  2. ESCs
  3. ESC Support Questions
Scheduled Pinned Locked Moved ESCs
4 Posts 3 Posters 1.8k Views 2 Watching
  • P Offline
    P Offline
    PatkirkMartin
    Hi all, some questions about the VOXL ESC
    Hardware
    • VOXL2 (MDK-M0154-1-01)
    • VOXL ESC FPV 4-in-1 (MDK-M0138-11-00)
    Software Version (voxl-version)
    voxl2-test-fixture (TF-M0054):/$ voxl-version
    kernel:       #1 SMP PREEMPT Wed Oct 22 04:13:18 UTC 2025 4.19.125
    hw platform:  M0054
    mach.var:     1.0.1
    SKU:          TF-M0054-4-V1-C11
    voxl-suite:   1.6.3
    Packages:
    Repo:  http://voxl-packages.modalai.com/ ./dists/qrb5165/sdk-1.6/binary-arm64/
    Last Updated: 2023-03-02 12:58:39
    List:
    libfc-sensor                   1.0.9
    libmodal-cv                    0.6.0
    libmodal-exposure              0.1.4
    libmodal-flow                  1.0.3
    libmodal-journal               0.2.7
    libmodal-json                  0.4.8
    libmodal-pipe                  2.14.11
    libqrb5165-io                  0.6.3
    libvoxl-cci-direct             0.3.3
    libvoxl-codec                  0.0.2
    libvoxl-cutils                 0.1.6
    modalai-slpi                   1.2.2
    mv-voxl                        0.1-r0
    qrb5165-bind                   0.1-r0
    qrb5165-dfs-server             0.2.0
    qrb5165-mini-tof-server        0.2.2
    qrb5165-rangefinder-server     0.1.6
    qrb5165-slpi-test-sig          01-r0
    qrb5165-tflite                 2.17.2
    voxl-bind-spektrum             0.1.1
    voxl-camera-calibration        0.6.1
    voxl-camera-server             2.2.19
    voxl-ceres-solver              2:2.0.0-2
    voxl-configurator              1.1.5
    voxl-cpu-monitor               0.7.7
    voxl-docker-support            1.3.1
    voxl-elrs                      1.1.0
    voxl-esc                       1.5.7
    voxl-esptool                   0.2.0
    voxl-feature-tracker           0.5.2
    voxl-flow-server               0.3.6
    voxl-gphoto2-server            0.0.10
    voxl-imu-server                2.0.1
    voxl-io-server                 0.0.8
    voxl-jpeg-turbo                2.1.3-7
    voxl-lepton-server             1.3.3
    voxl-lepton-tracker            0.0.4
    voxl-libgeographic             1.0.0
    voxl-libgphoto2                0.0.4
    voxl-libuvc                    1.0.7
    voxl-logger                    0.6.1
    voxl-mavcam-manager            0.6.0
    voxl-mavlink                   0.1.6
    voxl-mavlink-server            1.4.14
    voxl-modem                     1.2.3
    voxl-mongoose                  7.19.0
    voxl-mpa-to-ros                0.3.9
    voxl-mpa-tools                 1.5.6
    voxl-nano-tracker              0.1.7
    voxl-open-vins-server          0.6.0
    voxl-opencv                    4.5.5-3
    voxl-osd                       0.3.8
    voxl-portal                    0.8.7
    voxl-px4                       1.14.0-2.0.133
    voxl-px4-params                0.9.0
    voxl-qvio-server               1.2.3
    voxl-remote-id                 0.0.9
    voxl-reset-slpi                0.0.1
    voxl-state-estimator           0.0.6
    voxl-streamer                  0.8.0
    voxl-suite                     1.6.3
    voxl-tag-detector              0.1.0
    voxl-tflite-server             0.5.1
    voxl-utils                     2.0.2
    voxl-uvc-server                0.1.7
    voxl-vision-hub                1.9.21
    voxl-vtx                       2.0.2
    voxl-wavemux                   0.0.3
    voxl2-io                       0.0.3
    voxl2-security-hardening-utls  1.0-r0
    voxl2-system-image             1.8.06-r0
    voxl2-wlan                     1.0-r0
    Services/Config (voxl-inspect-services)
    voxl2-test-fixture (TF-M0054):/$ voxl-inspect-services
    Scanning services...
     Service Name             |  Enabled  |   Running   |  CPU Usage
     docker-autorun           | Disabled  | Not Running |
     modallink-relink         | Disabled  | Not Running |
     voxl-camera-server       |  Enabled  | Not Running |
     voxl-cpu-monitor         |  Enabled  |   Running   |     0.0%
     voxl-dfs-server          | Disabled  | Not Running |
     voxl-dma-latency         |  Enabled  |   Running   |
     voxl-feature-tracker     | Disabled  | Not Running |
     voxl-flow-server         | Disabled  | Not Running |
     voxl-imu-server          |  Enabled  |   Running   |     3.8%
     voxl-io-server           | Disabled  | Not Running |
     voxl-lepton-server       | Disabled  | Not Running |
     voxl-lepton-tracker      | Disabled  | Not Running |
     voxl-logger              | Disabled  | Not Running |
     voxl-mavcam-manager      | Disabled  | Not Running |
     voxl-mavlink-server      |  Enabled  |   Running   |     0.0%
     voxl-mini-tof-server     | Disabled  | Not Running |
     voxl-modem-doodle        | Disabled  | Not Running |
     voxl-modem               | Disabled  | Not Running |
     voxl-nano-tracker        | Disabled  | Not Running |
     voxl-open-vins-server    | Disabled  | Not Running |
     voxl-osd                 | Disabled  | Not Running |
     voxl-portal              |  Enabled  |   Running   |     0.0%
     voxl-px4                 | Disabled  | Not Running |
     voxl-qvio-server         | Disabled  | Not Running |
     voxl-rangefinder-server  | Disabled  | Not Running |
     voxl-remote-id           | Disabled  | Not Running |
     voxl-softap              | Disabled  | Not Running |
     voxl-state-estimator     | Disabled  | Not Running |
     voxl-static-ip-watcher   | Disabled  | Not Running |
     voxl-static-ip           | Disabled  | Not Running |
     voxl-streamer            | Disabled  | Not Running |
     voxl-tag-detector        | Disabled  | Not Running |
     voxl-tflite-server       | Disabled  | Not Running |
     voxl-time-sync           | Disabled  | Not Running |
     voxl-uvc-server          | Disabled  | Not Running |
     voxl-vision-hub          |  Enabled  |   Running   |     1.9%
     voxl-vrx                 | Disabled  | Not Running |
     voxl-vtx                 | Disabled  | Not Running |
     voxl-wait-for-fs         |  Enabled  |  Completed  |
    Questions
    1. I am looking for an ESC to use with the VOXL2 that supports >6S batteries. Mainly looking at 8-10S range. Does VOXL have any hardware products that support such voltages?
    2. If I move away to a third party ESC that supports my desired voltage ratings, what interface hardware do I need to get this ESC connected? Right now, I am under the impression that I would need your VOXL2 IO expander (link) attached to the ESC UART and your Flight Core PWM output board (link) to run PWM out to my ESC?
    3. Do you have any support for DShot 300/600 anywhere in the VOXL ecosystem? Is this something that could be added in the firmware on the IO expander?
    • VinnyV Offline
      Hi @patkirkmartin
      1. We do not support >6S ESCs or Power Modules at this time.
      2. Your suspicions are correct. For 3rd Party ESCs, you are unlikely able to use our voxl-esc tools which use UART based communications. The IO Expander is one way to get you there.
      3. For Dshot, we have some guidance here: https://docs.modalai.com/fc-configure-misc/ since it is baked into standard PX4 support as far as I can tell.
        We completely revamped our Tech Docs with improved search functionality, so try to search for Dshot and see if any of those other posts help you along.
        Otherwise, what I would do once you decide on a specific ESC, create a new post just based on that for Dshot support and one of our SW engineers will be able to respond.
        Hope this helped.
      • P Offline
        P Offline
        PatkirkMartin
        @vinny
        Awesome! Thanks. I will follow your guidance and make a new post with the ESC I'd like to use (once I make that selection).
        Helpful, as always. Much appreciated!
        • Alex KushleyevA Offline
          We do not support DSHOT when using Voxl2 + IO Expander board. However, OneShot125 is supported (though you would need to re-build voxl-px4 pakage and change the following scale factor : https://github.com/modalai/px4-firmware/blob/voxl-dev/src/drivers/voxl2_io/voxl2_io.hpp#L133) -- set MIXER_OUTPUT_TO_CMD_SCALE = 125 instead of 1000. This would reduce the actuator latency by 1-2ms (as long as the ESC supports OneShot125).
          • P PatkirkMartin referenced this topic on
