used with VOXL2 when using Flight Core V2 as an external flight controller (stm32-based). However, Flight Core V2 is EOL.
      The IO expander board (M0065) does have capable hardware to generate DSHOT signals, however, integrating and testing DShot-based ESCs is not in the scope of our team's effort.
      Have you considered using a 3rd party flight controller as well as the ESC and using VOXL2 as a companion computer?
      • P Online
        P Online
        PatkirkMartin
        @alex-kushleyev
        A large part of my team's selection of your hardware was the small footprint we get by combining flight controller + companion computer on the same piece of silicon. If we move to a third party flight controller, we honestly may as well just move away from this ecosystem.
        I am not afraid of getting into some more technical details with your development team on what it might look like for us to work on a DSHOT integration.
        PS: As an aside, my team has a large order put in with your sales team that we have not heard back about in some time. Would you please pass along that we need a response on that? I have sent a follow up via your sales inquiry forum on the website with more information
        • P PatkirkMartin
          @alex-kushleyev
          @PatkirkMartin,
          I will pass on your note about the order to our team.
          Regarding DSHOT, can you please clarify which features are a must-have for your application? specifically, do you need both DSHOT control (lets say Dshot600) and DSHOT telemetry? Or UART Telemetry.. or no telemetry..
          P 1 Reply Last reply
            @PatkirkMartin,
            P Online
            P Online
            PatkirkMartin
            Thanks for passing my note along. Greatly appreciated.
            The biggest thing we need out of DSHOT is the telemetry. At this point, or for a first pass, any way we can get telemetry from a third party ESC if fine. Even if we are still using PWM or OneShot.
