  2. VOXL SDK and Software
  3. voxl-suite upgrade
voxl-suite upgrade
voxl-sdk
6 Posts 3 Posters 3.5k Views 3 Watching
  • R Offline
    R Offline
    RoyAzriel
    We have 4 strling2-max drone all with 1.6.4~alpha2 from factory.
    One of the drones beacame a brick and I was doing the unbricking procedure.
    The only release available in developer site is 1.6.3 so now not all my drones have the same version.
    my goal is to make 1.6.3 - > 1.6.4~alpha2 and align all drones
    1.6.4~alpha2 is not available in developer site.
    what can I do ? it tried apt update && apt upgrade on drone with connction to internet it failed.
    MRB-D0012-4-V3-C28-T8-M36-X0
    MRB-D0012-4-V2-C28-T8-M36-X0
    see sku is v3 in 1.6.4~alpha2 and V2 in 1.6.3
    another important question. we intend to assemble the depth camera and change configuration to C29. We noticed the front cameras are moving to a new location with offset regarding the symetric axes. do we need to somehow update vio intrinsix files ? if yes how should it be done ?
    Roy
    out of the box version:
    kernel: #1 SMP PREEMPT Wed Oct 22 04:29:38 UTC 2025 4.19.125
    hw platform: M0054
    mach.var: 1.2.1
    SKU: MRB-D0012-4-V3-C28-T8-M36-X0
    voxl-suite: 1.6.4~alpha2
    after unbric version:
    hw platform: M0054
    mach.var: 1.2.1
    SKU: MRB-D0012-4-V2-C28-T8-M36-X0
    voxl-suite: 1.6.3
    no current network connection
    tomT 2 Replies Last reply
    • Alex KushleyevA Offline
      @RoyAzriel , we will check about the SDK.. I see how that's an issue for you.
      Regarding extrinsics when upgrading your Starling 2 Max from C28 to C29, the different extrinsics already exist (and the source can be found here : https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-mpa-tools/-/tree/master/misc_files/usr/share/modalai/extrinsic_configs) . Once you run voxl-configure-mpa, then the correct extrinsics should be loaded, or you can replace the file manually (it goes to /etc/modalai/ on voxl2)
      • R RoyAzriel
        Roy
        hw platform: M0054
        mach.var: 1.2.1
        hw platform: M0054
        mach.var: 1.2.1
        voxl-suite: 1.6.3
        • R RoyAzriel
          Roy
          hw platform: M0054
          mach.var: 1.2.1
          hw platform: M0054
          mach.var: 1.2.1
          voxl-suite: 1.6.3
          wrote on last edited by tom
          @RoyAzriel I'll send you an email with a link to the latest SDK. It is largely untested on starling2-max which is why it isn't available on our public downloads page yet.
          R 1 Reply Last reply
            R Offline
            R Offline
            RoyAzriel
            @tom hi tom,
            Can you recomend a tested and stable version.
            The 4 drones were shiped with this version.
            any recomendation to what stable version we should move ?
            BR,
            Roy
            • R RoyAzriel
              @tom hi tom,
              BR,
              Roy
              @RoyAzriel 1.6.4 release is tested on Starling 2 now, go ahead and use that from the link I emailed you.
