  3. Request Support: VOXL2 Not Powering up.
13 Posts 2 Posters 4.5k Views 2 Watching
  • VinnyV Offline
    Hi @mikhail-mayers Wow, ok, that is very odd...
    Do you have a DMM to measure voltages out of the power module?
    You should see 5V +/-0.1V. If not, work your way back to the 12V wall adapter.
    I'm thinking most likely the wall adapter is the culprit here as that is a COTS item, whereas the Power Module and the VOXL 2 have been tested by our staff and procedures.
    • Mikhail MayersM Offline
      Mikhail Mayers
      Hey @vinny
      The power module did not did not have a voltage on the 4 pin. I followed the diagram here:
      https://docs.modalai.com/voxl2-power/
      The 12V did have power. The issue could be with the power module? I see no signs of damage on the power module.
      Next steps?
      • VinnyV Offline
        Thanks @mikhail-mayers. We'll get you a replacement Power Module. That is pretty clear cut to me. I'll have someone from our Operations team reach out to you to ship a replacement Power Module. Do you happen to know your order #? Thanks!
          Mikhail Mayers
          Thanks @vinny
          Order #8058
          • VinnyV Offline
            Thanks @mikhail-mayers I sent a request up. I asked for a return label for your power module when you receive the replacement so I can debug this. Very odd to me since these all go through load and burn-in testing.
            Apologies for the disruption to your testing, so I hope we can resolve this quickly for you!
              Mikhail Mayers
              No worries, it happens.
              Thank you for the quick turn around. It was working just fine up until it stopped working. I just hope the VOXL2 is ok.
              • VinnyV Offline
                @mikhail-mayers I was asked to have you fill this form out;
                https://www.modalai.com/pages/rma?_pos=1&_sid=54677f88c&_ss=r
                Please reference this link so we know to credit you anything for the parts/service. This should be free given your order is in April.
                Note our address has changed, so we'll be sure to include the correct new address for you in the forms.
                • VinnyV Offline
                  Reference this forum link in the RMA.
                    Mikhail Mayers
                    VOXL2 does not seem to have damage. Looks like it turned on like normal with the replacement part.
                    • VinnyV Offline
                      wrote on last edited by Vinny
                      #13
                      Great to hear @mikhail-mayers . I tested the module you sent back and it baffles me... must be some internal silicon damage to the IC since it had all in-spec inputs, and no faults on any outputs, but it was just not turning on... so, it is now one of my Mechanical Samples 🙂
                      Glad we could get that resolved for you and thanks for your patience.
