  3. 5G Modem Cannot Connect to Private 5G Network
cellular
2 Posts 2 Posters 1.3k Views 1 Watching
  • S Offline
    S Offline
    spiff
    We have a sentinel drone with the EM9291 Sierra Wireless modem and are attempting to connect to a private 5G network. The modem seems to recognize the SIM, but has failed to reach out and attempt connecting to the network.
    voxl-modem.conf:
    voxl2:/$ cat /etc/modalai/voxl-modem.conf
    	"modem_type":	"em9291",
    	"apn":	"internet",
    	"world":	"false",
    	"microhard_ip": "192.168.168.100",
    	"dtc_ip": "192.168.0.100",
    	"doodle_ip": "10.223.0.100",
    	"modallink":	"false",
    	"placeholder": "hello world"
    This is the output to voxl-modem-start:
    voxl2:/$ voxl-modem-start
    qrb5165 based hardware detected...
    wwan0 is up!
    Sierra detected!
    Starting qmi network...
    error: couldn't start network: QMI protocol error (14): 'CallFailed'
    call end reason (3): generic-no-service
    verbose call end reason (3,2001): [cm] no-service
    [/dev/cdc-wdm0] Client ID not released:
    	Service: 'wds'
    	    CID: '44'
    Error detected! Retrying...
    	Service: 'wds'
    	    CID: '45'
    I've noticed the SIM is listed as 'illegal' from the output of qmicli -d /dev/cdc-wdm0 --uim-get-card-status:
    voxl2:/$ qmicli -d /dev/cdc-wdm0 --uim-get-card-status
    [/dev/cdc-wdm0] Successfully got card status
    Provisioning applications:
    	Primary GW:   slot '1', application '1'
    	Primary 1X:   session doesn't exist
    	Secondary GW: session doesn't exist
    	Secondary 1X: session doesn't exist
    Slot [1]:
    	Card state: 'present'
    	UPIN state: 'not-initialized'
    		UPIN retries: '0'
    		UPUK retries: '0'
    	Application [1]:
    		Application type:  'usim (2)'
    		Application state: 'illegal'
    		Application ID:
    			A0:00:00:00:87:10:02:FF:FF:FF:FF:89:07:09:00:00
    		Personalization state: 'ready'
    		UPIN replaces PIN1: 'no'
    		PIN1 state: 'disabled'
    			PIN1 retries: '3'
    			PUK1 retries: '10'
    		PIN2 state: 'enabled-not-verified'
    			PIN2 retries: '3'
    			PUK2 retries: '10'
    	Application [2]:
    		Application type:  'isim (5)'
    		Application state: 'detected'
    		Application ID:
    			A0:00:00:00:87:10:04:FF:FF:FF:FF:89:07:09:00:00
    		Personalization state: 'unknown'
    			PIN1 retries: '3'
    			PUK1 retries: '10'
    		PIN2 state: 'not-initialized'
    			PIN2 retries: '0'
    			PUK2 retries: '0'
    Slot [2]:
    	Card state: 'absent'
    		UPIN retries: '0'
    		UPUK retries: '0'
    The system mode seems to be rotating through WCDMA, LTE, and NR5G based on the output from AT commands and qmicli -d /dev/cdc-wdm0 --nas-get-system-selection-preference:
    voxl2:/$ qmicli -d /dev/cdc-wdm0 --nas-get-system-selection-preference
    [/dev/cdc-wdm0] Successfully got system selection preference
    	Emergency mode: 'no'
    	Mode preference: 'cdma-1x, cdma-1xevdo, gsm, umts, lte, td-scdma'
    	Band preference: 'wcdma-2100, wcdma-pcs-1900, wcdma-1700-us, wcdma-850-us, wcdma-800, wcdma-900, wcdma-850-japan'
    	LTE band preference: '1, 2, 3, 4, 5, 7, 8, 12, 13, 14, 17, 18, 19, 20, 25, 26, 28, 29, 30, 34, 38, 39, 40, 41, 42, 43'
    	LTE band preference (extended): '1, 2, 3, 4, 5, 7, 8, 12, 13, 14, 17, 18, 19, 20, 25, 26, 28, 29, 30, 32, 34, 38, 39, 40, 41, 42, 43, 46, 48, 66, 71'
    	TD-SCDMA band preference: 'a, b, c, d, e, f'
    	Roaming preference: 'any'
    	Network selection preference: 'manual'
    	Service domain preference: 'cs-ps'
    	GSM/WCDMA acquisition order preference: 'automatic'
    	Acquisition order preference: (null), lte, umts
    voxl2:/$ busybox microcom /dev/ttyUSB0
    AT!ENTERCND="A710"
    OK
    AT!GSTATUS?
    !GSTATUS:
    Current Time:  412688		Temperature: 40
    Thermal Mitigation Level: 0
    Reset Counter: 1		Mode:        ONLINE
    System mode:   LTE        	PS state:    Not attached
    LTE band:      No band		LTE bw:      1.4 MHz
    LTE Rx chan:   ---		LTE Tx chan: ---
    EMM state:     ---            	---
    RRC state:     DISCONNECTED
    IMS reg state: NOT REGISTERED  	IMS mode:    Normal
    IMS Srv State: UNKNOWN SMS,UNKNOWN VoIP
    PCC Rx0 RSSI:  --- 		PCC Rx0 RSRP:  ---
    PCC Rx1 RSSI:  --- 		PCC Rx1 RSRP:  ---
    PCC Rx2 RSSI:  --- 		PCC Rx2 RSRP:  ---
    PCC Rx3 RSSI:  --- 		PCC Rx3 RSRP:  ---
    PCC Tx Power:  ---		TAC:         ---
    RSRQ (dB):     ---		Cell ID:     ---
    SINR (dB):     0
    NR5G band:       ---		NR5G bw:         ---
    NR5G Tx Power:   ---		NR5G Tx chan:    ---
    NR5G Rx chan:    ---		NR5G RSRP (dBm): ---
    NR5G RSRQ (dB):  ---		NR5G SINR (dB):  ---
    OK
    AT!GSTATUS?
    !GSTATUS:
    Current Time:  412694		Temperature: 40
    System mode:   NR5G       	PS state:    Not attached
    MM5G state:    Deregistered     Limited Service
    RRC state:     RRC Idle
    NR5G TAC:        000001        		NR5G Cell ID:    D15 (3349)
    NR5G band:       n78       		NR5G Carrier ID: 0
    NR5G dl bw:      100 MHz   		NR5G ul bw:      100 MHz
    NR5G Tx Power:   ---        		NR5G Tx chan:    0
    NR5G Rx chan:    622260
    NR5G dl MIMO:    4         		NR5G ul MIMO:    1
    NR5G(sub6) Rx0 RSSI (dBm):   -51.8	NR5G(sub6) Rx1 RSSI (dBm):   -51.3
    NR5G(sub6) Rx2 RSSI (dBm):   ---  	NR5G(sub6) Rx3 RSSI (dBm):   ---
    NR5G RSRP (dBm): -79			NR5G RSRQ (dB):  -11
    NR5G SINR (dB):  22.0
    OK
    AT+C5GREG?
    +C5GREG: 0,0
    OK
    AT!NRINFO?
    !NRINFO:
    Connectivity Mode: SA
    NR5G RSRP (dBm): -114			NR5G RSRQ (dB):  -25
    NR5G SINR (dB):  23.0
    OK
    at!selrat?
    !SELRAT: 00, Automatic
    OK
    at!band?
    Index, Name
    00, All bands,
    0 - GW:    100200000EC00000
    1 - LTE:   0000A7E2BB0F38DF 0000000000000042
    3 - NRNSA: 000081A03B0A38D7 0000000000007C62
    4 - NRSA:  000081A03B0A38D7 0000000000007C62
    OK
    at!sdpref?
    RATs : WCDMA,LTE,NR5G
    GWC  : B1,B2,B4,B5,B6,B8,B19
    LTE  : B1,B2,B3,B4,B5,B7,B8,B12,B13,B14,B17,B18,B19,B20,B25,B26,B28,B29,B30,B32,B34,B38,B39,B40,B41,B42,B43,B46,B48,B66,B71
    TDS  :
    NRSA : n1,n2,n3,n5,n7,n8,n12,n13,n14,n18,n20,n25,n26,n28,n29,n30,n38,n40,n41,n48,n66,n70,n71,n75,n76,n77,n78,n79
    NRNSA: n1,n2,n3,n5,n7,n8,n12,n13,n14,n18,n20,n25,n26,n28,n29,n30,n38,n40,n41,n48,n66,n70,n71,n75,n76,n77,n78,n79
    OK
    • S spiff
      voxl-modem.conf:
      	"apn":	"internet",
      	"world":	"false",
      wwan0 is up!
      Sierra detected!
      	Service: 'wds'
      	    CID: '44'
      	Service: 'wds'
      	    CID: '45'
      Slot [1]:
      		UPIN retries: '0'
      		UPUK retries: '0'
      	Application [1]:
      		Application ID:
      			PIN1 retries: '3'
      			PUK1 retries: '10'
      			PIN2 retries: '3'
      			PUK2 retries: '10'
      	Application [2]:
      		Application ID:
      			PIN1 retries: '3'
      			PUK1 retries: '10'
      			PIN2 retries: '0'
      			PUK2 retries: '0'
      Slot [2]:
      		UPIN retries: '0'
      		UPUK retries: '0'
      AT!ENTERCND="A710"
      OK
      AT!GSTATUS?
      !GSTATUS:
      EMM state:     ---            	---
      SINR (dB):     0
      OK
      AT!GSTATUS?
      !GSTATUS:
      RRC state:     RRC Idle
      OK
      AT+C5GREG?
      +C5GREG: 0,0
      OK
      AT!NRINFO?
      !NRINFO:
      OK
      at!selrat?
      OK
      at!band?
      Index, Name
      00, All bands,
      OK
      at!sdpref?
      TDS  :
      OK
      @spiff You'll likely need to reach out to Sierra Wireless directly for debug help.
