<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[ESC Support Questions]]></title><description><![CDATA[<p dir="auto">Hi all, some questions about the VOXL ESC</p>
<p dir="auto"><strong>Hardware</strong></p>
<ul>
<li>VOXL2 (MDK-M0154-1-01)</li>
<li>VOXL ESC FPV 4-in-1 (MDK-M0138-11-00)</li>
</ul>
<p dir="auto"><strong>Software Version</strong> (voxl-version)</p>
<pre><code>voxl2-test-fixture (TF-M0054):/$ voxl-version
system-image: 1.8.06-M0054-14.1a-perf
kernel:       #1 SMP PREEMPT Wed Oct 22 04:13:18 UTC 2025 4.19.125
hw platform:  M0054
mach.var:     1.0.1
SKU:          TF-M0054-4-V1-C11
voxl-suite:   1.6.3
Packages:
Repo:  http://voxl-packages.modalai.com/ ./dists/qrb5165/sdk-1.6/binary-arm64/
Last Updated: 2023-03-02 12:58:39
List:
libfc-sensor                   1.0.9
libmodal-cv                    0.6.0
libmodal-exposure              0.1.4
libmodal-flow                  1.0.3
libmodal-journal               0.2.7
libmodal-json                  0.4.8
libmodal-pipe                  2.14.11
libqrb5165-io                  0.6.3
libvoxl-cci-direct             0.3.3
libvoxl-codec                  0.0.2
libvoxl-cutils                 0.1.6
modalai-slpi                   1.2.2
mv-voxl                        0.1-r0
qrb5165-bind                   0.1-r0
qrb5165-dfs-server             0.2.0
qrb5165-mini-tof-server        0.2.2
qrb5165-rangefinder-server     0.1.6
qrb5165-slpi-test-sig          01-r0
qrb5165-tflite                 2.17.2
voxl-bind-spektrum             0.1.1
voxl-camera-calibration        0.6.1
voxl-camera-server             2.2.19
voxl-ceres-solver              2:2.0.0-2
voxl-configurator              1.1.5
voxl-cpu-monitor               0.7.7
voxl-docker-support            1.3.1
voxl-elrs                      1.1.0
voxl-esc                       1.5.7
voxl-esptool                   0.2.0
voxl-feature-tracker           0.5.2
voxl-flow-server               0.3.6
voxl-gphoto2-server            0.0.10
voxl-imu-server                2.0.1
voxl-io-server                 0.0.8
voxl-jpeg-turbo                2.1.3-7
voxl-lepton-server             1.3.3
voxl-lepton-tracker            0.0.4
voxl-libgeographic             1.0.0
voxl-libgphoto2                0.0.4
voxl-libuvc                    1.0.7
voxl-logger                    0.6.1
voxl-mavcam-manager            0.6.0
voxl-mavlink                   0.1.6
voxl-mavlink-server            1.4.14
voxl-modem                     1.2.3
voxl-mongoose                  7.19.0
voxl-mpa-to-ros                0.3.9
voxl-mpa-tools                 1.5.6
voxl-nano-tracker              0.1.7
voxl-open-vins-server          0.6.0
voxl-opencv                    4.5.5-3
voxl-osd                       0.3.8
voxl-portal                    0.8.7
voxl-px4                       1.14.0-2.0.133
voxl-px4-params                0.9.0
voxl-qvio-server               1.2.3
voxl-remote-id                 0.0.9
voxl-reset-slpi                0.0.1
voxl-state-estimator           0.0.6
voxl-streamer                  0.8.0
voxl-suite                     1.6.3
voxl-tag-detector              0.1.0
voxl-tflite-server             0.5.1
voxl-utils                     2.0.2
voxl-uvc-server                0.1.7
voxl-vision-hub                1.9.21
voxl-vtx                       2.0.2
voxl-wavemux                   0.0.3
voxl2-io                       0.0.3
voxl2-security-hardening-utls  1.0-r0
voxl2-system-image             1.8.06-r0
voxl2-wlan                     1.0-r0
<p dir="auto"><strong>Services/Config</strong> (voxl-inspect-services)</p>
<pre><code>voxl2-test-fixture (TF-M0054):/$ voxl-inspect-services
Scanning services...
 voxl-camera-server       |  Enabled  | Not Running |
 voxl-cpu-monitor         |  Enabled  |   Running   |     0.0%
 voxl-dma-latency         |  Enabled  |   Running   |
 voxl-imu-server          |  Enabled  |   Running   |     3.8%
 voxl-io-server           | Disabled  | Not Running |
 voxl-lepton-tracker      | Disabled  | Not Running |
 voxl-logger              | Disabled  | Not Running |
 voxl-mavcam-manager      | Disabled  | Not Running |
 voxl-mavlink-server      |  Enabled  |   Running   |     0.0%
 voxl-mini-tof-server     | Disabled  | Not Running |
 voxl-modem-doodle        | Disabled  | Not Running |
 voxl-nano-tracker        | Disabled  | Not Running |
 voxl-open-vins-server    | Disabled  | Not Running |
 voxl-osd                 | Disabled  | Not Running |
 voxl-portal              |  Enabled  |   Running   |     0.0%
 voxl-px4                 | Disabled  | Not Running |
 voxl-qvio-server         | Disabled  | Not Running |
 voxl-state-estimator     | Disabled  | Not Running |
 voxl-static-ip-watcher   | Disabled  | Not Running |
 voxl-streamer            | Disabled  | Not Running |
 voxl-vision-hub          |  Enabled  |   Running   |     1.9%
 voxl-vrx                 | Disabled  | Not Running |
 voxl-vtx                 | Disabled  | Not Running |
<p dir="auto"><strong>Questions</strong></p>
<ol>
<li>I am looking for an ESC to use with the VOXL2 that supports &gt;6S batteries. Mainly looking at 8-10S range. Does VOXL have any hardware products that support such voltages?</li>
<li>If I move away to a third party ESC that supports my desired voltage ratings, what interface hardware do I need to get this ESC connected? Right now, I am under the impression that I would need your VOXL2 IO expander (<a href="https://www.modalai.com/collections/expansion-board/products/voxl2-io?variant=40610514206771" rel="nofollow ugc">link</a>) attached to the ESC UART and your Flight Core PWM output board (<a href="https://www.modalai.com/collections/accessories/products/flight-core-pwm-output-cable-and-break-out-board" rel="nofollow ugc">link</a>) to run PWM out to my ESC?</li>
<li>Do you have any support for DShot 300/600 anywhere in the VOXL ecosystem? Is this something that could be added in the firmware on the IO expander?</li>
</ol>
]]></description><link>https://forum.modalai.com/topic/5311/esc-support-questions</link><generator>RSS for Node</generator><lastBuildDate>Wed, 08 Jul 2026 07:10:02 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/5311.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 07 Jul 2026 14:10:43 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to ESC Support Questions on Tue, 07 Jul 2026 20:24:28 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/patkirkmartin" aria-label="Profile: patkirkmartin">@<bdi>patkirkmartin</bdi></a></p>
<ol>
<li>We do not support &gt;6S ESCs or Power Modules at this time.</li>
<li>Your suspicions are correct. For 3rd Party ESCs, you are unlikely able to use our voxl-esc tools which use UART based communications. The IO Expander is one way to get you there.</li>
<li>For Dshot, we have some guidance here: <a href="https://docs.modalai.com/fc-configure-misc/" rel="nofollow ugc">https://docs.modalai.com/fc-configure-misc/</a> since it is baked into standard PX4 support as far as I can tell.<br />
We completely revamped our Tech Docs with improved search functionality, so try to search for Dshot and see if any of those other posts help you along.<br />
Otherwise, what I would do once you decide on a specific ESC, create a new post just based on that for Dshot support and one of our SW engineers will be able to respond.<br />
Hope this helped.</li>
</ol>
]]></description><link>https://forum.modalai.com/post/26326</link><guid isPermaLink="true">https://forum.modalai.com/post/26326</guid><dc:creator><![CDATA[Vinny]]></dc:creator><pubDate>Tue, 07 Jul 2026 20:24:28 GMT</pubDate></item></channel></rss>
