    PX4 calibration
    Starling & Starling 2
    • AniruddhaA
      Aniruddha
      Hello Everyone,
      I have Starling 2 drone and I am trying perform px4 horizon calibration using voxl-calibrate-px4-horizon command. but when I take off the drone I am loosing control of it and It is crashing. is there any other way to perform this calibration
        Eric Katzfey ModalAI Team @Aniruddha
        @Aniruddha Can you use level calibration in QGC instead? Are you saying that you are crashing after running voxl-calibrate-px4-horizon or in your attempt to run it? What flight mode are you using in your flight? If you fly in manual mode is everything okay?
        AniruddhaA 1 Reply Last reply Reply Quote 0
        • AniruddhaA
          Aniruddha @Eric Katzfey
          @Eric-Katzfey when I fly in manual mode it is fine. I set drone on position mode as it said in documentation. I run the command and start calibration then I take off drone from ground. when I move drone after that drone twitch in the air and I lost hit the drone to the safety net. i tried to do it from QGC but when I go to vehicle configuration I don't see any option. and only summary tab which is empty and and firmware tab.
            @Aniruddha Did you follow this guide: https://docs.px4.io/main/en/config/level_horizon_calibration
            • Aaron PorterA
              Aaron Porter
              @Aniruddha
              How are you connecting the Ground Station to the Starling 2? Seems like your QGC instance is not fully loading up the parameters so you are not getting the sensors tab to do the level horizon calibration.
