  3. PX4 -> QGC connection through USB for VOXL2
27 Posts 8 Posters 4.3k Views 4 Watching
    @bendraper , I will ask around.
    B Offline
    B Offline
    bendraper
    @Alex-Kushleyev So I can see a gadget functionality called gsi.rndis (I'd expect something called rndis.0 or something but maybe that is irrelevant) but when I change the line in /sbin/usb/compositions/901D to use gsi.rndis instead of ncm.0, my network interface on windows disappears and I can no longer ADB. I'd imagine there's something at the kernal level that doesn't like that but I'm out of my wheelhouse there. Setting it back to ncm.0 returns to the previous state but still cannot ping. Wireshark doesn't even see anything happening over that interface
    • Zachary Lowell 0Z Offline
      Zachary Lowell 0
      Hi All - gonna spend a bit of time looking into this today so I can get some context on the problem.
      Zach
      B 1 Reply Last reply
      • Q Offline
        Q Offline
        qt
        wrote on last edited by qt
        #20
        Q 1 Reply Last reply
        • Q qt
          [[topic:post-is-deleted]]
          Q Offline
          Q Offline
          qt
            @Sarika-Sharma ,
            We discussed this internally and we will make an effort to formalize enabling the instructions (in a script) in the near future, but there is a relatively short way of enabling TCP/IP communication between VOXL2 and a QGC host. Please try these instructions and let us know if that works for you or what issue you run in to.
            Basically, there is a command to enable the usb gadget in the kernel and this creates the network interface which you then have to configure on both sides. You can change the IP range if necessary.
            # VOXL2 Setup
            # Begin by configuring the usb gadget
            sed -i '/ln -s functions\/ffs.adb configs\/c.1\/f2/a \ ln -s functions\/ncm.0 configs\/c.1\/f3 2>\/dev\/null | true' /sbin/usb/compositions/901D
            # Next setup a udev rule to give our NCM device a static IP (192.168.7.2)
            echo 'ACTION=="add", SUBSYSTEM=="net", KERNEL=="usb0", RUN+="/bin/sh -c '"'"'sleep 2; /sbin/ifconfig usb0 192.168.7.2 netmask 255.255.255.0 up'"'"'"' > /etc/udev/rules.d/80-usb-ncm.rules
            # Reboot VOXL2
            # Check usb0 network device
            voxl2:/$ ifconfig usb0
            usb0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
                    inet 192.168.7.2  netmask 255.255.255.0  broadcast 192.168.7.255
                    inet6 fe80::935f:1a09:ab1d:d2fb  prefixlen 64  scopeid 0x20<link>
                    ether 56:77:2d:6c:84:9b  txqueuelen 1000  (Ethernet)
                    RX packets 0  bytes 0 (0.0 B)
                    TX packets 0  bytes 0 (0.0 B)
            # Host Side Configuration
            - note that a network manager may rename the device from usb0 to something else..
            ifconfig usb0
            usb0: flags=4098<BROADCAST,MULTICAST>  mtu 1500
                    ether fa:74:5a:f3:2b:88  txqueuelen 1000  (Ethernet)
            #bring up the interface and set it to static ip
            sudo ip addr add 192.168.7.1/24 dev usb0
            sudo ip link set usb0 up
            # Can also use Network manager to configure the network interface for a static configuration
            - address 192.168.7.1
            - netmask 255.255.255.0
            - gateway 192.168.7.1
            # ping VOXL2 from linux host
            - ping 192.168.7.2
            #set up QGC
            - use ip address:port : 192.168.7.2:14550
            You can also use other network tools like ssh, etc, to communicate to the host, but this setup does not enable you to communicate from VOXL2 to outside world (using NAT to enable internet access via the host)
            Q Offline
            Q Offline
            qt
            That's not perfect but I created a shell script based on https://docs.modalai.com/qgc-via-adb/ for the drone configuraiton.
            For my PC configuration, I created an udev rule to force an interface name since usb0 is renamed in "enx******". My udev rule can only work with my drone (I think). To define IP address, I add a conf file in /etc/systemd/network/
            I have only tested on my linux and it works perfectly :
            #!/usr/bin/env bash
            set -euo pipefail
            # See ModalAI doc : https://docs.modalai.com/qgc-via-adb/
            UDEV_RULE_DRONE="/etc/udev/rules.d/80-usb-ncm.rules"
            UDEV_RULE_PC="/etc/udev/rules.d/99-voxl-usb-ncm.rules"
            SYSTEMD_CONF_PC="/etc/systemd/network/10-voxl0.network"
            USB_COMP_QUALCOM="/sbin/usb/compositions/901D"
            # Network configuration
            USB_IFACE="usb0"
            USB_NET="192.168.7.0/24"
            PC_IP="192.168.7.1"
            DRONE_IP="192.168.7.2"
            NM_CONN_NAME="voxl-usb-ncm"
            show_help() {
                echo "Usage: $0 [--pc] [--drone] [--uninstall]"
                echo
                echo "Enable USB NCM networking for ModalAI VOXL / Starling 2 Max"
                echo
                echo "Options:"
                echo "  --pc         Configure host PC only"
                echo "  --drone      Configure drone via adb only"
                echo "  --uninstall  Remove configuration"
                echo "  --help       Show this help"
                echo
                echo "Defaults: if neither --pc nor --drone is provided, both are processed."
            do_pc_install() {
                echo "[INFO][PC] Installing udev rule for VOXL USB NCM"
                cat > "$UDEV_RULE_PC" <<EOF
            SUBSYSTEM=="net", ACTION=="add", ATTRS{idVendor}=="05c6", ATTRS{idProduct}=="901d", ATTRS{serial}=="890d035c", NAME="voxl0"
            EOF
                echo "[INFO][PC] Creating systemd-networkd config for voxl0"
                cat > "$SYSTEMD_CONF_PC" <<EOF
            [Match]
            Name=voxl0
            [Network]
            Address=${PC_IP}/24
            LinkLocalAddressing=no
            IPv6AcceptRA=no
            EOF
                echo "[INFO][PC] Reloading udev rules"
                udevadm control --reload-rules
                udevadm trigger
                echo "[INFO][PC] Restarting systemd-networkd"
                systemctl restart systemd-networkd
                echo "[INFO][PC] PC installation complete"
            do_pc_uninstall() {
                echo "[INFO][PC] Removing PC configuration"
                if [ -f "$UDEV_RULE_PC" ]; then
                  rm -f "$UDEV_RULE_PC"
                  echo "[INFO][PC] Removed udev rule"
                fi
                if [ -f "$SYSTEMD_CONF_PC" ]; then
                  rm -f "$SYSTEMD_CONF_PC"
                  echo "[INFO][PC] Removed systemd-networkd config"
                fi
                udevadm trigger
                echo "[INFO][PC] PC uninstallation complete"
            do_drone_install() {
                echo "[INFO][DRONE] Enabling USB NCM networking on VOXL via adb"
                adb root
                adb remount
                echo "[INFO][DRONE] Updating USB composition in Qualcomm script \
            $USB_COMP_QUALCOM configure the usb gadget with \
            the addition of the function NCM"
                echo "[INFO][DRONE] In $USB_COMP_QUALCOM, \
            add the line 'ln -s functions/ncm.0 configs/c.1/f3 2>/dev/null | true' \
            just after the line 'ln -s functions/ffs.adb configs/c.1/f2'"
                adb shell "sed -i '/ln -s functions\\/ffs.adb configs\\/c.1\\/f2/a \
                \\        ln -s functions\\/ncm.0 configs\\/c.1\\/f3 2>\\/dev\\/null | true' \
                $USB_COMP_QUALCOM"
                echo "[INFO][DRONE] Creating udev rule $UDEV_RULE_DRONE for usb0 with IP ${DRONE_IP}"
                adb shell "cat << 'EOF' > $UDEV_RULE_DRONE
            ACTION==\"add\", SUBSYSTEM==\"net\", KERNEL==\"usb0\", \
            RUN+=\"/bin/sh -c 'sleep 2; /sbin/ifconfig usb0 ${DRONE_IP} netmask 255.255.255.0 up'\"
            EOF"
                echo "[INFO][DRONE] NCM enabled — reboot required"
            do_drone_uninstall() {
                echo "[INFO][DRONE] Removing NCM configuration"
                adb root
                adb remount
                echo "[INFO][DRONE] Removing udev rule $UDEV_RULE_DRONE"
                adb shell "rm -f $UDEV_RULE_DRONE || true"
                echo "[INFO][DRONE] Reverting USB composition (901D)"
                adb shell "
                sed -i '/ln -s functions\\/ncm.0 configs\\/c.1\\/f3/d' \
                $USB_COMP_QUALCOM
                echo "[INFO][DRONE] USB NCM configuration removed"
                echo "[INFO][DRONE] Reboot required to fully apply changes"
            # Arg parsing
            TARGET_PC=false
            TARGET_DRONE=false
            DO_UNINSTALL=false
            for arg in "$@"; do
              case "$arg" in
                --help) show_help; exit 0 ;;
                --pc) TARGET_PC=true ;;
                --drone) TARGET_DRONE=true ;;
                --uninstall) DO_UNINSTALL=true ;;
                  echo "[ERROR] Unknown argument: $arg";
                  show_help;
                  exit 1 ;;
              esac
            done
            # Default to both if none selected
            if ! $TARGET_PC && ! $TARGET_DRONE; then
              TARGET_PC=true
              TARGET_DRONE=true
            fi
            # Execute
            if $DO_UNINSTALL; then
              $TARGET_PC && do_pc_uninstall
              $TARGET_DRONE && do_drone_uninstall
            else
              $TARGET_PC && do_pc_install
              $TARGET_DRONE && do_drone_install
            fi
            echo "[INFO] All done."
              Zach
              B Offline
              B Offline
              bendraper
              @Zachary-Lowell-0 Hey Zach did you discover anything in this effort? I played around with recompiling the kernel to include the CONFIG_USB_CONFIGFS_RNDIS=y flag and confirmed it took on my Voxl 2 Mini, and can see the existence of a new rndis.rndis function in the usb gadget functions directory, but when I try to reconfigure the 901D config file, I end up just breaking the USB port entirely.
                Zachary Lowell 0
                @qt said in PX4 -> QGC connection through USB for VOXL2:
                name
                @bendraper I kind of redid exactly what you described above and ran into very similar issue in the sense that it basically rocked my usb-c port. All this to say, I think we should choose a different route - is it possible instead to route the packets via adb over the USB-C port instead to basically get the same result? Point the software to the serial connection and leverage ADB to pull the packets that are forwarded? Basically creating our own sudo rndis connection almost.
                Zach
                  name
                  Zach
                  B Offline
                  B Offline
                  bendraper
                  @Zachary-Lowell-0 This would probably work but for my use case I cannot guarantee ADB being an option unfortunately.
                  • B bendraper
                    #26
                    @bendraper , have you considered running a docker container (VM) on your Windows machine with a minimal Linux kernel that would use the Linux drivers for NCM and create the proper network connection between VOXL2 and Linux container. Then you could potentially set up the routing table in Windows so that it can access the device via the Linux container and linux container may need to have some networking magic down as well to pass through the communication?
                      Zachary Lowell 0
                      ^^^ This is the next best option outside of ADB IMO - nice suggestion @Alex-Kushleyev
