  3. Issues with controller and drone
starling
22 Posts 2 Posters 3.3k Views 1 Watching
  • D daniellee
    @Eric-Katzfey Hello Eric! Thank you for replying, we were doing that because it was what chatgpt asked and recommended us to do to try to reboot the PX4 system.
    Eric KatzfeyE Online
    @daniellee Okay, well I would have just recommended power cycling the drone. Let's look at your personal drone now. Seems that the RC is working fine since you can see it in QGC. Why do you say it is not receiving inputs from the RC? What are you doing that convinces you of that?
    D 1 Reply Last reply
    • Eric KatzfeyE Online
      @daniellee said in Issues with controller and drone:
      Our preflight was showing pass but the systems never enabled even though the preset is enabled.
      What do you mean that the systems never enabled? What systems? How are you trying to enable them? What is the preset you are talking about? Looking at the QGC screen it looks like it is ready to arm. Can you arm it via QGC?
        D Offline
        D Offline
        daniellee
        @Eric-Katzfey That is the problem. Every time I power cycle the system, it does not keep the services necessary for flight enabled. I will power cycle the drone to show that it does not stay enabled. After power cycling I enabled the px4 service because it was not enable on start up so that I can view the vehicle status.
        The preflight failed in the adb shell. But is passing in QGC.
        I can see the radio RC transmitter moving the joysticks in QGC but the drone does NOT take off. So movement commands sent via the controller are being seen but not used by the drone. Screenshot from 2026-06-16 18-36-07.png Screenshot from 2026-06-16 18-36-45.png
        This is what I mean by the joystick inputs not working. These photos show that the controller is connected and the inputs are being read. However, the drone is not using them.
        • D daniellee
          @daniellee So when you power cycle the drone and then adb in and do voxl-inspect-services which services are not enabled and running that you think should be? In your earlier screen shot voxl-px4, and voxl-mavlink-server were both enabled and running. What other services do you think you need for flight? That's all that should be required for manual flight mode.
          D 2 Replies Last reply
            D Offline
            D Offline
            daniellee
            @Eric-Katzfey I understand that but do you know why the controller inputs arent being received by the drone? We have no idea what is causing this.
            • D daniellee
              @daniellee I don't know what that means. If you can see the RC sticks / switches at QGC then PX4 has to be seeing them. What happens when you try to arm the drone from QGC?
                D Offline
                D Offline
                daniellee
                @Eric-Katzfey It gets armed but the drone does not fly/respond to the controller inputs.
                • D daniellee
                  @daniellee Ah, okay, now we're getting somewhere. If it is arming that means you see the propellers spinning? Can you send me the log file from px4? (Look in /data/px4/logs).
                    D Offline
                    D Offline
                    daniellee
                    @Eric-Katzfey Hi Eric Im not at the computer right now and the px4 logs are the same as the ones above, the props arent spinning even when armed on QGroundControl.
                    • D daniellee
                      @daniellee I don't see any log files attached in this thread.
                        D Offline
                        D Offline
                        daniellee
                        @Eric-Katzfey I have the PX4 log files in a zipped folder but I do not see a way to upload them to the forum.
                          D Offline
                          D Offline
                          daniellee
                          @Eric-Katzfey Hello Eric I have downloaded the PX4 logs- I managed to get a link for one of the logs, the internal timestamp is messed up and I believe this is the most recent one. Here is the link : https://logs.px4.io/plot_app?log=db2c6cd3-f6c9-4bf8-b5bc-dc5ac185c752
                            D Offline
                            D Offline
                            daniellee
                            @Eric-Katzfey said in Issues with controller and drone:
                            Just to be clear, that image you are referencing was the second photo related to the voxl-inspect-services after I enabled and started the px4 service. The first photo shows it not enabled and not running.
                            Upon power cycling, I have to enable it every time we attempt to fly.
                            • D daniellee
                              @daniellee This log shows a normal flight happening in altitude hold mode. RC inputs are coming in and motors are spinning. Was there some issue with the flight this log was captured from?
